Question about Panasonic NV-GS200 Mini DV Digital Camcorder
Green Hue on Screen
The camera has developed a green hue on the screen. This is not night vision, it just has a green hue on everything which is still there on playback. The camera was working fine and every now and then when I turn it on, maybe 1 time out of 10, it will be in normal mode when colours are as they should be. I have played with all sorts of modes and settings and cannot seem to get rid of it. Like i said, occasionally it will go away, but not because of a specific thing and it always comes back. Any advice would be greatly appreciated, it's great little camera but pretty useless as the moment!
  • 2 more comments
  • Anonymous Dec 16, 2007
    I have the same problem excpet my screen sometimes turns red also. I guess I am going to call a Panasonic service center.
  • Anonymous Apr 15, 2008
    I have the same problem. But my location is Russian Federation. What to do ?
  • BigMattDaddy Oct 09, 2008
    I am experiencing the exact same problem with the screen and video discoloration.  When I tell tech support of the issue they pretend like it doesn't exist.  They are asking for any reference-able case numbers that they can look up.  The estimated cost to repair my GS200 is $540!!!!!  Does anyone have a case number???
  • Stelios Poyiatzi
    Stelios Poyiatzi Jul 03, 2011
    I had the same sort of problem with model NV-GS200, but now the lcd screen does not work at all. I have to use the view finder to either record videos or watch what I recorded. The serial number falls within the range of C4H******. I bought this camera about 7 years ago. Do you think they fix the problem without a charge? I bought it from UAE and I am located in Cyprus. I would really appreciate any suggestion.
    Kind Regards
Important Notice
Digital 3CCD Camcorder
Panasonic has discovered a premature component failure with a limited number of PV-DV953 (2003 Model) and PV-GS200 (2004 Model) 3CCD camcorders, which may cause an abnormal camera picture (incorrect color reproduction, reddish, noisy image, etc). This anomaly is limited to a specific range of serial numbers listed below.
If your camcorder demonstrates the specific symptom and falls within the serial number range, Panasonic will repair the camcorder free of charge.
Please call the following toll-free number for assistance in receiving a free repair:
Panasonic Call Center: 1-800-973-4264
Model # Serial Number Ranges
PV-DV953 (2003) E3Hxxxxxx, F3Hxxxxxx, G3Hxxxxxx, H3Hxxxxxx, I3Hxxxxxx, J3Hxxxxxx, K3Hxxxxxx, L3Hxxxxxx and A4Hxxxxxx
PV-GS200 (2004) C4Hxxxxxx and D4Hxxxxxx
Posted on Dec 16, 2007
  • Stelios Poyiatzi
    I had the same sort of problem with model NV-GS200, but now the lcd screen does not work at all. I have to use the view finder to either record videos or watch what I recorded. The serial number falls within the range of C4H******. I bought this camera about 7 years ago. Do you think they fix the problem without a charge? I bought it from UAE and I am located in Cyprus. I would really appreciate any suggestion. Kind Regards
Hi
My Panasonic nv-gs120 camcorder was left without the main battery attached for 2 -3 weeks.
Went to use it last week and had the same problem as you
If you have found a solution please advise - I will do the same.
Ray
Posted on Oct 14, 2007
6ya staff
SOURCE:
MY SONY/WEGA/KDF-E5010 HAS STARTED TURNING ITSELF OFF AFTER SEVERAL MINUTES AND THEN ON AGAIN. IT HAS ALSO STARTED SHOWING A GREEN HUE TO EVERYTHING.
The green screen suggests a problem or bad Optical engine. Most Sony sets have a self check for error codes---set off: with remote: Display, 5, vol down, power(hit the power button)
Dec 17, 2012 | Televison & Video
There is too much green color, i tried hue - contrase - lite etc. but the color is still green
how do i get the red and green hue back on my olevia 227-s11 tv my screen is blue and brown
Dec 09, 2009 | Syntax OLEVIA LT20HV 20 in. LCD Television
When using the camera option the screen has a green hue and the pictures I take have the same green hue
Please check the camera settings. If the problem persists then reinstall the firmware after taking a backup of the data on the phone. Remove the memory card before reinstalling.
Dec 04, 2009 | LG enV VX9900 Cellular Phone
Green hue
Unplug the TV from the wall and plug it back after 45-60s should fix the problem. However, it will come back from time to time so the same procedure will reset the video board. You'd want to upgrade the firmware on the ATSC tuner as well because old firmware was built before the final standard and when the TV goes digital in June 2009, it wreak havoc on all older HD TV. Go to hitachi website and download new FW for your TV. Copy the FW to an SD card and follow procedure from Hitachi to upgrade. It works wonder for my TV after the upgrade.
Sep 22, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Wavy coloured lines on the screen all the time & hue
Tv repairman. the green picture tube has an intermittent short in it. This is an expensive fix.
Mar 30, 2009 | Sony KP-51WS500 51" Rear Projection...
Blurred TV - double vision with red hue
I was searching online about what could be the problem with our TV and I came across your page. We have a 52" JVC Projection TV that now has a "blurred" screen. We can see the channels but it looks like it's has a shadow around the images. The screen in in a red hue with green blur.
If you have any suggestions on what caused this and what we can do to have this fixed, I would greatly appreciate your advice.
Sep 07, 2008 | JVC AV-56WP74 56" Rear Projection...
Sudden pink hue to faces
It sounds like you lost your green, try turning down your color all the way and see if the screen is B&W, if it is then you have a problem in the ry-by-gy processor. If tthe screen is not B&W then I would suggest the Green video driver on the green CRT is bad or in that area>let me know!
Mar 13, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic NV-GS200 Mini DV Digital Camcorder Logo
284 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
