Question about RCA HD52W59 HDTV Projection Television
3 curved lines top & bottom/blurred picture
My tv is about 1-1/2 years old. On occasion it would just turn off on its own. Today while watching tv, picture became distorted. I see 3 curved colored lines (green, red & blue) across top & bottom of screen, picture is blurry, almost like the way something in 3-D looks if you're not wearing 3-D glasses. Also, the screen is black in the same curve shape at the top of the screen above the curved colored lines and also at the bottom of the screen below the lines. Anyone know what this might be. Thanx in advance
  • 4 more comments
  • superr186 Nov 05, 2007
    same model same problem brand new lost receipt
  • Anonymous Nov 26, 2007
    same exact problem. always happens out of warranty ;)
  • ardyardy Dec 08, 2007
    i have the same problem
  • Anonymous Jan 21, 2008
    same problem
  • Jo Castillo Jun 29, 2013
    How did you fix it?
    I have mod.# p52937sg with same problem,how do you fix?
    Genius:
  • 1,030 Answers
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Posted on Dec 07, 2007
SOURCE:
I have a 2 1/2 year old Sharp Aquos LCD 32" television that I was watching last week and the colors on the left side of the screen became distorted in columns, and then the whole side of the screen...
Hi, Try moving the TV around so that the bars disappear. It could be you have it too close to something thats affecting the screen. You might even move it to a different room. Good luck.
Jul 10, 2011 | Televison & Video
Picture distorted with images and outlines
Unfortunately this is an unrepairable problem called screen burn.
This happens commonly with old displays and can only be fixed by replacement.
More information can be found here: http://en.wikipedia.org/wiki/Screen_burn-in
Mar 27, 2010 | LG Televison & Video
Distorted picture,After power loss
Replace both STKs covergence chips 392-56or 570s use same STK numbers.
Dec 12, 2008 | Mitsubishi VS-50805 50" Rear Projection...
HCL47154 47IN REAR PROJECTION TV
sound like one of your tubes went dead..
Sep 30, 2008 | Samsung HCL4715W 47" Rear Projection...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Samsung rear projection 42" green curves causing distortion just started
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 50UX57B 50" Rear Projection...
RCA HDTV blurry
this indications that you have a problem with convergence. first try to go into customer menu...setup....convergence. and see if the convergence will adjust.. if it wont then you have a problem with the convergence cuircit boards.
Oct 05, 2007 | RCA HD52W59 HDTV Projection Television
Picture distorted
Hello buddylaw,
Can you post a picture of the TV screen with the problem? It will help in the diagnoses. It looks like you may have a thermal sensitive component causing this issue. But I will have to seen a picture of the screen to properly diagnose this problem as to the possible section that may be causing this problem.
Thank you.
Shuttle83
Sep 10, 2007 | Sony KV-36XBR450 36" TV
Rca 52 inch keeps shutting off and picture is curved
The curved picture indicates failing parts in the pin amp section and probably some faulty parts in the scan amplifier sections. The set is being turned off by the uPC because there is a fault indicated, and it is going in to protect mode.
The set will have to be properly serviced.
Jerry G.
Aug 21, 2007 | RCA 32V420T 32" TV
RCA HD52W59 HDTV Projection Television Logo
759 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
