Question about Canon LV-5210 Multimedia Projector
I plug in the Cannon LV 5210 and the red light is on. Now I press on the red light and it turns green to turn on the projector. The light is green for about 10 seconds and then it goes back to the red light. It is in shut down mode when the fan comes on. Then it will stop and the I will try again and again and it still goes to shut down mode. What do you think is wrong with it? Thanks alot, Stan
  • 1 more comment
  • otfritz1 Apr 23, 2009
    Hello, I cleaned the filters and tried to stick a paper clip in the reset hole and still isn't working. lease let me know what else I can do.  Thanks, Stan
    Hello Mister Firesnake,  Did you get my email that I already cleaned the filters?  Help!!!!!!!!!!!!!!!!!!
    Hello, I have a Cannon LV 5210 that goes into shut off mode when I turn it on. I have cleaned the filters and tried to hit the reset button with a paper clip but I can not get the projector to come on. (The Light) Help!!!!!
    Thanks, Stan
  • Canon Master
  • 3,866 Answers
There is a rely cercuit to the fan that is fouled up and needs to be replaced, Also you need to check the actual lamp for replacement to because when the relay goes so does the lamp inside of the unit. Lets hope its under buyer protection or a warrenty plan.
Posted on Apr 23, 2009
    President:
  • 2,923 Answers
Hello Stan,
Kindly check the filters. To check the filters, please follow the steps below:
1. Turn the projector over and look for the long lines plastic on the side.
2. These plastic lines has doogerhitchies in their middle.
3. Pull them out using your fingernail.
Once you pulled the filters out, clean it in and out and make sure that the filters are dry before putting them back.
  • Melvin Ramos
    Melvin Ramos Apr 23, 2009
    Stan,
    Try to consider these things:
    – Check the projection lamp.
    1. Turn off the projector and disconnect the AC plug. Allow the projector to cool for at least 45 minutes.
    2. Loosen the screw with the screw driver, and remove the lamp cover.
    3. Make sure that the lamp is not loosen.
    4. Try to reset the lamp replace counter.
    – Unlock Key lock for the projector in the Setting Menu
    1. Use the remote control unit and press the unlock key button. This feature is used to prevent operation by a third person.
    If all else failed, kindly contact Canon.
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Jul 23, 2014 | Optoma HD20 DLP Projector
Horizontal lines in display
Canon LV-5210 Service I have a problem with my projector cable will connect the three colored yellow and red travaja not tanpoco and white so little that I can change to part travaje my Canon LV-5210 Service Peden me to say which is the part that must be changed
Sep 28, 2012 | NEC NP3250W Projector
Canon LV 5210's warning led turns red and turns off directkly after start.
warning problem related to lamp, already encountered that kind of problem replace the lamp assembly and it work.
Apr 12, 2010 | Canon LV-5210 Multimedia Projector
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
No picture
When you turn it on if you haer a high chirp chip befor the light turns red
starter ok lamp has reach its life needs to be replcce
Mar 04, 2008 | Canon LV-7210 Multimedia Projector
Warning light stays solid on
The same problem as mine, is there a Canon technical support to help us fix this problem.
Dec 28, 2007 | Canon LV-S3 Multimedia Projector
Projector turns off
hi there may i give a shot?
fan sound get lourder......that is normal after start up
check the bulb
check the filter
restart the projector reset button back of projector
Oct 31, 2007 | Canon LV-5210 Multimedia Projector
Canon LV-5210 Multimedia Projector Logo
111 people viewed this question
old marine
old marine
