Question about Sony Handycam CCD-TRV37 Camcorder
Need a manual for a Sony handycam DCR-HC26
Everything on this camcorder is a touch screen and I can't find where to rewind the tape and record again. I feel like such a stupid female, but my husband usually does this and he is out of town. I need to tape my daughter for a report.
    President:
  • 1,223 Answers
Here is the manual for ur camera just read and Be a MAster of ur camera
http://www.docs.sony.com/release/DCR-HC26_Instruction_Manual%5B1%5D.pdf
Pls rate me FIXYA fo rhelp
Posted on Apr 23, 2009
How to delete contents of sony dcr hc 26 handycam?
There is no erase or delete, per-say...you have to re-record over any recordings on the tape in a silent room with the lens cap on.
May 28, 2014 | Sony DCR-HC26 Mini DV Digital Camcorder
My sony handycam DCR-HC26 is frozen on "clock
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body or the LCD module itself and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Feb 01, 2011 | Sony DCR-HC26 Mini DV Digital Camcorder
Sony dcr-hc26 touch screen does not work
If the touch screen of the Camcorder is not working, pleasefollow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
dcrhc26%20reset%20button.jpgdcrhc26%20reset%20button.jpgmoz-screenshot.pngmoz-screenshot-1.pngrsshajan_3.jpg
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
Please follow the steps below to perform the LCD Calibration
If the issue persists again, service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
Dec 30, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
My Sony handycam won't allow me to use the touch screen features in play mode. I can't rewind, play or fastforward the tape. It has reached the end of the tape - what now?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Reinsert the tape and check the operation
Try another tape to check whether the issue persists only with particular tape.
Note: In the above figure, 8 represents the reset button.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Dec 18, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
My SONY HANDYCAM DCR-HC26 touch panel is not working n m unable to forward,rewind,play,or do anything...how do i fix this problem..plzz help..its urgent...
Most likely, the flex cable that runs from your LCD to your main PCboard is bad. The only thing that you can try to do is flip your LCD around and against the camera. See if the touch screen will work then. The camcorder will still need to be repaired by an experienced technician at some point.
Hope this helps.
www.austintelstarservices.com
Oct 02, 2010 | Sony Handycam DCR-HC20 Mini DV Digital...
My sony handycam DCR-HC26 is frozen on "clock set"
Hello i am hamid
I need a drive for Windows 7 Help me please
hamid.far12@yahoo.com
Jul 07, 2010 | Sony DCRHC26 MiniDV Digital Handycam...
My Sony Handycam DCR-HC26 started giving me C:31:23 error ''Reinsert the cassette'' when I try to record on a new Sony tape. I am however able play back a previously recorded Sony tape.
the error c:31:23 error pertains to one of the reel (part that turns the tape) is malfunctioning. although you can play back videos, you would definitely have issue w/ recording, rewinding or fast forwarding the tape.what you can do is to turn the camcorder off.remove the battery and ac adapter for at least a minute.insert the battery or reconnect the adapter.you can also try pressing the reset button (located near the top of the speaker, on the panel where lcd screen goes to).make sure cam is on when you do that.if still your getting this problem, service would be needed for your cam.hope this helps :)
Mar 18, 2010 | Sony Video Cameras
My sony DCR-HC26 TOUCH SCREEN NOT WORKING
it's not exactly the same, but this website shows a pretty foolproof way on how to fix it on a different camera.
http://www.agoraquest.com/viewtopic.php?topic=33427&forum=32&start=10&select_page_number=2
i fixed the touchscreen on my hc26 with it on the first try. i put a piece of paper folded a couple times under the ribbon cable connections where it meets the screen (against the plastic frame for the screen, under the blue cable), and put a piece of cardboard against the circuit board to give it more pressure from that side. works like a charm!
Jan 26, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
Nov 22, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
Will not record or play back.
the head may be dirty, try cleaning the head with a cleaner tape and try recording again.
Oct 23, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
Sony Handycam CCD-TRV37 Camcorder Logo
162 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
