Question about Apple MacBook Mac Notebook
Cannot connect to Wifi
Hi, i have an apple macbook. All of a sudden, it cannot connect to my home wifi network. It works when connected using a cable. I also have windows installed on it and when using windows, connects to the home wifi absolutely fine. Tried using the diagnostics, but no problem in that
    Habit-Forming:
  • 33 Answers
Try to use NetSpot free app - http://netspotapp.com/
Posted on Aug 09, 2012
Hi there - Why do I keep on getting a message saying 'Playback error has occurred, please try to reload the page'. I did a few speed tests and my connection is between 4.5 and 5Mbps.
Hi, how are the Apple TV and MacBook Pro connected to the network, could be a flakey WiFi connection and/or lots of traffic on your local network... are you able to connect both via ethernet cable and retest, how many other users connected to your network? Cheers, John
Aug 27, 2017 | Apple Computers & Internet
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
Lost wifi connection
Macbooks can be a bit finicky with their Wifi depending on the model number, and also which router you have. For example, an old Netgear-based router I had would routinely drop the connection to my old Macbook Pro, even though the mac had nothing wrong with its hardware or software, and it would still think it was connected perfectly to the internet.
The easiest way to determine if there is a problem with the Wifi built in to your mac is to try it on another network and see how you get on.
If you have no problem keeping connected on an alternate network, the issue lies between your computer and the base station, and is probably also affected by any other wireless networks you have close by.
At this point, without knowing anything about your router, I wouldn't want to suggest anything more, though forcing your router to use a particular Wi-Fi channel rather than allowing it to choose it itself might help out a lot. It's probably best to ask a local technician if they can help out if you're not comfortable changing such settings.
Nov 29, 2013 | Apple MacBook Pro Laptop Computer with...
Hi there, I got an Apple MacBook Pro, OS 10.6.7 and recently got problems connecting to my wireless internet at home. I've got no problems at all connecting to other wlans (at work, at friends'...
So you're knowledgeable, good. Do you have the SSID broadcasting or not? Do you have WEP or WPA, etc active? Can you find the network you are trying to connect to under preferences on your MacBook Pro? Does your network show up? Either way, delete it and start over. If you re-set up your network and it still doesn't find it, but the other machines in your house work wirelessly, it is still a configuration issue. Do you have your wireless network as the default network to find? Do you have a help desk that you can call at your workplace? Give me more details and i'll continue to try and assist.
Jun 10, 2011 | Computers & Internet
Ibook wont log onto my network
I ran into this with my home network and my old g3 ibook needed the older speed wifi to connect. I found my old wifi router, hooked an ethernet cable to the newer router (in a regular ethernet port) and connected the other end to the internet port on the old one... they linked and worked fine to provide wifi for the old G3's ..
Dec 19, 2009 | Apple iBook G3 Mac Notebook
Iphone / WiFi signal / Motorola SB5100 problem
Try turning 3g off, then make sure security of network is wep not wpa personal the iphone has trouble with that
Dec 14, 2009 | Apple iPhone 3G
Someone on my network
We need to first determine what type of WiFi device you have in your home because each has a little different method of creating security. It would be best to create a security code for your WiFi connection that way only the people you give the code to can have access. Keep in mind there are different types of security codes to deal with. The more basic types of security may be easier to decode by a "hacker" but allow the least amount of work by your own computer. Whereas, the more complex security means much more privacy for you but a little more work for your laptop.
There's also the suggestion of making your WiFi "name" something clever and non-guessable, connect your MacBook to it, save it as a preferred network and then disable the "radio" on your wireless router. this will allow your WiFi network to continue working, but it is not constantly broadcasting your network name to your neighbors. They will now need the actual NAME of your network PLUS the security code you've enabled.
Many remote support technology companies, including me, are able to use your Internet connection to connect to your computer and then secure and configure your WiFi device for you if you're not comfortable doing the things I've outlined.
Nov 15, 2009 | Apple MacBook Pro Laptop Computer with...
Could not connect to campus wifi through leopard
You may need to access the network with the ASCII password. Is there a system administrator you can contact to get this code? It will be a very long string of characters and replaces the typical password you seen in many Airport type setups.
Aug 28, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Campus wifi not able to connect
You can only use your Airport with one OS at a time. If you have OS X using it, XP will be able to piggyback.
Can't connect!
First of all... Unplug the modem, unplug the Airport (WiFi router) and turn off the Airport connectivity in your MacBook.
After 5 full minutes... Plug in the modem.
Wait 2 full minutes... Plug in the Airport.
Wait 1 full minute... Turn on the Airport connectivity in your MacBook.
After all of that...
If you're still not back up and running and you're using an Apple Airport, open the Applications folder, open Utilities, open Airport Utility.
If you're using any other type of WiFi router, use the Network Diagnostics button that should show up in the web browser window when you try to go to any website.
Apple MacBook Mac Notebook Logo
212 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
