Question about Cuisinart Thermal DGB-600 Grinder
Grinder blades dull
The grinder is not chopping the beans into a fine ground. The beans are very rough ground. how can I sharpen the blades?
  • Anonymous Jan 02, 2008
    My grinder blades appear to be dull. I've cleaned everything thoroughly. We've had for two years. Can we send off to have sharpened?
Add a cup or so of raw rice to your coffee grinder and zap it until it is ground up into a fine powder, or repetitively zap it it will sharpen the blades and clean your coffee grinder. Wipe down with a damp cloth then dry with a dry cloth.
Posted on Jul 24, 2008
I may be having the same problem. My coffee grinder has had more leftover beans in it more and more this week, until finally today, possibly a quarter teaspoon passed through to the filter basket and the remaining beans were still very much beans. My first assumption was the blades.
Posted on Dec 25, 2007
  • Anonymous Dec 25, 2007
    Oh wait...I obviously didn't have a *solution*...I clicked on "Have the same problem?"
6ya staff
SOURCE:
It got jammed with coffee beans, and then started smoking. I pried out the jammed beans, but now it won't start. Is it burned out?
Try manually turning the chopping blades. If they do not turn easily, you may have something stuck between the blades and the base. Otherwise, yes, you'll need to invest $10 in a new grinder.
May 17, 2015 | Cuisinart Coffee Makers & Espresso...
Why does ground coffee not go thru shoot
If using Beans; it is set to fine and due to static it sticks - OR you have a blockage..
If you are putting ground coffee into a grinder; the static will be a bigger issue and in addition there is no weight from the beans to press the grinds into the burrs. A bean grinder is not ment to grind beans that have already been ground.
Get a better grinder and do not buy supermarket beans.
May 31, 2014 | Capresso 560.01 Infinity Burr Grinder,...
Makes funny noise when I try to grind coffee and no ground coffee comes down into the handle. Seems like something is stuck in the grinder.
if you hear it trying to grind, but is not, or hear it spinning and is not grinding, more than likely it is blocked, or so oily that bean will not drop. Coffee beans, have so much oils in them, that after a while it gets caked up, and beans either get jammed, or stuck. If you hear grinder low humming, then it is probably stuck or clogged, if it is on but hear like a spinning sound, beans are not dropping, because they are stuck because of oil build up. If you can get to the grinder, turn machine off, unplug, get all beans out, take like a wooden chop stick and put it in area where beans go and move the chop stick around the gears. you like your reaming it out kind of. turn machine back on, try this procedure a few times. ( MAKE SURE MACHINE IS UNPLUGGED WHEN DOING THIS) As said early if it is a low humming, like motor turning but jammed, do not use until jam is fixed, you will burn up motor, then have more expensive fix. Let me know if this helped and solved problem. Mr Bean Man from Fixya
Jun 12, 2011 | Breville BES860XL
The grinder spins but no beans get grided. sometimes if i push them down it will work for a while.
Remove all beans from grinder and with the remain beans adjust the grinder to more gross grinding and the make 3 to 4 coffees.
Then Use a vacum cleaner and absorve as much from the grinder. Wash also the Beans hopper with soap and hot water so all oil remianing go away. Dry it very well and put back in place.
Now add new add some new beans and try to make an espresso and when the grinder spins then rotate back to the original grinding position. Remeber that you must go back to fine one step at a time not at once since this will blocked the grinder blades with grounded coffe and grinder will not rotate.
You should to this often is you use oily dark roated beans beans. I sugest to find also a better quality beans which are more light color thus less oily.
Aug 25, 2010 | Saeco Vienna Espresso Machine
Our bean grinder has stopped grinding. It spins but the beans do not grind. The machine works fine on the ground coffee option.
Did you put water in the grinder by mistake? If the grinder is wet it won't grind anymore,have to cleaned the blades physically .
OR are you using the beans from the fridge? It's a NO NO.
Jul 30, 2010 | Saeco Magic De Luxe 30092 Espresso Machine
I placed ground coffee instead coffee beans in coffee bean container. I used the mixer and mix but do not have a mute.Doesn't work.Can I solve a problem or should I call service . If yes, what I have to...
Bean grinders expect to grind whole beans as you have just found out. The grounds have clogged the entrance of the grinder. Use a wood chop stick to try and loosen up the 'caked' coffee and remove the coffee with a vacuum hose attachment. Try to **** out as much of the coffee as you can. Please note that this should all be done with the machine unplugged. Try grinding again but don't let it 'Hum' too long if it's not grinding. You can also try to adjust the grinder 'coarser' to give more room for the burrs to clear. Good Luck!
Feb 16, 2010 | Miele CVA610
Cuisinart DGB-700BC grinds but no grounds in the basket.
Hi there, you have some kind of blockage, If the beans are going down, you need to remove the brewer unit and wash it, if the beans arent going down the exit of the grinder is blocked and needs to be removed, cleaned and replaced
Jul 26, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Thermal DGB-600 Grinder Logo
1,349 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Norman Worley
Ekse
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
