Question about Rockford Fosgate Punch 401S Car Audio Amplifier
Amplifier loads i think I have my subwoofers wired wrong to the amp. Here's how there wired: sub 1, positive of the sub into the 1st positive channel on the amp and negative of the sub into the 1st negative channel. The same goes for my other channel on the amp. What load does this give me? And how would you wire the speakers to the amp? amp: 2 or 4 ohm stable the 2 subs: 1000 watts 1200watts 4 ohm 401s punch bridgeable
  • 655 Answers
Hello ronnieyannon,
A single 4 ohm speaker wired to each channel, like you have them wired, presents a 4 ohm load. And it appears that you have them connected properly. The 401s is only stable to 4 ohms when bridged, so if you were to parallel the 2 4 ohm subs in bridged mode, the load would be 2 ohms and the amp would most likely overheat and go into protection.
I'd wire them the way you have them wired.
Each channel of the amp outputs only 100 watts into 4 ohms. That is adequate for regular full-range speakers, component speakers, mid-range drivers, and even some small subs. But it is a little low on power for most subwoofer applications.
Hope this helps.
Posted on Apr 23, 2009
Can someone please show me how to wire my subs to amp.. i have a 2600 watt planet audio 2 channel amp (2 ohm stable) and my subs are soundstream tarantulas t4 12s 900/1800 watts total. they are 1 ohm subs...
for your subs and amp the best way would be for the speakers to be wired in series1ch (mono or bridged)to have a 4 ohm load to your amp stable at 2 ohms
see pic for wiring diagram for 2 1 ohm dvc subs wired in series.
you will need more than one speaker wire for wiring the subwoofers coils(positive & negative terminals) together
hope this helps :~)
Mar 03, 2014 | Car Audio & Video
I have to hook up 4 amps in my car. 4 channel 700 watt ken wood, 2 channel 800 watt Sony, 4 channel 740 watt Jensen ,and a 2 channel Rockford fosgate. Which is best way to hook them up so I'm not ki
Pace posted on Saturday, March 05, 2005 - 01:08 GMT Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms.
Nov 26, 2012 | Computers & Internet
Jl1000/1 amp wiring to 4+4 ohm sub to 2ohm staple.
From your information I am assuming that you have a sub that is dual 4ohm voice coils. Also, I am assuming that you have a single channel amplifier. This is easy to get to a 2 ohm load.
First, go from the positive of the amp to the positive of both voice coils. Then go from the negative of the amp to the negative of both voice coils. You should have two sets of wires running to your sub. This is called a parallel set up and decreases the ohms load of the voice coils to a singe 2 ohms If you have a prefab box, just do the same thing, but instead of the amp, you will be wiring to the cup terminal inside. The amp will be wired regular to the cup terminal on the outside with just one wire.
This is all assuming that you are hooking up only one sub. If you attempt to hook up 2 subs like this to a mono amp, you will drop the load to 1 ohm.
hope this helps
Aug 25, 2011 | Jl Audio 13W7 Car Subwoofer
I need help installing a 4 Channel Power Acoustik Amplifier to Two Pioneer Subwoofers. I hooked up the power wire to the positive battery terminal in the engine compartment. I then cut the power wire and...
You are doing right on what you described. I really like to work with a clearly described what involved in an issue.
Now we have to use a Voltmeter to check if there is power to the amplifier. If there is power to the amplifier terminal, then the problem is at the amplifier, not the connection. Let check it out:
1- Turn on your Kenwood radio, make sure to hear sound from your regular speakers.
2- Turn remote control knob to the mid level between min and max.
3- Measure the blue wire where you spliced to ground to see if you have 12V, if it is not then the problem is right there.
4- Measure the Red wire power from the Amplifier to ground ( the bolt that you connect the negative power to see if there is 12V, if not trace back to the Fuse that you inserted between the positive terminal of the battery and the wire going through the firewall to correct it.
5- If you have 12V at step 3 and 4, then you have a defect unit, return it to the manufacturer for a replacement.
Sep 06, 2009 | Car Audio & Video
Rockford fostgate p500-2 amp overheating pls help!
Your Amplifier:
125W x 2 @ 4-Ohms RMS
250W x 2 @ 2-Ohms RMS
500W x 1 @ 4-Ohms bridged RMS
Your Subwoofers = Dual 4 ohm
Possible wiring configurations of (2) Dual 4 ohm voicecoil subwoofers are:
2 ohm Stereo
1 ohm mono
4 ohm mono
That amplifier is not 1 ohm mono stable.
You need to put a 4 ohm load on the "bridged" terminals of the amplifier
Your best wiring configuration is going to be Series-parallel.
CLICK HERE to see the pic Larger
4721108.jpg You can also get the same result (power) by having the subs wired in parallel independently. Put both + on one sub to one + on the amplifier and both - on one sub to the - of the same channel of the amplifier.
Repeat for channel 2.
This will be a 2 ohm stereo load.
You should only use this method if the subwoofers are in seperate enclosures... not one big cavity.
Thanks for using FixYa -a FixYa rating is appreciated for answering your FREE question.
May 03, 2009 | Rockford Fosgate Punch P5002 Car Audio...
How to wire 2 dvc subs to a orion 2150sx ? dont know the wire colors or how to hook um to my amp.
what impedence are the voicecoils?
Dual 4 - Dual 2 - Dual 1 ??
Orion SX / GS / HCCA amp Wiring guide:
Orange = Right Positive
Black/ Orange = Right Negative
Yellow = Left Positive
Black/ Yellow = Left Negative
Blue = 1+1
Bridging of SX or HCCA Amps:
1. Use the Orange wire for Positive.
2 Use the Black/ Yellow wire for Negative
3. Push "in" the Mono Button
That amplifier is only 4ohm mono stable - so assuming the subs are dual 4 ohm voicecoils...
First wire both in Parallel Independently So each subwoofer is now a 2 ohm load. (combine + and + - and- on both subwoofers)
Now Take a positive on one voicecoil of sub #1 and attach to amplifier+(orange)
Take a - on that same subwoofer and attach it to a + on the OTHER subwoofer.
Finally, take a - from the second woofer to the amplifier -(black/yellow)
Now you have a 4 ohm load on your bridged channels.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 23, 2009 | JBL 1200GTi Car Speaker
Alpine type-r 2ohm dual voice coil help
try reconnecting your rca's from the deck to the amp when finished wire one speaker positive to positive on left channel and negative to negative on right channel then connect the 1st subwoofer. if all power and sound is fine and working turn off power to amp and connect negative terminal of 1st sub to positive on 2nd sub and positive from first sub to negative on second crossing the wires runs the speakers in series another way to try is parralel the speakers wiring by connecting positive left channel output of amp to positive on 1st sub same with the negative then splice positive to positive on second sub and same with negative.
Feb 09, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
How to wire 2 ohm 2 12ich alpine type r's to box terminals?
Dual 4 ohm subwoofers can only be wired @ 1 ohm, 4 ohm or 8 ohm.
2 ohm mono load is not possible.
You will need to use (1) subwoofer to get the 1000W out of the amp.
Wire both positives on one sub to + on amplifier and both - on the same sub to - on amplifier to give the amplifier a 2 Ohm load.
Add a second amplifier, or buy an amplifier that is 1 ohm mono stable.
You can wire both to the amplifier at 4 ohms 600W, but they will share the power and only see 300W ea.
Jan 12, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
How can i get a 2ohm load outta 2 4ohm dvc subs can you show me how to wire the amp as well it says on the amp its 2ohm stable
A normal wiring setup to produce a 4-ohm load is what you usually see - each speaker is wired to one channel of the amp. This is series wiring. To get a 2-ohm load, you need to wire in parallel. Here's how:
Take sub A and wire the positive terminal to the positive terminal of channel 1 on the amp. Wire the negative terminal of sub A to the negative terminal of channel 2 on the amp. For sub B, it's the opposite - positive terminal of sub B to the positive terminal of channel 2, and the negative to the negative terminal of channel 1. That's parallel wiring, and will produce the 2-ohm loading (and subsequent increase in output) that you're seeking.
Aug 28, 2008 | Jl Audio Car Audio & Video
Amp connection
Parallel would be the best way to wire them. 2 4 ohms subs to one channel wired parallel would be a 2 ohm load for that channel and if u wire them series then 2 4ohm subs to one channel would be an 8 ohm load for that channel.
May 31, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Rockford Fosgate Punch 401S Car Audio Amplifier Logo
214 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
