hello! my mini ipod freezing, when i turn it on, the apple sign appear, after the apple sign disappear then the charger sign shows and i could not turn it on to menu, its freezing, i tried to connect via usb to my laptop and its not detecting.. how to solve this problem? could anyone can help me? TIA! my ipod mini isn't recognized by my computer when I plug it in, it starts to show the battery recharging sign but then freezes up. I can toggle the hold switch and press menu and the center button to reset it, but the apple sign comes on and then nothing else happens.
Comments:
Apr 23, 2009
- i can't get it to go into disk mode, when i reset it the apple sign goes away and then comes back on, but then when i switch to pressing select & play nothing happens. if the apple sign doesn't go away, does this mean it's got some battery charge left or not? i don't know what to do next with this damn thing.
I would attempt putting the ipod into disc mode and see if your ipod is recognized by the computer after you reconnect it.
I have researched this issue and found a knowledge base article on apples web site that may help you out with this.
Here are the steps to do it...
Putting iPods with a Click Wheel into disk mode
Before placing the iPod into disk mode, you should verify that it is charged.
Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center. If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If it won't go into disc mode while not connected to your computer, try doing the above steps with it already connected to you computer. If none of these steps work, it is sadly probably time to get a new ipod. I hope that it does help you out though. Good luck :)
Comments:
Apr 24, 2009
- You need to switch from holding down the menu and center buttons to holding down the play and center buttons right as you see the apple.
If the battery is low or dead it will say connect to power.
Please try putting it into disc mode a few more times before giving up. It can be difficult getting it into disc mode the first few times you do it.
I have a Neeon2 creative zen, it has a bad problem. once I found out that some files with strange...
(More)
I have a Neeon2 creative zen, it has a bad problem. once I found out that some files with strange names like sistem codes appeared on my device, out of other directories (like pictures, music,?) then I decided to format it, because they didn?t remove. But when I formatted my mp3 player with my laptop (win vista 32-bit) it seemed that sth bad happened to it, I installed firmware but it still didn?t work, it seemed that it has gone mad, it wrote ?font mismatch? and doesn?t work anymore. And even didn?t get charged? . I connected it to win XP professional and installed firmware but it still doesn?t work. Plz help me
When I plug in my iPod Mini I get an Error Message stating that iTunes detects but can't recognize a...
(More)
When I plug in my iPod Mini I get an Error Message stating that iTunes detects but can't recognize a new iPod. This does not occur when I connect my iPod Classic - everything runs fine. I have a Windows Vista PC and am running iTunes 8.0 Peter
My ipod mini is 6gb bought in March 2005. It worked fine until last year. It is still charging and...
(More)
My ipod mini is 6gb bought in March 2005. It worked fine until last year. It is still charging and all the songs are still in the ipod. However, my computer can no longer recognize it. Same with iTunes.
My ipod mini is 4gb bought in september 2004. It worked fine until last year. It is still charging and all the songs are still in the ipod. However, my computer can recognize it & but can't install driver. Same with iTunes.
