Question about Crown XTi 2000 2-Channel Amplifier
Keep blowing speakers
We have a crown xti 2000 amp (1000x / side) and had two behringer E1520 400w speakers in a school auditorium setting. We have gone through 3 speakers now ... we are assuming it is from clipping. What hardware type of solutions will reduce the risk of blowing more speakers. The general users of this equipment are teenagers, so expecting responsible levels of sound are not likely. Any suggestions ... new amp?, more powerful speakers?
Signed ... I have no idea what I'm doing..
bm
  • 4,234 Answers
It sounds more like you are overdriving the speakers not clipping the amp. If the output rating for the amp is 1000W into 4 ohms, this is approximately 500W into an 8 ohm load. Your speakers are rated for 400W. If you are running the amp at full output, that is too much power for the speakers and either the speakers are warming up too much and failing or are being extruded too far and failing. Your best bet is to better match the amp/speaker setup. Crown amps have built in clipping indicators and I believe that the xti series also has a compression circuit that would prevent distortion on the output side.
To confirm my suspicions, in what manner are the speakers failing? Are they completely open or do they sound distorted?
Thanks,
Dan
Posted on Apr 23, 2009
I use the crown xti 6000 for 2 double 18s pd186 for bass per channel
Send a signal from the mixer to the amp directly, seems as if you have a distorted signal from your crossover
Dec 23, 2013 | Crown XTi 2000 2-Channel Amplifier
How to connect mixer to a crown power base 2 amp and speakers
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
How do I unlock my XTi 2000 amp?
Pressing & holding the prev/up & next/down buttons at the same time will toggle the lock on or off.
Mar 12, 2010 | Crown XTi 2000 2-Channel Amplifier
I have my amplifier connected to my dj system only one speaker of the bass works wich is channel 1 channel 2 does not work and fault button keeps on blinking red?
The XTI 2k has lots of DSP options built into the front panel. If it's your intent to run the amp in bridge mono for subs be sure than you have all settings set correct for the DSP, it's very possible that channel 2 will render in-active.
This also applies in the case if you wanted to run your subs in stereo and the internal settings are set for bridged mono.
Another possibility would be if the DSP was set with a crossover. If you put a cross-over point (Low Pass Filter) on the high side of the sub, if becomes the High Pass Filter of Channel 2. Audio would pass if there was no other filter sets, but would not if you were using a crossover and then hitting the subs.
Sep 11, 2009 | Crown XTi 2000 2-Channel Amplifier
Crown Xti 2000, signal to both channels, no sound out of one, swapped speakers, connectors, etc. , still no sound out of one channel
common problem with xti series... all the amp needs is a soft ware update contact crown and they can sort it for you... you dont have to send the amp back to them. it was a verry common fault with all the early xti amps..
Aug 24, 2009 | Crown Audio Players & Recorders
Can this all be hooked up?
There was never anything mentioned about the 18 yamaha sub in the hook up process
Aug 17, 2009 | Crown CE1000 2-Channel Amplifier
Crown XTi 4000 brand new digital amp how can i unlock it? i dont know but the screen display short 1
Hiya, to unlock press PREV and NEXT until it says unlocked.
The short 1 sounds a little serious though. Have you tried taking off the speakers?? If still there then suggest contacting crown. They have a pretty good no nonsense 3 year warranty
Best of luck
Jul 13, 2009 | Crown XTi 4000 Amplifier
I have two xti 2000 amp running with electrovoice speaker 600w
This is most likely to be a heat issue where the amps overheat and shut themselves off then cool down and turn back on. Please check that the amps have proper ventilation and that any air ducts are clean.
Feb 26, 2009 | Crown XTi 2000 2-Channel Amplifier
Amp keeps blowing speakers
If the amp blew the speakers , it sounds like the amp pumped HIGH levels of DC voltage into the speakers.
Get another amp and not Behringer,not Pyle,not Gemsound and not Numark.
Feb 02, 2009 | Behringer EUROPOWER EP2500 Amplifier
How would i conect a ep2500 amp two 2 subs @ 4 ohms, or 8ohms
hey" i got 2 behringer 2500 amps and i have 2 peavey speaker that are 4 ohms 2000 watts eachand want to mono the amp separte,and i want to run 1 amp to each speaker so can you help me?
Nov 26, 2008 | Behringer EUROPOWER EP2500 Amplifier
Crown XTi 2000 2-Channel Amplifier Logo
249 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
