Question about Panasonic Televison & Video
On my 50 panosonic hd tv the right hand speaker is humming but when i switch the red and white cable for audio the left hand speaker hums
    President:
  • Panasonic Master
  • 1,779 Answers
Sounds like you have an open shield with your rca cable....Replace it.
Posted on Apr 23, 2009
There is problem in my samsung 21 Ultra Slim Flat TV. there is no picture but only sound when connected to satellite receiver with AV cable. why is this??
You need to be more specific . There are usually three types of "A/V" cables. There is the HDMI cable. One cable many wires inside and the same plugs at either end. There is component. This has 5 RCA plugs at each end. They are color coded so you dont mess them up. However, there are 2 red ones. One of the red ones is paired with a white one and carries the left and right audio. The other, red video. The last type is the old style and there are 3 cables - red white and yellow. Yellow is the video and the red and white are left and right audio. The easiest way to prove what is bat is by substitution. Swap receivers, and cables is one way, or use a DVR with the same connectors. Oh and does your tv's audio work at all? (Dont have it muted and or the volume all the way down. or a headphone in the headphone jack). One way to test the audio cable plus TV is just unplug the component audio cable from the receiver and touch the center pin with your finger with the volume way up. SHould here a hum if its a good cable and tv's input. One way to sub for the tv audio is to patch the satellite audio out to an audio in of an audio sytem like an FM receiver. If its good into that system and flunks the hum test, your tv is suspect. Have fun.
Jun 09, 2014 | Samsung 50 in. Plasma TV
Pioneer M-EV51 surround problem.
TRY CONNECTING THE RCA JACK (RED,WHITE) AUDIO
INPUTS. MY GUESS IS THAT IT WILL WORK THAT WAY,
AND IF IT DOES CHECK ALL AUDIO SETTINGS ON BOTH
AMP & TV PCM digital audio / LPCM digital audio (LIMITED)
MAYBE BAD HDMI CABLE. SEEN IT SEVERAL TIMES B4
Nov 14, 2013 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Wiring for radio speaker wire color misibishia?aido
1989 Dodge Ram 50 Car Audio Wire Harness Color Guide
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Violet/Yellow
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
May 20, 2011 | 1989 Dodge Ram 50
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
I have a panosonic surround sound system and a toshiba 60" tv and when watching tv speakers have a humming sound , but when watching a dvd speakers are fine and no humming sound.what is the problem? Tv...
it depends on what volume level the tv is on
if the level of volume is low and making the sound then try unpluging or pluging in the sound system to the tv
Sep 13, 2009 | Televison & Video
How do i use it so my tv programming is in surround sound?
if the Comcast cable box has an HDMI output, it should connect directly to one of the TV HDMI inputs. Then connect the LG DVD unit HDMI output to the second HDMI input of the TV. Use two HDMI cables. Do not buy the expensive Monster HDMI cables. If you have already done so, I recommend you take it back for a refund, then buy the low cost HDMI cables which will work just as good and then you can bank the savings toward a new Porsche Boxter!! Now we have the video connected from both the cable box and the LG system.
Now--what do you do if the cable box does not have an HDMI output--just use its component output and your component cable (red, blue and green) to connect to the TV component input. This will still get the video to the TV and good HD pictures. Hum--do you have an HD cable box? You did not say and I just assumed that you did since you got the HDTV. If not, let me know with a follow up question and I will assist in that area further.
Now for the audio connections--The DVD player will not need any connections since it in the LG unit. The sound will come out the speakers when you start playing the DVD. The cable box is where we get the TV audio to feed the LG unit. If the cable box has an optical output, use an optical cable (again the low cost one)and connect to the optical input on the LG.
This will get the TV audio to the surround system. If no optical output, use the red and white (left/right) audio connections and connect to one of the two the LG audio inputs. To hear TV audio on the LG speakers, just switch to that input or the input associated with the optical input.
To watch DVDs, switch the TV to the HDMI input to which you connected the LG unit. For TV, go to the other HDMI input (or component input).
Switch the LG to the audio input to which you connected the cable box to get TV sound.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Sep 11, 2009 | Audio Players & Recorders
Tv hums when hdmi is connected via dvd player
how do you have the audio hooked up for it if you are using componet cable (red,white) for sound they could be causing the humming you can either switch audio cables or use some other form of cable for sound
Jan 24, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Humming from speakers
I need to know how you have your TV hooked up through the cable for ex. hdmi or the green blue red white and yellow cables that plug into the back if its not doing it through the ps3 or anything else means its not the TV its either a faulty cable box or the wires are bad or hooked up wrong going to the tv.. i would first check make sure all the colors are in the right color slots if thats how you have it hooked up and if thats all right then just email me back through the fixya website i am on every hr id be happy to further help you, and if you can please give me a rating it would be greatly appreciated...
Thanks,
Steve
Dec 29, 2008 | Sony Televison & Video
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Hum from speakers
I suspect an open ground or bad cnnection in your hdmi cable to the amp from the sat.A hum is very indicative of that situation
Dec 11, 2007 | Onkyo TX-SR604 Receiver
Televison & Video Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
