Question about Axsion Televison & Video
I need to rescan the channels but it is not an option under menu.
Hello, I recently purchased an Axion ANX-8701 7" LCD handheld TV. As I took the TV out of the box, it powered on and started that channel search. I didn't have time to set up the anntena so It didn't really get all of the channels. I need to rescan the channels but autoscanning is not an option under the menu items.
Thank you
  • d_griffiths Apr 23, 2009
    Thank you I will try this and I may take the instrument outside and try to retune.
    The unit came with 2 antenna. One that was sorta hard wired in that the antenna is connected on top of the unit (see the picture on the Target website) but you can plug and unplug the pin connector into the TV. There is an external antenna that can be plugged in to the same slot. This antenna can be moved around. It has a round base with the antenna pointing up. I purchased this little tv as a way to use it in my office. Some of the stations in my area have already switched to digital. I was hoping I would be able to use this unit, since it appears to come with the technology for digital. If I can't rescan I won't be able to use this :(
    Thank you again
  • 68 Answers
You will need to manual scan. you must put on the ariel as this gives you the pictures check the instructions. for searches, if you dont get any channels after tuning then take it back to where you got it,
Posted on Apr 23, 2009
  • sandra mac dougall Apr 23, 2009
    thankyou very much for the reply. you say its for your office. and there is a connection for an external .when you are at home take out the arial from your home tv and plug in to see if you get nice clear pictures?. if ok it could be the arial has a gap in it this can lead to picture loss. or the connection from inside the little tv. easy to fix. check the cicuit board trace the from the bottom of the arial. to where it is solderd and check for a bad solder joint. and remake also you may want to check the tunner for dirt as this would cause slipping. you can use a rubber to clean up the contacts.you can also check the arial connection to see if it is damaged???.if you need to buy a new arial make sure its 75ohms to get a clear picture.
Toshiba LCD TV/DVD 15LV505 lost channels. Rescan = fewer channels. Now in Setup, when I press the remote down-it skips the Channel option. What must I fix/change in Settings to get the Channel option?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
Dec 08, 2016 | Toshiba Televison & Video
How do I get the menu cursor to move up or down in order to rescan my TV?
either the channel or volume buttons perhaps if there are no other up,down buttons
Nov 17, 2015 | Televison & Video
Need universal remote control tv codes
If you have a universal remote control, you can use its code search feature to try to find a code that works. If you search through allcodes stored in the remote without success, you may have to try another universal remote. Different remotes may have different codes.
Mar 14, 2015 | Axion AXN-8701 7 in. Portable TV
Vizio tv dropped a channel, won't rescan
Try with the remote to direct enter the channel number (with the number buttons and or enter) If set makes it there go into menu for option to manually add it to the set memory.
Not likely a problem with your set.
Dec 17, 2012 | Vizio RazorLED M260VA 26" LED-LCD TV -...
Plugged in, cable connected, turned on, says "No Signal"
OTA signal? Check your antenna orientation and if there are any tall objects that would interfere with the signal. (See antennaweb.org or tvfool.com for signal directions and distance to the station. antennaweb assumes an external antenna and is very conservative with station information.) Scan for channels with Menu > > (right arrow twice) up or down to AutoScan and hit enter. Use add channels to include stations with the antenna in a new direction.
If you are using the built-in antenna, you may not get digital signals. Try an external antenna (see above sites). Digital signals are enough or zero.
This TV doesn't have a cable tuner so a set top box would be needed for cable stations, check the box directions for the station you need to tune the TV to access the signal.
I hope this helps.
Aug 05, 2010 | Axion AXN-8701 7 in. Portable TV
Picture loss
hello,, I suggest that you go into the menu find the auto scan or auto channel setup and allow the TV`s to auto setup, this will find valid channels and tune them in, this should solve you problem, also note, after a power failure you need to rescan or re tune, it will not remember your last setup good luck
Apr 26, 2010 | Televison & Video
My viewsonic N3751w LCD TV won't receive air signal. It has a built-in digital tunner so it should be able to receive several air signal without a need to have a digital to analog converter
Check that your antenna is sufficient for your location and oriented correctly. Try antennaweb.org for the most likely channels; tvfool.com has a much greater list of channels and the antennas needed to receive them. Both sites assume external antennas and warn that trees and buildings around your location may cause interference.
If you have a splitter connecting one antenna to several TVs, consider using an amplifier to ensure that the TV gets sufficient signal strength. Remember digital TV is has all-or-nothing reception issues.
If you previously could pick up the stations with this TV and suddenly lost them, try resetting your TV. Unplug the unit for at least 10 seconds. Also restore the factory default settings and then rescan for all channels. The reset is possibly Menu, Options, Restore Default or Menu, Setup, Memory Recall. (Viewsonic has changed its menus at intervals so look for something similar). Once you find it, click enter then left or right arrow to YES, hit enter again. Then hit menu twice to exit the OSD menu and then re-enter the menus before trying to rescan channels.
Also check that the TV is looking for OTA and not cable signals. Check that the tuner is still working by retrying the scan in a spot you know that the antenna captures a stations signal. Make sure your antenna cable hasn't been damaged by anything.
If you recently had a power surge (lightning strike) near the antenna or cable, you may be in need of a new tuner. (BTDT with an older TV)
I hope this helps.
Apr 24, 2010 | ViewSonic N3751W 37 in. LCD Television
Axion handheld tv. No picture at all.
I have on and if the batteries start getting weak the screen display brightness is the first to stop working. Double check that, if you are on AC power try sliding the brightness control from dim to bright a few times and see if the rheostat has corroded. Those are a few of the quick checks you can try, let me know. Jay
Jan 21, 2008 | HandHeld Entertainment Axion 2.5'' TFT LCD...
My jensen lcd tv
It sounds like you need to reset this device to original specs. This can be done by leaving it unplugger for 4 - 5 hours. Then is this does not work you will have to contact the company and get aa schematic. At that point we can begin troubleshooting.
Sep 03, 2007 | HandHeld Entertainment Axion 2.5'' TFT LCD...
Televison & Video Logo
227 people viewed this question
Top Axsion Televison & Video Experts
KG John Justin
KG John Justin
Are you an Axsion Televison and Video Expert? Answer questions, earn points and help others
