Question about Canon EOS Elan 7 35mm SLR Camera
Canon EOS Elan 7
When I turn my camera on to start taking pictures, the battery blinks in the top window as if I have a low battery. I know this is not true, because I changed the battery more than once. The only thing that I have tried is to clean the battery contact points with an eraser on the end of a pencil.
  • Anonymous May 27, 2008
    battery symbol flashes and camera will not work. tried 3 sets of new batteries with no success. After reading this I opened the flash manually and turn camera on and off. It works.... until I try in a darker location again. THANKS for the advise.
I had this problem when on vacation and could not find anyone to work on my camera. Now home I was scared to take into the shop for repairs. I found this in a search and tried it. WORKED PERFECTLY for me. Now to find why the flash does not come up is not as scary... THANKS
Posted on May 27, 2008
I have the same problem!!
Posted on Sep 25, 2007
  • aceya Sep 26, 2007
    Try pulling the flash up and turning it on and off. I think it's a problem with the flash. I had the same problem when I tried to shoot in auto with the flash down. I think the flash cannot pop up on its own for some reason and it shuts down to prevent damage.
    I can shoot with the flash down in creative modes, but when I try that in auto, I get that battery warning. Probably a spring is broken or something.
    The elan 7 needs the flash to strobe to get the best use of it's autofocus
SOURCE:
Camera will not turn on, even with new batteries
Do you get a flashing low battery symbol? If so, try setting it on P instead of the green rectangle. If it then operates then the shaft in the flash pivot is bent and not operating the flash switch.
Sep 11, 2013 | Canon EOS Elan 7 35mm SLR Camera
I dug up my old Canon Elan 7e and put new batteries in the Vertical Grip Battery Pack BP300, but it's still dead. Anything I can try before bringing in to a camera shop, or selling both the camera and...
Take off the BP300 and put in the appropriate batteries in the camera. If the camera works without the BP300, you know the problem is in the battery pack. If not, you know the problem is in the camera. On eBay, you can replace the camera body for about $35 and the battery pack for about $20.
Hope that helps,
Bax
Aug 05, 2013 | Canon EOS Elan 7 35mm SLR Camera
Which battery to use with eos elan?
The EOS Elan uses a single 6V lithium 2CR5 battery, which should be available at most department, electronics, and office-supply stores. If all else fails, you can buy it online from here.
If you need a manual, you may download a copy from here.
Oct 26, 2012 | Canon EOS Elan II 35mm SLR Camera
Problem with an old Canon EOS elan camera
Try an ammonia-based cleaner..but don't get it on the plastic.
Jun 22, 2009 | Canon EOS Elan 7 35mm SLR Camera
I have got an EOS Elan II E Film Camera (Cannon). I want to know Cannon has camera with a digital body which suits the lens attachment of EOS Elan II E.
Hi, all canon EOS digital cameras can take all EF lenses. An EF lens from 1989 will fit a Digital body from 2009.
The newer EF-S lenses will only work with the smaller APS-C size sensors on the cheaper consumer bodies.
Hope this answers your query, please take the time to rate!
Mar 10, 2009 | Canon EOS Elan IIE 35mm SLR Camera
Canon ELAN 7 Battery issue. Camera won't recognize new batteries
a new battery will provide enough power to run the camera.....If your battery is not charging right the power will not be enough to run camera ...just the low level warning....which takes very little power to run!
Dec 11, 2008 | Canon EOS Elan 7ne 35mm SLR Camera
Canon EOS Elan 7 35mm SLR Camera Logo
173 people viewed this question
Top Canon Photography Experts
old marine
old marine
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Canon Photography Expert? Answer questions, earn points and help others
