Question about HP OfficeJet 6110 All-In-One InkJet Printer
Error code of Carriage block, but cant find it!
I am getting a clear carriage and then press enter, there is nothing blocking the carriage that I can see. It also is not feeding paper it starts to take it then backs it out. HP OFFICE JET 6110
  • Anonymous Apr 29, 2009
    Exact same as above.......starts to take paper than pushes it back and continually says "clear Carriage" with nothing visibly blocking the carriage.
  • inkypete May 11, 2010
    Did you have a recent jam?Have a look inside with torch carefully
    try pulling the power when head moves to centre and check
    I feel there is some paper over a sensor, only needs to be a little bit
  • 25 Answers
There are several steps involved to troubleshooting this error. Please visit this link and complete every step per the manufactuers instructions.
Posted on Apr 23, 2009
Mx 316
Error 5100 typically means that something has jammed the carriage. Unplug printer, open, and examine the print area for anything that might be blocking the print heads from moving back and forth. clear...
Sep 07, 2014 | Canon PIXMA MP160 All-In-One InkJet...
Hi hp designjet t1100ps plotter showing error code 86:01, paper jam. but physically there is no paper or obstacle in print area. carriage block also moving one time right to left then the error code is...
This error can be caused if there is anything blocking the movement of the carriage. I just had a client with this problem on Tuesday and it turned out that they had opened the print head cover and had not closed it properly. This caused the metal latch to block the movement of the carriage. I would check that first, as well as look for any small bits of paper that may be blocking the complete movement of the carriage.
Apr 01, 2011 | HP Designjet T1100ps Printer
Canon PIXMA MP480. Print head slams all the way left, then all the right at startup. Error code 5100. Have looked the encoder strip, cleaned it, looks OK. Carriage seems to move freely. Wondering if...
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp480#ServiceAndSupport
The above is a link where you can enter '5100' and it will return 3 possible solutions for the error code 5100.
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press the button. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON button does not shut off the printer.
  2. Wait approximately ten seconds and then press the button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
    Note: It may be necessary to unplug the power cord and retry if the above steps do not clear the error.
--- Secondly, it says that it could have 'packing' material in the printer when new, blocking the movement of the printhead, but I don't think that's the case since you say the carriage seems to move freely.
Feb 12, 2011 | Canon Pixma MP500 All-In-One InkJet...
I'm getting an error msg and can't print. It says please fix cartridge jam and hit enter. I can't find any jam. What do I do?
If there isn't a cartridge jam then it's probably a carriage jam:
However, I'm not too familiar with clearing a carriage jam. I just know that if your cartridges are not blocked then the carriage is likely at fault. You will need to Google this on how to fix a carriage jam.
Jan 24, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I turned my printer on and it said open door. clear cariage jam then press enter what is that?
Hi and welcome to FixYa,
with the indulgence of mackenzie123...
A 'Carriage Jam" error indicates that the holder of the ink cartridges (called carriage) which includes the print head cannot move or complete its sideways movement. Three (3) possibilities:
  • it is really jammed. Paper debris is blocking its path and therefore must be cleaned;
  • the guide rod / rail has lost / dried up its lubricant and therefore the carriage could not move easily. The guide rod/rail as the name implies is the provides the path of motion;
  • ink smears on the encoder strip. The encoder strip is the long narrow plastic with barcode like markings. This tells the carriage where it is. An ink smear would block the markings and confuses the carriage.
Hope that this be of initial help/idea. Good luck and thank you for using FixYa..
Apr 19, 2009 | HP PSC 2210 All-In-One InkJet Printer
My printer is a hp6210 and the error I am getting is carriage jam, open door clear carriage and press ok
The carriage is what holds the ink cartridges. If you open that and make sure that there is nothing that is blocking the carriage from moving. If there is remove it. If the machine is powered off you should be able to slide the carriage by hand back and forth along the metal shaft that it rides on. If it feels like it is sticking you can wipe the shaft off with a clean lint free cloth. DO NOT add and oil to the shaft. Power the machine back on and it should work. If it still errors out you will probably have to bring it to a repair place.
Hope this helps
Dec 04, 2008 | HP Office Equipment & Supplies
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
90 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
