Need to access network printer
I have a Canon Pixma Printer hooked up to my desktop computer. My desktop has a Linksys Router hooked to it which I use for my laptop and a second PC. I would like to use the printer with my laptop and second PC but don't know the steps to take to make it work. I did see a question that was similar to mine, but all it says was to hook an ethernet cable to the router. I'm afraid that I need more desriptive directions. Help if you can....Thanks.
  • 600 Answers
First you need to have all pc conected to the router via a "network " cable aka " CAT5" then, if you running windows goto control panel> network set-up wizard and follow the prompts and you"ll be on your way
Posted on Apr 23, 2009
Can i hook up my printer to my wireless router and if i can how do i tell it to print when i need it to print
The iP6310D can't connect to the wireless router directly. It has a USB port and an optional blue-tooth receiver.
If you connect the printer to one computer, you may be able to share it using that computer as a server. Install the printer software on all of the machines. For the software, see http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip6310d#DriversAndSoftware . For Windows 7 and 8, if you set up a Homegroup, enable sharing for the printer on the computer that it is directly connected to. Then use Add a Printer command from the Devices and Printers Control Panel option to locate networked printers. For other OS options, you'll need to make sure that the computers are in the same workgroup. (See the Network set-up information.) Then add a network printer.
If your wireless router has a USB port, you may be able to connect the printer to the router. Again install the printer software on each computer. Then use the router's software to add a printer on the computer. (For Linksys routers, that is the Cisco Connect software. Some routers may not offer this software for all OS's or for all printers.)
A similar option is a print server connected to the USB port of the printer. You will need to check the specifications for each one. There are some that only work on select printers.
Once the software (the printer driver and then the network software/shared printer is set up), then any program should be able to print following the File > Print command.
Please add a comment with your OS and/or router model, I'll try to walk you through setting up a shared printer or a USB connection on the router.
(Note: I have a USB printer connected and a wired network printer to a Cisco router. My only issue is that I get a printer error with every print job. The printers print the documents anyway. The error is due to the printers not responding to the software as fast as if it were a direct connection.)
Aug 10, 2013 | Canon PIXMA iP6310D InkJet Photo Printer
I have my Canon MX420 printer hooked up, my computer recognizes it's existence, and the printer prints fine by itself. However, every time I try to print from my computer via wi-fi, my computer says...
If your printer has the network cable plugged into it then your halfway there. Make sure that as well as having a hard line network cable plugged into your router, you need to connect the printer to the wifi signal as well. On your printer, push your settings button, scroll to your wireless lan setup, and connect to your router and if password protected, enter in the password and you should then be connected to you router, now try printing using your laptop or device through your wireless connection, and it should print. Please post back if you need further instructions or help!
Aug 24, 2011 | Canon Pixma MX420 All-In-One Printer
Is it possible to set up the printer for wireless printing?
This is not a wireless printer, however, you can create a wireless envirnoment by using a wireless router or a wireless printer server router. Linksys and others carry the routers for around $40.00. You would hook the printer directly to that router and the router would have an IP address that all wireless devices could see.
Good Luck.
Mark
Nov 29, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I am trying to connect a lap top with a printer connected to the desktop. When the makes of Canon printers are displayed there is no PIXMA MP600. I have a wireless router and have both connected to the...
In able to access the printer, your option is to get it access over your network. You must setup a home networking and make sure that both computer sees each other, and File and Printer Sharing was enable to both computers.
Hope this helps.
Let me know for any clarification on networking issue,
Sep 30, 2009 | Canon Office Equipment & Supplies
Hooking a Linksys wireless router and SpeedStream router together
Connection should be from LAN port of Speedstream going to Internet port of Linksys router. That should be it.
Oct 25, 2008 | Computers & Internet
Access denied to network to laptop
Disable all firewalls, both on laptop and on computer that shares the printer.
Ensure that laptop and desktop sharing the printer are both on same Domain or Workgroup.
If this does not fix it, call back the Geeks and thell them to acces the router configuration, and configure router internal firewall.
Put both laptop IP and computer sharing printer IP in the range of thrusted IP on router settings.
Sep 08, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Can you recommend a router?
I have a Cable modem SBV5222 Surfboard from Motorola and I think my Linksys G router might not be compatible,can you help me with any suggestions as which kind of router will be more ideal to go wireless?
Jul 30, 2008 | Linksys Wireless-G Broadband Router
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
