Question about Amana ARB2217C Bottom Freezer Refrigerator
No cold in fridge or freezer: buzzing compressor
I have an Amana ARB2217CSL. Neither the refrigerator or freezer gets cold at all. Every three minutes, the compressor clicks on, buzzes very loudly for 30-45 seconds, then clicks off. Based on other posts/responses I've read, it appears to be: (1) faulty compressor, (2) faulty starter motor, (3) faulty start capacitor, or (4) faulty relay/overload. I have two questions: FIRST, it *appears* (I'm not a fridge expert) that the relay/overload is attached to the "start capacitor" as one unit on my fridge model (parts listed on www.repairclinic.com seems to confirm this). I assume the start capacitor is NOT the start motor. Should I replace both the relay/overload with start capacitor AND the start motor? SECOND, I cannot find a separate "start motor" on my unit. Must the whole compressor be replaced if the start motor is bad, i.e., is the start motor for the compressor enclosed within the compressor unit itself? Please provide *very detailed and clear* suggestions as to what parts I need to replace. Thanks in advance.
  • 1 more comment
  • jalioto Sep 24, 2007
    I forgot to add that the fan works fine.
  • jalioto Oct 29, 2007
    I replaced the overload relay.  It worked.  For about a month.  The compressor needs to be replaced.
  • jt42 Nov 27, 2007
    I have an Amana ABB2223DES Top/Bottom Refrigerator/Freezer which is three years old. It has the same problem described by Jalioto, a buzzing noize that lasts 30 seconds or so, followed by a click. It seemed to be worse last night, happening every three-four minutes. Sure enough, we came down this morning to find the freezer/fridge had stopped working and were no longer cold. But at least the buzzing/clicking was still going!
  • 473 Answers
There is no start motor. If the brand of the compressor is a tecumpseh then it is most likely the problem and has a 5 yr warranty from the date of purchase. If it is an Embraco compressor I would try and overload and relay. They are all in one part sometimes called a start device.
Posted on Oct 05, 2007
SOURCE:
I have an Amana fridge model number abb2224dew. The compressor is very hot and the relay/capacitor is buzzing/clicking. The compressor will not startup. What is causing the compressor to heat up and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
I have an Amana ARB2217CSL. The freezer is working fine, but the refrigerator section is no longer staying cold.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 09, 2011 | Amana ARB2217CSL Bottom Freezer...
My 1999 TX18 Amana Top Freezer/ Fridge won't get cold. I cleaned it, plugged it in. The light and fan work and it stayed cold for 4 days but it won't get cold.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Apr 03, 2011 | Amana Refrigerators
I have the Amana ARB220ZCS fridge and yesterday it just stopped working. This light is sill on but it is not getting cold, the fridge or the freezer. Thanks James
heatman101
Mar 20, 2011 | Amana ARB220ZCS Bottom Freezer...
Freezer and fridge not cold. Sounds like relay is attempting to work as it buzzes. I have replaced the relay/capacitor, same buzz.
I'm sorry, but that is very bad news...
If you have changed those parts and are still getting the buzz then the compressor has locked up and is not fixable...
You will have to replace the compressor or junk it and buy new...
wish I could give you better news...
heatman101
Nov 28, 2010 | Amana ABB1927DE Bottom Freezer...
I have a amana bc20tw fridge with bottom freezer that is keeping cold in the freezer and cool (43 degrees) in the fridge. I checked the coils in the freezer and there is no ice or major frost. Also, the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 15, 2010 | Amana ABB1927DE Bottom Freezer...
Problem with the Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Clicking, buzzing, compressor too hot, thawed out freezer, fridge is semi cool
heatman101
Oct 10, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Not getting cold
heatman101
Sep 05, 2010 | Amana ARB2217CSL Bottom Freezer...
Amana side by side, buzzing, no fan in fridge.
that sound is the relay/overload. it is trying to start the compressor. the problem is either that relay or the compressor itself
Feb 05, 2010 | Refrigerators
Refrig is not cooling
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Jul 01, 2009 | Amana ARB2217CSL Bottom Freezer...
Amana ARB2217C Bottom Freezer Refrigerator Logo
830 people viewed this question
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
