Question about Baby Lock Eclipse Serger
Foot control gets very hot
I just bought a used serger. The foot control gets very hot after using for a little while. It gets almost as hot as a kettle. Is this normal? If notl, what is wrong with it? Thanks.
I have the same problem but on a 98 avenger 420a foot area gets hot like if tranny heat or engine goes in even during cold days
Posted on Jul 27, 2009
  • 65 Answers
You need a new foot control.
Posted on Apr 23, 2009
We have a new Janome New Home Serger The Handwheel will not turn; speed controller will not move needle. We would usually take it back to the dealer, but we have moved out of country
Have you tried turning the handwheel and using the foot control at the same time just to get it moving if its humming when you put your foot down its trying to go sometimes a little help to get it going helps it might need some oil or its got a dry spot from being stored give it a go and let me know how you got on. Ron
Dec 14, 2017 | Janome Sewing Machines
I the regular needle plate and presser foot
are you saying you need a presser foot and needle plate for a serger,, if that what you need, try these sites for the parts
sewvacdoctor.com
sewingpartsonline.com
Feb 18, 2016 | Sewing Machines
Serger is not stitching
... not quite sure what you mean by "not stitching", here are a few things to check. If the problem is more specific, please leave me a note with more details.
Let's start right from the beginning (for 4-thread overlock/serge):
1. According to the serger manual, ensure that the proper needles are being used. That they are inserted all the way up into their positions and that the flat side of the needle is facing away from you. The left needle will appear to be shorter that the right, that is OK, all is going perfectly.
2. Use four good quality spool of serger thread (good quality sewing thread is fine also) and place them on the spool or cone holders. There should be "little bucket looking things" that fit onto the cone pins to make the cones sit nice and straight, use them. Rattling thread will cause grief.
3. The first thread to be loaded onto the serger is the Upper Looper ...it is the big needle looking thing that swings left to right and back again above the sewing surface. Follow all the threading guided according to your manual, the threading guides are generally coded in a colour specific for this looper. Once the eye of the Upper Looper is threaded, place the thread under the presser foot and to the left. Presser foot down.
4. Next is the Lower Looper, the big needle looking thing that swings left to right and back again under the sewing surface. It can be a bit tricky in some sergers as the thread need to pass to the left and then back to the right under the sewing surface. Your manual should have a good diagram if you can not follow the threading guides on the serger itself. Again the threading guides are generally colour coded with a different colour but specific for the Lower Looper. Once the looper is threaded, it is important that the thread is placed directly OVER the Upper Looper as it comes out of the eye of the Lower Looper. Place the thread now under the presser foot and to the left. Presser foot down.
5. Thread the right needle front to back and place the thread under the presser foot and to the left. Presser foot down.
6 Thread the left needle front to back and place the thread under the presser foot and to the left. Presser foot down.
7. Hold the four thread ends firmly in the left hand and give each thread individually a good pull down over the serger and behind, this will ensure that the threads are all engaged in the tension dials.
8. Set the tensions to the middle number, although this may vary with the brand and model of your serger. If you have the manual check for the correct settings specific to your unit.
9. Set differential to 'normal', or '0' (if your unit has one)
10. Set stitch length to about 2 1/2 to 3.
11. Make sure that the blade is in cutting position. We can trouble shoot blade position later if needed.
12. Make sure that you have the overlocking plate installed ... not the rolled hem plate (if your serger has two plates). Some sergers use the same plate for both functions.
13. Using two layers of medium weight fabric do a test stitch, what is the result? Is a chain forming? Are there stitches on the fabric? Are they looking the way they should?
Hopefully this has helped you, please let me know.
Cheers.
Sep 01, 2014 | Sewing Machines
Bl4-736d serger foot control very hot and speed of machine slow to stop
sounds like the foot control needs to be replaced.
Jan 24, 2013 | Sewing Machines
I have a Elna Pro 945 serger. I would like to use the piping foot #396013-82 however I don't have the directions on how to use the foot. Please let me know where I can get directions., Thank you Greta
try this link http://www.youtube.com/watch?v=bC-bJE5zwzw&feature=related for movie of a Pfaff piping foot in action, the principal would be similar, you are wrapping bias strip around cording on left of foot and overlocking right side. You can also do this with fabric top and botton thereby inserting the piping as you make it.
I have not tried this technique myself as I've only bought a blind hem foot for my Bernina but must admit I have used that a bit in the past.
Most serging techiques are very similar across the brands.
Mar 03, 2011 | Elna 945 Computerized Sewing Machine
Lost the foot pedal and cord to my Hobbylock serger 796 made for Pfaff. where can I purchase another one?\r\n Thanks, Charlotte
Here's a link to the Google froogle search results, they are a little pricey though... You might find a cheaper one in your area by calling around and asking for a used one.
http://www.google.com/products?q=796+foot+control+pfaff&hl=en&aq=f
-Chirs
Jun 13, 2010 | PfaFF Hobby 4260
I've just got janome 634d serger, how can i make the bottom of a T-shirt ? Thank you so much
If you want the bottom of the T to look like RTW with the double row of stitching, you cannot do this on a serger.
You can achieve the effect by using a twin needle, two spools of thread, bobbin and a straight stitch.
Make sure the double/twin needle will pass through the presser foot and opening in the needle plate below the presser foot.
Practice on a double layer of a scrap of the T shirt material as the tension may need to be slightly looser than the normal setting.
Apr 05, 2010 | Janome MyLock 634D Mechanical Sewing...
Don't know how to thread the juki mo-735 serger
This video starts off a little ****, but expected if you have ever visited the Threadbanger site - http://www.metacafe.com/watch/1462325/how_to_use_a_serger_indie_pendent_designer_spotlight_thread_he/ Not your brand, but the same "serger basics". Lift the antenna to it's highest position. Set the tensions to zero. Have the presser foot up when threading. Raise the upper looper to it's highest position. Sergers are great little machines, but they can be nerve racking when it comes to threading. After years of threatening my old FunLock, I bought a Babylock Imagine with air-jet threading - what a relief!
Mar 12, 2010 | Juki MO-735 Mechanical Sewing Machine
Sewing Machines Logo
123 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
