Question about Fisher and Paykel GWL11 Top Load Washer
No cold water regardless of setting
I moved my washing machine for a few days to do some work on the basement and after hooking it back up, the washer temperature sensor (?) seems to be off as it only will use hot water regardless of the setting. I checked the hook up and confirmed that the cold water is on and hooked up properly. Any idea what this could be? Thanks!
  • prayiigod Sep 01, 2008
    When the temp of the washer is set on cold the water only comes out either warm or hot.
  • 70 Answers
Hi, you will need to replace the cold valve in the washing machine. :)
Posted on Sep 09, 2008
    Novelist:
    Champion:
  • 244 Answers
2 things it can be if your water pipe were you connect the hose too under the sink has a plastic turn handle to switch the water back on then it is most likely that it has sheard inside it undue the screw that holds it on pull the plastic cover off and with pliers turn until you hear the wate rcome through if not then it will be the solenoid inside your washer that has become faulty were the pipe connects to m8
Posted on Sep 24, 2007
Can I hook the wash and rinse to cold water hose?
Not sure what you are asking. If you want to wash and rinse you clothes in cold water only, there should be a water temp selection switch to allow you to do that. If you are asking if you can hook cold water hose to both ports on the washer back the answer is yes but it is easier to just cap off the hot side of the water valve on the back of the machine. Most machine water inlet valves are a 3/4 thread garden hose connection. Go to a hardware store or a Lowes/ Homedepot and ask for a screw on cap. They come in both plastic and brass. If you do cap the hot side of the inlet valve, make sure your washer has a cold only setting for wash and rinse and keep it set there. If it gets moved to hot nothing will fill or run.
Apr 15, 2015 | Washing Machines
Can neighbor use washer using cold water hook-up only?
Good day,
Yes if cold wash and rinse are used only. If the selector is set to warm accidentally, water would fly out of the hot water port when filling. Be careful, or hook up another cold water supply to the hot inlet.
Nov 01, 2010 | Maytag LAT3600A Top Load Washer
Warm water filling up washer, with no hot water hooked up to wash
exactly
it will maintain 60 degrees but cycling hot cold
thermistor
Sep 29, 2009 | Maytag Performa PAV2200
Washer was working fine! Moved washer to new house, and now it will run but only with hot water. put washer on Auto controll, and cold cold or warm cold setting, and it wont even turn on.
Have you tried checking your cold water supply faucet? Are you sure there is cold water running out of that faucet before you hooked up the hose? Is it possible there is a shut off on the supply valve that isn't turned on? Therefore it will not run on cold water setting? This actually happened to me once. We went away for a week and turned the water off for the hot and cold supplys. Came back to do laundry and only turned the hot one on and not the cold. Good luck!
Aug 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag performa washer hot/cold now reversed
Try moving hot hose to the cold side and c old hose to hot side on supply side. this should correct your problem
Feb 26, 2018 | Maytag Performa PAV2200
New WTW5700SW clothes washer. 1 week old. Worked great for 1 week. Temperature control problem. The cold setting provides hot water. The warm and hot setting provide cold water. The warm setting...
the temp thermister in the control panel is bad, lowes has a 30 day return policy if they delivered it have them bring you a new one, if you picked it up take it back, get a new one no need in starting out with an new almost out of the box washe with problems
Apr 13, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
73 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
