Question about Magellan Roadmate 1200 Car GPS Receiver
SD card is not detected.
My Roadmate 1200 is telling me that the sd card is not detected, when it was earlier.
  • Anonymous Apr 23, 2009
    It does not have SD card slot while it says it has. It does not have charging indicator and you can`t tell if it is being charged or not and if charge is complete. It does not prompt name of the streets!
    Overall it is incomplete item.
3 Suggested Answers
  • 6 Answers
SOURCE: Where can I download free maps for my Magelllan RoadMate 1200?
go here //downloadanystuff.org/ put your download query and search
Posted on Jun 08, 2009
stephen_sher
  • 6 Answers
SOURCE: magellan roadmate sd card error
I had a similar error and I fixed it. That is, as far as I know...
Here's my theory: The SD card is acting like it has an error on it. This often happens when it is removed improperly.
HERE'S HOW TO FIX IT:
  1. Remove your SD card from your GPS
  2. Insert your SD card into an SD card reader or connect it to your PC
  3. Wait for windows to go through it's process of discovering your the "removable storage device" your just connected (see step 2)
  4. (This step may be different depending on what version of Windows you are using or depending on how you have your OS laid out). Look at the lower right hand corner of your desktop. There should me a small icon there with a green circle and a check mark. It looks like this...877f33f.jpg
  5. Click that with the right mouse button.
  6. It will say "Safely Remove Hardware" - Left click that message.
  7. A window will pop up allowing you to select your SD card and "Safely Remove" it (it will have a letter name like "drive F" for example).
  8. Wait for the windows to tell you it is ok to remove your hardware - then remove your SD card form the PC
  9. Make sure your GPS is turned off.
  10. Insert the SD card into your GPS.
  11. Turn on your GPS
  12. That's all! I hope I was able to help.
IF THIS HELPED, please leave a comment indicating that it did! If it did not help, please let me know that as well.
Posted on Jul 17, 2009
While using my Magellian GPS 1200 the screen froze up and when I went to restart it the following messang appeard.SD card has been removed.Program will restart.Please insert SD card with map. I tried re...
More then likely when the screen froze up on you it it had a little power glitch as well, nothing serious but it did wipe out some of the information in it's memory about the SD card.Power the unit up and let it come up with the error, then use the reset button. Might be hard to find since it's just a little hole with the word reset around it, using a paperclip push in the button and see what happens. If the error comes up again then i am thinking that you will need a new SD card. Quick test for this, remove the SD card from the gps unit and try rebooting, it should come up with an error, no SD card or no map, stick in an SD card from another device, 2gb, see if the gps can find the card, it should give you an error that says unable to find maps. If you get these error codes then most likely the gps unit is fine but it pooched your programs on the SD card.
Hope this helps
Apr 27, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Won't work "sd card has been removed" shown on screen
It is looking for the map file on the sd card. Usually you can just go in the config menu and tell it to use the internal map (if this model has it). It may not be as detailed as what was on the sd card but will get you around.
If the SD is still in the unit the SD may have failed or become corrupted.
Apr 01, 2010 | Magellan RoadMate 1412 Car GPS Receiver
Update for Magellan RoadMate 1200
when driving after approx. 1 hour. I get an error message that says my SD card has been removed. Any suggestions?
Jan 20, 2010 | Magellan Roadmate 1200 Car GPS Receiver
I lost my sd card how can i get another one
The SD cards are one of the most common memory card formats. You can buy them in any large department store or electronics outlets. If the original card had pre-installed factory software on the card, your GPS may still not work so check with Magellan first to see if that is the case.
Nov 09, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Magellan roadmate 1412 just stop working and displayed the following messange: "SD card has been removed. Program will restart. Please insert SD Card with map"
Providing you saved the SD card info as soon as you got it, reformat the SD card and copy the files over. Or find a friend that has the same unit and copy their files. Reformat your card before also.
Oct 02, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Magellan roadmate sd card error
Jun 02, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Missing SD Map Card on Magellan Roadmate 1212
Unfortunately even if you do find a card it will not work with your unit because the cards have to be for that unit.If it is from another unit the codes will not allow it to work. The only option I know of is to purchase your map for that unit and put it on a sd card
May 09, 2009 | Magellan RoadMateā„¢ 1212 Car GPS Receiver
Roadmate 300
P/N for the full coverage map SD card is 600369. That's what I have and it works no problems.
Mar 19, 2008 | Magellan RoadMate 300 GPS Receiver
Magellan Roadmate 1200 Car GPS Receiver Logo
129 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
