=-=-=-=-=-=-=-=-=-=-= = One thing you need first = =-=-=-=-=-=-=-=-=-=-= Bluetooth capable phone [that supports bluetooth dialing]: Not all phones do this, even the ones with Bluetooth. My Motorola V551 worked fine with bluetooth dialing. My new Samsung does not, even though the palm and the phone recognize each other. With my Samsung, I can only send and receive contact info. So say you have a BT phone that supports BT diailing... ===setup your phone and palm=== In Palm Applications goto Preferences select Bluetooth Ensure BT is on and that your Palm is Discoverable and has a Name Select "Setup Devices" Select "Phone Setup" Select "Phone Connection" Follow through the setup guide and you should be nearly set. Once complete, exit back to Applications ==dial a contact== goto Contacts (or press the contacts button) select a contact so you see the contacts vCard info on screen at the top center of the screen select the palm icon. select the number for quick connect. you should then be in business
Posted on Sep 24, 2007
Jul 10, 2011 | Palm Treo 650 Smartphone
contact in the Palm Profile account, which does not synchronize with an online account but is backed up daily to your Palm Profile. If you are using Contacts for the first time, you go through a few different steps to get or access the contacts on your phone (see Using Contacts for the first time ). Follow this procedure to add contacts directly on your phone after the first time you use Contacts. 1. Open Contacts . 2. Tap . 3. (Optional) Tap the account button to the right of Name to change the account to which the new contact will be added. 4. Tap fields to enter contact details, select a ringtone for that contact, add notes, or add birthday details for the contact. Scroll to see all of the fields available for contact info. 5. In some fields, such as New Phone Number, when you enter the information a label button appears on the right. Tap the button to change the label for your entry-for example, to identify a number as a mobile or work phone. Tip Use the Reminder field to enter that important message or question you have for this contact. The next time you send or receive a call or a message to or from the contact on your phone, the reminder pops up on the screen. You can also add a reminder later (see Assigning a reminder message to a contact). Tip To insert a two-second pause in the dialing sequence, enter a T where you want the pause to appear. To insert a stop in the dialing sequence, enter a P where you want the stop to appear; to dial the next set of numbers after the stop, tap the screen. 6. Tap Done.
Oct 24, 2010 | Palm Pixi Cell Phone
May 04, 2010 | Sprint Palm Centro Smartphone
Oct 30, 2009 | Palm Treo 700w Smartphone
Mar 18, 2009 | Palm Treo 680 Smartphone
Oct 16, 2008 | Palm Treo 500 Centro
Jun 04, 2008 | Palm Treo 750 Smartphone
Feb 05, 2008 | Palm Treo 700w Smartphone
Dec 30, 2007 | Palm Treo 750 Smartphone
Nov 03, 2007 | Nokia 3230
Feb 27, 2014 | Palm TX Handheld
190 people viewed this question
