Question about Kenmore 24032\24036 Top Load Washer
F51 code does note finish washing f51 code
  • 107 Answers
From experience, I know this is an Oasis. F-51 can be caused by a fauly main control, a bad wiring harness or something stuck between the basket and tub. There is a recall going on with these, you might want to look into.
Posted on Apr 23, 2009
What does an error code F51 on a whirlpool cabrio washer mean?
Cabrio F51 Fault (Stored Fault Code F51) The Cabrio's F51 fault code flashes on the washing machine's display when there is a motor rotor position sensor (RPS) failure.
Check for good contact at the control Board and at the RPS. Sometimes disconnecting and reconnecting the RPS plug connection several times will clean off corrosion that may be affecting the contacts.
Here is an earlier Fixya answer addressing the query:
Whirlpool cabrio error code f51 what does it mean
Sensor is item 20 below. Clean it.
Nov 27, 2017 | Whirlpool Washing Machines
Miele washing machine W3725 is coming up with Technical fault F51 ?
F51: Pressure Sensor
Symptom
In the operating mode, the display indicates Technical fault.
The program is stopped, the water intake valve is closed, and the drain pump is
switched on for 120 seconds.
Cause
Electrical defect in analog pressure sensor (ADS). The values are out of range.
x
Note
The pressure sensor is integrated into the power/program electronic (ELP)
This will usually require a professional to repair.
Dec 10, 2016 | Miele Washing Machines
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool washing machine - F51 code
F51 - This is a motor Rotation Positioning Sensor failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Sep 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
IT SAYS F51 ON THE DISPLAY IT DOES NOT LET MY WASHING CYCLE FINISH
You have the F51 code. The reason could be due to an intermittent connection at the rotor position sensor (RPS). To correct this, remove and install the the connector at the rotor position sensor (plug and unplug) at least three times to clean off any corrosion build up on the connector or the rotor position sensor due to the intermittent connection.
Confirm that the connector is fully seated onto the rotor position sensor upon final connection and verify that there are no damaged wires. The electronic control unit may have to be replaced, since the upgraded version is less sensitive to intermittent RPS connections.
Sure hope this helps you and best wishes.
Aug 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 24032\24036 Top Load Washer Logo
135 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
