Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Spring on bottom wheels eureka altima
Trying to find a picture of where to attach springs on the bottom wheels
  • 281 Answers
Look up inside where the wheels go and you will see a open notch clip the spring in there and on the wheel assembly itself oon the inside you will see a holeclip the other end of the spring to that .your done
Posted on Apr 23, 2009
I took apart my Eureka 71B hand held vacuum and a small spring fell out. I don't know where it goes and can't find a manual anywhere. Help?
Lonny,
I have a 71-B2 model myself and if you can take a picture of the spring, I can try to take mine apart and see if I can figure out where your spring goes and get back with you.
Aug 09, 2015 | Eureka 71B Easy Clean Hand Vacuum Yellow
The wheels with the spring broke off and I'm trying to put a new one on but I don't know where the spring goes.
This spring can be very confusing to install. It slides onto the wheel assembly near where the attaching pin is longer ( there are flat protrusions on both sides of the wheel assembly). One end of the spring pushes up on the assembly when it is in place, and the free end must be pulled down and inserted into the small slot in the bottom of the base. Pull down on the shorter end of the spring, holding the longer end, and slide it onto the round area on the wheel assembly. As you put the wheels back on, pull on the longer end and insert it into the slot in the base.
Jan 24, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Eureka model 4870DT plastic foot pedal for is broken
This a fairly frequent repair on the Eureka Smart Vac model 4870, so I decided to go ahead and take a few pictures of the handle release pedal repair, and walk you through this step by step. The model that I did the repair on is a slightly newer model, but other then maybe the color of the vacuum, or the color of the foot release pedal, the repair is identical. $40 is an awful lot of money to do this repair, after it's all done with you'll be very happy that you choose to post this repair on Fixya, rather then paying $40 for someone else to fix it.
What you'll need to complete this repair. The links contained in the parts are links to the parts on our website, GoVacuum if you don't already have the new pedal.
- Eureka Smart Vac Model 4870 Handle Release Pedal (colors may vary, but will fit ALL 4870 models) Eureka Part 70042-355N
- Eureka Smart Vac Model 4870 Handle Release Spring (Only needed if missing underneath of old pedal)
- Large Flat Head Screwdriver
- A small amount of elbow grease. :-)
Step 1. Remove the old handle release pedal from the base of the Eureka Smart Vac if it hasn't already fallen out of the base of the vacuum. Here's what the pedal looks like installed in the base:
The easiest way to remove the old pedal if it's still inside of the base of the machine, is to take a larger sized flat head screw driver, and put it up underneath of the pedal. With the screwdriver underneath of the pedal, pry upwards on the pedal until it pops off. This can take some pressure to get it out, don't put too much pressure on this part or it will crack the bottom housing. If the pedal won't come out from the bottom, you may also try putting the screwdriver in between the top housing (different colored plastic part in front of the pedal) and the pedal and try prying here. I find it the easiest to do when I put the screw driver underneath and pry upwards like this:
Step 2. Once you've removed the pedal from the base of the vacuum cleaner, make sure that the spring is still inside the base. The spring is a metal torsion part that pushes upwards on the pedal to keep it from always falling out of the vacuum cleaner. I have highlighted the spring in this picture in red:
Step 3. If the spring is still installed, you're now ok to put the new pedal on. You'll see on one side of the pedal that the notch that locks the machine in the upright position, as well as on the bottom part of the pedal that part of the pedal that connects into the lowest part of the base that has two little circular notches that protrude out. This part of the pedal goes on the side closest to the vacuum cleaner's upright body. There's really one way the pedal will go into the vacuum. Put the pedal over top of the metal spring, and push down on the pedal as far as it will go. I find that a few GENTLE hits with a hammer on the top of the pedal will gently slide the pedal into the correct part of the lower base:
Step 5. Test the pedal by stepping on it to make sure that the handle release when you're stepping on the pedal. Also make sure the vacuum will lay flat on the floor when you step on the pedal a second time. Now raise the handle into the upright position and make sure that the machine locks itself in the upright position. If yes, then you're all set! If it's not locking, then there may be a more serious problem of the lower base part being cracked, which will not allow the pedal to sit properly. If this is the case, please just reply to this repair, or start a new repair with that problem, and I'll be happy to show you how to fix this. If this repair was helpful to you, (it seems that it saved you $40!) please be so kind and rate my repair helpful by clicking on the 4 thumbs up icons in the top corner of the repair. I really do appreciate that. We do carry most every part for your vacuum on our website, please feel free to check out our site, Govacuum.com for all of your Eureka vacuuming needs!
Thank you,
Chris J.
GoVacuum
Apr 07, 2010 | Eureka Smart 4870DT Bagged Upright Vacuum
Eureka Upright Vacuum 4230 Series. Spring popped off on height adjustment knob. Where does it go and how do I put it back on?
sure would like to know that answer myself does anyone know how to put the spring back i am about to lose my ever loving mind
Apr 04, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
My front wheels fell off how do I fix it. there is a slender long spring and I don't know where it goes
That spring connects to a slot beside the height adjuster knob and a hole in the base to the wheels that fell off.The problem is you can't get the wheels to go back in flush so the height adjustment works.The vacuum will not be close enough to the floor to get any type up suction or brush contact.To change that spring as well as the belt,remove the cover by taking out two screws,one on each side.Force the rller out by prying the right end out of the slot.
Feb 23, 2010 | Eureka 2997AZ Bagless Upright Vacuum
I am looking repair parts for the C2094G
go to abcvacuum.com they should have the parts you need. If they don't i am sure they can tell you where to go.
Jul 28, 2009 | Eureka C2094G Vacuum
Metal Spring in Belt area?
Yes the metal spring is used to pivot one of the rollers in that area.
You would need to take it apart one more time and check to see if any of the roller travel up or down while you press it with your fingers. look to the edge on either side for a place to attach the end of a spring. then a place on the chassis to add the other end of the spring. Then redo the belt.
May 24, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Spring connecting height adjustment
There should be a place easily for the wheel assy to fit back in and then if you look you should see 2 small holes in the bottom of the vacuum that it will slip into. If your looking at the vacuum straight they should be on the left side on the bottom.
Nov 14, 2008 | Vacuums
Eureka 411B Upright Vacuum
It goes in a slot beside the right wheel. It is a detent for the hinge. Metal spring first and then the nylon piece round edge up.
Nov 14, 2008 | Eureka 411A Upright Vacuum
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
204 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
