Question about Hitachi 43UWX10B 43" Rear Projection Television
Hitachi 43fdx01b convergence problem
The picture is purple and green outlined on left bottom also slight focus problem what can i do my self to correct where is the convergence board located and can i buy one ?and also is there any directions how to adjust and repair? thank you
  • Hitachi Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are details for both issues. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
e87380c.jpg69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picturehitachi 43fdx01b convergence problem - 578ba6c.jpget that needs the fluid changed.
TV set hitachi 43fdx01b convergence problem - 69189a5.png change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 19, 2011
    Genius:
  • 1,694 Answers
Have a professional replace convergence output Ic's and re-adjust.PCB replacement not necessary.
Posted on Sep 24, 2007
SOURCE:
There are green and red waves on the top and bottom of my screen and the shapes in the picture are distorted. This is on a Hitachi 43FDX01B
Ur convergence it dead.U know how to solders?Buy a convergence kit at Tv repair World.com,Tvrepairkits.com.Replaced 2 convergence ICS,and all it resistors.Shop will cost u $300 for parts and labors.
Jan 27, 2010 | Hitachi 43FDX01B TV
Hitachi UltraScan HD Projection Screen 43FDX01B
The convergence board is on the fritz! See TVRepairKits.com and see if they have a kit just right for you!
Jan 12, 2010 | Hitachi 43FDX01B TV
Red and green waves...double vision ...how old...how valueble...hitachi 43FDX01B
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Hitachi 43FDX01B TV
Tv's picture is messed up.
Symptom: Blue convergence off, bowed inward at the top and bottom with No blue vert movement.
Cause: Replace IK05 (STK392-110) and RK54 (1.5 ohm/1W) and converge. RK50(2.2 ohm/1W)
Sep 20, 2009 | Hitachi 43FDX01B TV
Hitachi 43FDX01B green is out of whack
The green is not adjustable in the customer menu because it is considered the 'master' color. It is adjustable in the technician mode however but if it is curved it won't even adjust properly that way either. The problem is the convergence ampifier responsible for green convergence has failed. The convergence output IC's need to be replaced.
May 27, 2009 | Hitachi 43FDX01B TV
Purple/Green Outline surrounding picture
I have seen two different things cause this. The first and most common is the electrical failure of one or both convergence IC's. A handful of times, the data in the DCU became corrupted and I was able to enter the service mode, go to manual convergence and correct the one location that was off.
Apr 28, 2009 | Toshiba 50HDX82 50" Rear Projection...
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is [email protected] thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Convergence IC's must be changed to start repair..original...
STK392-110 sub to Hitachi upgrade STK394-160E.....PART #
CZ 01341...you need two....
Next, take a critical look at the B+ feed resistors near the IC's..
check for over-heat / damage......usually 2.2 ohm 2 watt......
Let me know....................T.
Jan 03, 2008 | Hitachi 43FDX01B TV
Hitachi 43UWX10B 43" Rear Projection Television Logo
113 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
