When pressing the up down button, its hard to change the channel unless you continue to hold it very firmly.
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Automatically finds all channels available through antenna or cable inputs, and stores them in memory on the channel list.
- Run EZ Scan again after any Antenna/Cable connection changes.
- A password is required to gain access to EZ Scan menu if the Lock System is turned on.
1. Press the MENU button and then use UP/DOWN button to select the SETUP menu.
2. Press the FORWARD => button and then use UP/DOWN button to select EZ Scan.
3. Press the ENTER button to begin the channel search.
Allow EZ Scan to complete the channel search cycle for ANTENNA, and CABLE
ok.
