Back to:
Tags:
Brother MFC-8440 All-In-One Laser Printer
Loud ratchet noise when turning printer on....I... (by 2 users)
posted by CSRfool on Sep 24, 2007
I am unable to use printer. I have cleared the front, back and paper tray of any "jams", but I think that tiny little pieces of torn-off paper is is the rollers and preventing the machine to work. Of course, 1 year and 3 months...so should I somehow unscrew the plate in the front and see if I can get at it to solve the problem? I do a lot of printing, faxing, scanning...but my work software requires parallel print.....thus the MFC, which has capabilities for both USB and parallel. The Brother jams a lot, I remove the paper, and go on. It might be that I have the paper setting wrong, or it just could be using or reusing paper for draft copies.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by batchee, posted on Jul 22, 2008
I'm not as far along. Once the printer starts up as it's receiving a job, it will make a grinding noise. It pulls the paper through but jams. What is the problem and how can I fix it?
Best Solution
posted on Nov 15, 2007
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The problem is a broken gear. Part number LJ7416001.
It is in the fuser assembly.
To remove:
Looking at the back of the laser, you will see a flat "platform" going across under flipdown access door. There is a screw in the middle of it. Remove it with a philips screwdriver, and slide the plastic platform out.
pull the door downward to about a 45 degree angle or so, and it will slide off a pair of flat retaining pins. One on each side. These are part of a molded plastic piece. Each piece is held on by two screws. Remove those. The plastic pieces come out:
NOTE: there is a hook on the bottom of each piece that hooks into the metal frame. The hook faces down. DON"T break them off. The plastic needs to move up and out. After removing the two pieces of plastic, you will see a metal enclosure on the right side of the printer, with two phone jacks in it. It is held on with 2 screws. Remove them and swing it out of the way. Behind it is another large philips screw. Remove that. On the other end of the fuser is another screw. This one has a slot in it, and a small cross slot. Use a flatblade screwdriver to remove this screw.
After it is removed, you can slide the fuser back. you will notice that there is a small multiple wire cable on the right. Unplug it.
On the left are two leads that feed the heater. they plug into a connector that is in the left side of the printer. Pull the connector out, and you will see on the top or bottom side of the connector, a clip that holds these together. Press it toward the connector and pull it apart.
Remove the fuser unit.
With the red roller downward, you should be looking at the top of the fuser. The white power leads run along it. At each end of the fuser, there is a philips screw. One of them will be kind of hidden by the white wires. Remove those two screws. DO NOT REMOVE the screws holding the small pieces of metal under the wires.
After than turn the fuser around so you are looking at the paper rollers and the blue levers.
Just to the left of the left lever, and up about 1/2 inch, you will see a plastic "latch" that hooks over a ledge. CAREFULLY pry it back, and press up on the top of the fuser. On the other end of the fuser, there is a small black gear. There is a latch underneath it facing to the left. Gently pry it to the right, and if both latches are free, the top of the fuser will lift up.
The broken roller should be obvious. Before you move the roller, look carefully at the two black sleeves on the end of the roller. They have to be replaced exactly in the same place. You will need to remove the screw holding the heating element in place in order to lift the heater roller enough to get the old gear pieces out and install the new gear. At this time, the gear is 2.89 from brother. The heater roller might be slightly bent on the end (mine was). It can be straightened. I tried to order another one LJ7415001 but was told that was not a valid part number. The person I was talking to finally agreed to transfer me to extenion 2190 (877-276-8437) when she could not find the number, and hung up on me.
The gear will slide over the heater roller. NOTE:
There are two black sleeves on the end of the rollers. They each have a pair of "ears" on the opposite sides. These will need to be oriented so they are horizontally, and make sure they are in thier slots. BE SURE to screw the screw into the heater connection.
This same procedure can be used to replace the heater element, just don't touch the new heater.
Once done, you can re-hook the top of the fuser, install the screws and reverse the entire operation. A small dab of high temp grease on the gear may keep it operating smoothly. Since the gears are a weak spot, and are cheap, order two so you will have a spare.
Cheers
Woody Baker
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on loud ratchet noise when turning printer on....I think paper in feeder:
I don't want to Accept this solution
Solution #2
posted on Oct 17, 2007
Thanks for Trying (70)
Soulvisitor
Rank:Guru Guru
Rating: 88%, 1471 votes
In Australia and I guess the same applies to you part of the world the Bro 8840 has a 2 year Return to base warranty!!! These machine are not usally problem jammers.
Comment by Soulvisitor, posted on Oct 19, 2007
If it making a load ratchet noise and not working and you don't have 2 year warrantly like us then
Best bet pretty common too that it is the fuser drive gear busted (noise would come from rear)
Or the rego roller drive 'front left' if facing it noise whould come from
But experence being a brother agent, tells me you need a new fuser assembly fitted approx Aus$250-350
Have also rarely seen it caused by poor refil toner cart unable to turn, take out and power up to remove possibility of cart fault
Comment by Soulvisitor, posted on Oct 21, 2007
Or you have paper stuck after tray and pre rego area, not easy if not used to it to pull this area apart, left cover gears need to be remove too as well as front and bottom plate areas
Comment by Soulvisitor, posted on Oct 29, 2007
So have you bought a new fuser for your machine yet?
Thank You!
Solution #3
Not Rated (0)
Guest
Rating: 0%, 0 votes
The part number for the heater roller has changed. it is LM2706001 and as of today it is 22.04. That is why the lady could not pull it up. Had to get transfered directly to parts to find it.
Thank You!
Can you Help with these Printers problems?
front cover broke, where can i get a replacement
I have tried two new high capacity toner cartridges and...
Fax machine is set on manuel and can not receive fax,...
This copier is showing the message.:: Maintenance 7 on...
Hi, When trying to fax from the tray, the mechanism to...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
