Question about Dryers
I have a frigidaire FEQ1442ES and i press the start button and it makes a humming noise. The belt is fine.
    Genius:
  • 1,122 Answers
The buzzing sound is the dryer mootor locking up,it is no longer strong enough to turn the drum,i see this all the time-mike
Posted on Apr 23, 2009
Why Frigidaire gas dryer will not start? makes humming noise
Rodney, if the humming noise sounds like your motor is running but the drum does not turn you probably have a broken belt.
Jan 20, 2015 | Frigidaire FGQ332ES Gas Dryer
Why does my dryer not start, but the washer is fine?
Hello Jennifer Christie, thank you for your post!
I see that you have replaced the belt and bearing drum in your Frigidaire dryer but the unit does not start. It sounds like you could be experiencing an issue within the motor or timer. I would recommend having a professional come out to properly diagnose and repair your appliance, to avoid any further unnecessary part purchases. I hope this is helpful. -Matt
Aug 30, 2014 | Frigidaire FEX831CS Top Load Stacked...
Dryer will not start
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not start. I also see that when you press the start button, the lights above the Control button blink and your dryer beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire electric dryer (model # LEQ1442ESO) is making a loud noise. It's like a loud humming or vibration. Is it the motor?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 08, 2011 | Frigidaire FEQ1442ES Electric Dryer
Frightened FEQ1442es Nothing happens when I press diamond button to start dryer except the light next to "Control" comes on and stays on for awhile. Dryer does not start.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 06, 2011 | Frigidaire FEQ1442ES Electric Dryer
Humming noise and doesn't run
More than likely the belt has slipped off and the noise you hear is the motor running without the belt. It is not a tough fix mentally, but it can be quite a difficult do-it-yourself task. Good luck.
May 18, 2009 | Frigidaire Dryers
Rfrigidaire dryer making a squeaking noise but works fine
hi. thanks for the question .the front bearing and the back bearing is worn. replace these 2 parts. to replace.lift the top. remove front. replace front bearing undo belt . remove the drum . replace the back bearing. thanks the appliance doc
Oct 06, 2008 | Frigidaire FEQ1442ES Electric Dryer
I press the start button and hear an electric humming noise and the drum does not turn.
unscrew the rear panel of the dryer,
You will most likeley find the rubber drive belt broken and wrapped around the drum or motor.
if so
Take your make and model details to your local parts dealer and pick up a new belt, for a few $
like a fan belt it installs snaked around the drum, motor, and backwards around a tensioner
May 29, 2008 | Frigidaire Dryers
Dryers Logo
63 people viewed this question
Top Dryers Experts
