Trying to connect my siemans amilo l7310gw to a samsung lcdtv with VGA lead, i have set the laptop to low resolution and for 5 seconds the desktop picture appears then goes off and get a message on tv saying check signal cable. i dont know what else to do, thre is nothing wrong with the lead or either appliance. it obviously does work for the picture to come up but wont stay on. i have checked the tv manual and it just says to change the the resolution which i have done. i need help in how to make the picture stay on permenant. thnaks
Struggling to connect my Goodmans Freeview+ HD recorder (HDMI output) to either the DVI (female) or VGA (female) input of my Samsung LE27T61B TV which is HD ready with a resolution of 1366 x 768.
They are different protocols. You have to have a converter than changes the protocol (protocol is like a language...it needs to be translated to a different language). They are available from eBay or amazon but they don't always work very well. Best thing to do is get a unit with the correct connections.
Jul 14, 2016 | Samsung Televison & Video
I have the above TV/Monitor - I have connected my laptop to it and can see the XP screen OK - the resolution is 640x 480 but it is too big - I cannot change the resolution using control...
1. you need to check for video graphics card updates/> find out what video card you have and go to the manufacturers site to see if there is an update for your video card.
2. If you right click on a blank part of your screen ( desktop) you will see a screen with a "settings tab" click and see if you can change the screen resolution there if not then you will have to go to the BIOS settings. this is done at the boot up screen > a selection menu at the top of the screen usually appears displaying F1, or F1 + another key to get in to the Bios ( basic input/output system)
3. you will have to see if you have the video card set to 640x480 here. If so select the proper resolution your video card can handle.
Aug 02, 2011 | Computers & Internet
My Windows XP is connected to my Epson Powerlite S3, but the screen is blue with the words Source: Computer (Auto) No Signal on it. When I click "Help" on the projector, it takes me to a screen...
'No signal' and 'unsupported signal' messages mean 1 of 2 things, either the VGA output is off(laptop) or the display resolution is set too high(laptop and desktop). Assuming the VGA cable you are using is good, try this:
Desktop: hook the computer back up too your computer monitor & set the computer to the basic VGA resolution. For windows XP, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes!
Drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector. You will need to change the settings each time you switch monitor to projector.
Laptop: by default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue button (on the lower left of the keyboard, usually to the left of control ) and tap the bleu button you just found. Let go & give you're a computer a few seconds to change over. If the laptop screen goes blank, you found the correct button! The display image should now be visible. Repeat this 1 to 2 times to change it back to laptop display.
If you did not see the display on the projector, 2 other issues are possible. First, verify that the VGA output on the laptop is working - connect the laptop to a regular computer monitor & change the display resolution to the lowest settings (see desktop above), then try it again on the projector. If you cannot get an image on a computer monitor, your laptop settings may need to be adjusted in the same dialogue box as the settings. Monitor #1 is the laptop display, Monitor #2 is the external output.
Happy viewing :)
Jun 12, 2011 | Epson PowerLite S3 Multimedia Projector
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
When I hook my 40" samsung lcdtv to my dell inspiron 1721 laptop through the vga cable...the connection cuts in and out. It will appear on my screen...then go blackm and then back on again.
try configuring your display settings on the laptop before connecting. I have a HP dv7 and it was doing the same thing until i configured it for a secondary display
Dec 11, 2009 | Dell Inspiron 1721 Notebook
Trying to connect laptop to Samsung HD LCD TV using VGA cable.
I had the same problem with my Samsung series 6 32" Lcd. After many hours of trying different settings and banging my head on the wall I found the solution. What the problem is your VGA cable not supporting the high resilotion of your Samsung TV. The simple solution is to buy a new VGA cable that supports HD. Take a look at this site you need something like this one! Hope this helps.....C
http://www.clearly-av.co.uk/PGM1110.html
Sep 19, 2009 | Philips 32PF7421D 32 in. LCD HDTV
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
Got samsung le37a456c us as monitor
This samsung as pc monitor has an easy solution. after trying everything on many different sites:- rebooting, locating tv in settings, all the different sequences of conecting and turning pc and tv on, resolution settings. all this was a complete waste of time. SOLUTION:- i read all these people with the same problem and many had tried laptops and pc's on same tv yet always using same vga lead. so i decided i'd look at problem not in pc or tv but the lead, i borrowed a vga lead from I.T. department and as soon as i plugged this lead into my samgsung tv my pc option was active and i'd not even connected pc at that point. so i know its a total lead oriented problem.
Mar 27, 2009 | Samsung Televison & Video
How do i set my acer travel mate 2312lm to 1440 by 900 pixel so i can work my lcd tv
**Your Laptop has VGA port for connecting external monitors :
Laptop Video Specs :
Laptop's Max Resolution1024 x 768
Integrated Video card : SiS Mirage M661MX
NOTE : If LCDTV does not have a VGA port, you will not be able to use it a external monitor.
Steps :
1. Connect Laptop to LCDTV using a VGA Cable
2. Right-click on your desktop and select "Properties." (or click on start > Control Panel > Display)
3. A new window displaying several tabs will appear. Select the tab called "Settings."
4. You will see boxes with numbers on the middle, in your case 1 and 2 will be present.
5. Click on 2 and click on box beside "Extend my windows Desktop onto this monitor" then choose the resolution that you like (1440 by 900) then click on apply. If 1440 by 900 is not available, choose the closest under 1440 by 900. Don't go over 1440 by 900 since that is the max value that will work on you LCD TV.
6. After clicking on Apply, the display should be present on the LCD TV. (The disply is an extended desktop so you will not see the start button nor the taskbar on the LCD TV. but it should have the same wallpaper. You can Drag the windows to the LCDTV. This will serve as an extension of you desktop. (Ex : You can watch movie on the LCDTV and you can do documents on the laptop's screen at the same time).
Oct 27, 2008 | Acer Computers & Internet
Amilo L7310GW will not boot up
Can you try switching on without the wireless mini pci card . but exercise care while disconnecting the thin two wires named MAIN & AUX from WLAN card .It is easy to remove this and you dont have to disassemble the entire notebook for this
Apr 23, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
David Payne
David Payne
