Question about Goodman CKL24AR24 Air Conditioner
My airconditioner for the house is not working we change the electronic thermostat an still not working we replaced the fuses an its not improving would it be because of my dogs eating the wire's that are coming out the box from outside ??
    Problem Solver:
  • 19 Answers
There could be a short in the wire. meaning that its not getting the proper voltage. do you have any other symptoms? make sure that the breaker is not tripped, and if it is, it very well could be from the dogs eating at the wires. that could also kill your dogs if they get hit with that voltage coming from the wries.
Posted on Apr 23, 2009
E64 error code electrolux dryer
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E64 - Heater thermostat
  • Thermostat faulty (replace heater unit)
  • Heater unit faulty
  • Wiring faulty
  • Electronic board faulty.
Dado
Aug 09, 2014 | Electrolux Dryers
New battries in Duracraft Programmable Thermostat for A/C...still won
Remove the thermostat and just touch the wires together and make it run until heat wave is over then figure it out. Kinda of a pain but at least it be cool
Aug 07, 2017 | Honeywell Electronic Programmable...
If the thermostat says 89 which is house tempture, what should I put the air condition on to off set that temperature to make it cool in my house, right now air condition is set for cool @ 70, and house...
You have done everything right there...something is wrong with your A/C...
Here is a tip about troubleshooting your airconditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 28, 2011 | Ruud UBHC Air Conditioner
Thermostat keeps blowing fuses
There is a short in one of the thermostat wires. The fuse is triggered on the low voltage side of the unit. Replace the wires.
Feb 08, 2010 | Coleman Heating & Cooling
I have a coleman electraheat rv airconditioner/heater. i think the thermostat has gone out on it. is this a replaceable?When i turn the thermostat knob nothing happens. the fan will run but the compressor...
The thromstat may be bad but it sounds like there is a loose connection where the wires plug on to the back side of the thromstat.
Any RV dealer should have the part or be able to order it for you
Aug 21, 2009 | Dometic Rooftop RV Air Conditioner
Airconditioner fan quit working witch fuse should i check or do you know the fuse configuation for a 2000 bug
Must be blown thermal fuses on the fan housing. This is behind the glove compartment. Each speed setting of the fan has it's own, values are higher as the fan speed increases. Someone that knows basic electronics could replace the blown ones or replace it with OEM unit.
Jul 17, 2009 | 2000 Volkswagen Beetle
Not heating
Hi, Check the thermostats and the fuse. Make sure the 4" vent to the outsideis cleaned. If it is plugged, it will cause elements and thermostats to go bad.
The thermostats and the fuse must have continuity. If they are open, replace them. All these parts are located in back on blower housing and element housing.
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Have moved into a house which has a honeywell CM5000 heating system but dispite resetting the time date and temperature in each room it still won't start.Have had the airconditioner on during the summer...
dont know the square footage of your home or how many units you have. unless you are in and out of your home for long periods of time and need a digital thermostate. get rid of it. install a 30 dollar honeywell or call a prof. to f@##$%^you.
Apr 25, 2009 | Honeywell Electronic Programmable...
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Replacing saftey thermostat monthly
Clean dryer vent to improve airflow so dryer will not cycle on high limit thermostat. The best way is to use a cordless drill vent cleaner designed to clean dryer vents. Manual brushes are also available, or you can disassemble, clean, and reassemble vent. (if so, use the foil tape when reassembling) Make sure you are not using flex dryer venting. This should also improve dryer performance, reducing dry time.
Jul 10, 2008 | LG DLE2532W Electric Dryer
Goodman CKL24AR24 Air Conditioner Logo
76 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
