Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
The starter rope on my echo chainsaw model CS 280E will not retract. Therefore I can's start the chainsaw. I don't see how to get into the part of the chainsaw that holds the rope.  There are four screws that hold the cover that must be removed (and a fifth screw that holds the handle) and I have removed all of the screws but it still is not possible to get access.
    Problem Solver:
  • 9 Answers
I believe its a non servicable part and a replacement is required. its a simple swap out
Posted on Apr 22, 2009
HOW TO replace cord on Cs-302S
Check put youtube, they have many videos on this problem.
Jul 02, 2015 | Echo Garden
I have a CS-4400 Echo chainsaw that wont start. I don't think it is firing
1st thing let's check the spark.remove the plug leave it connected to the wire and ground the side of the plug to the engine. and have someone pull the started rope. watch the gap area of the plug for spark. make sure the plug is gap to factory specs, and hold it by the rubber booth. and the on switch is in the run position. good luck Tom
Mar 09, 2015 | Echo Garden
Chainsaw starter rope won't pull
Pull your spark plug to ensure it isn't a compression issue or even piston/rod damage. If it still doesn't move, pull off your starter assembly and try to rotate the fly wheel by hand. If it turns, then your issue is in your recoil spring kit. You can replace the unit, or try to disassemble and reassemble.
Jul 30, 2014 | Echo Chain Saw. 18 in. 40.2 cc Gas Chain...
Chainsaw won't stay running
You must have dirt in one or more of the carb jets. Remove the carb and clean it with carb cleaner spray and compressed air (compressed air is a must).
May 10, 2012 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Attempted to start unit, second pull, the pull rope seized up and would not release or retract. Approximately a foot of rope hanging loose.
It has either broken the starter spring, or the pulley has jammed in the flywheel, remove the cover screws and take away the starter, if the c ord then retracts it was jammed, if not, slacken the centre fixing screw, does it retract now , if so the centre post is worn, and the fixing screws is clamping the pulley before it bottoms out on the top of the post, if it still does not retract, remove the centre screw and pulley, check the spring behind has not broken, be careful as it is a long spring under tention.
Jul 19, 2011 | Poulan 14" Chainsaw
How do I remove side cover assembly on an Echo 280E saw to get at starter cord so I can see why it does not recoil? It appears necessary to remove handle first because it passes through a hole in the...
hi there davidclfee
here is web site with parts breakdown/ exploded views
http://www.ereplacementparts.com/echo-cs280e-0000001-0055489-chainsaw-parts-c-35043_35970_35976.html
or http://www.partstree.com/parts/?lc=echo&mn=CS-280E+S%2FN+0000001+-+0055489&dn=3497
from the picture
remove screw front front of the top handle and the screw that connects a isolation rubber to handle
then remove the 4 screws that secure the cover to case
see exploded diagram you can click zoom in or print the diagram if you need but save a copy
to your computer and keep the web address its a good site
cheers hope it helps
pauly46
May 22, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How do you rewind the starter rope spring on an Echo PB-200 Blower.
assuming the spring has not broken behind the pulley causeing this problem you should be able to just re tension the spring, hook the starter rope into the slot in the side of the pulley, this will allow you to wind the pulley ( in the direction that the engine rotates ) up, when you have turned it enough times that the spring is coil bound ( be careful as the spring will be under a great deal of tension ) release the pulley then one whole turn, now unhook the starter rope and allow the spring to recoil ( dont just let it fly back ) and wind the rope in.
Feb 04, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
The started rope pulls and retracts ok . When I put it back on the saw the flywheel only moves a couple of inches. I , therefore, cannot get it started at all.
Look at the flywheel side of the starter spool for damage to the 'dogs' that grip the flywheel when using the starter. You may need to replace the spool if damaged. Hope this helps!
Nov 21, 2010 | Poulan Garden
Pull start and pawls with back plate for echo 602L
I think what you seek is listed here: http://www.echo-usa.com/documentation.asp?Model=CS-602VL&lang=E
See the "Starter and Magneto" print.
EchoUSA (all models)
If your saw is not listed type "CS" in the “Model:” window, click "Search" and select your saw from the list provided.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 28, 2010 | Echo Garden
Starter rope will not retract.
inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
588 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
