Question about Daewoo L700C 17" Flat Panel LCD Monitor
Monitor keep going to black screen while viewing.
''Daewoo L700C shows a great picture, but keep going blank (black screen) after 30 seconds or more''.
  • Anonymous Apr 27, 2009
    When I start my computer the monitor will come on and show a great picture, but after a few seconds to 1 minute the screen will go black. after re-starting the monitor by turning it on and off, it does the same thing (go black). The cables are properly connected, so I was thinking that there must be a internal problem.........
    New Friend:
  • 113 Answers
Disable the Screen Saver in the Display Properties from Control Panel of your Computer.
A Black ScreenSaver is active in your Display Settings. Change it to "NONE" and your problem will be solved.
Posted on Apr 23, 2009
L950SC Monitor screen has only a white screen?
Plz check the brightness and contrast from the menu on the monitor.
Jan 13, 2011 | Daewoo L700C 17" Flat Panel LCD Monitor
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Image not visible on monitor screen
My viewing screen is black. I had successfully taken a picture, viewed it, and turned the camera off. When I turned it back on about 30 seconds later, the viewing sceen was black. I can 'take' a picure, but it comes out black. Help!
Nov 12, 2007 | Casio Exilim EX-V7 Digital Camera
Computer Monitor
hmmm chek the power board in the back chek resistors and ic's in ocilloscope good luck
Oct 12, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
SCREEN MESSAGE - MODE NOT SUPPORTED
You have set a resolution that is too high or incompatible with your monitor. I assume you are using Windows. Turn the computer on and immediately keep pressing F8 on the keyboard until the 'Windows Advanced Options Menu' appears. Use the Up and Down keys to select 'Enable VGA Mode' Press enter and your screen will work again when windows starts. Now go to the display properties and click 'Advanced' then click the 'Monitor' tab and tick 'Hide modes that this monitor cannot display' OK everthing and now you should be able to adjust the resolution without getting a blank screen again! Good luck and come back to comment soon. Regards
Sep 26, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Daewoo L700C 17" Flat Panel LCD Monitor Logo
344 people viewed this question
Top Daewoo Computers & Internet Experts
John Anderson
John Anderson
Saleem Baig
Saleem Baig
JonSnell Electronic
JonSnell Electronic
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
