Question about Car Audio & Video
Subwoofers When i turn the gain up on my amp the subwoofers make a compressing noise to a beat but not randomly and all the lights dim when it beats. not sure whats going on
Ground ground ground
Posted on Jul 01, 2008
    Problem Solver:
  • 14 Answers
If the light on the amp is dimming when the bass hits it's usually a power related problem. It sounds to be that you don't have enough power going to the amp to drive the sub. It should stop if you reduce the volume at which you are playing the music. Yes?
How to solve this is to, increase the size of your power cables, add a power capacitor if needed & change the car battery to a higher capacity one.
The other option a little more professional, would be to fit a split charge system & a secondary battery to the boot/trunk of your car just to run your stereo system, with a power capacitor too. This will provide all the juice that your system requires so you can bang your head as long as you want :P
Posted on Dec 28, 2007
When i turn da radio off then turn the beat on it work n stop
I don't know if your talking about subwoofer or speakers but if they stop while a big loud beat comes in its to much for your amps if you have them to handle and the amps turn of and by turning of your head unit and on again it resets them and works again try turning your gain down on the amps
Aug 01, 2014 | Car Audio & Video
What cause my 15 speaker go off when the beat kick in but the amp still on n make noise out da speaker
Sounds like it's overloading you may have a sub to small for your amp cut all the settings on your amp back to minimum wind them up until sub cuts out then drop them back a bit .
Only one subwoofer beats
how do you have them wired? have you tried to cross wire or conect the speakers to gether
Jul 25, 2012 | Pioneer TSW303R 12" Car Speaker
Mi lights dim everytime mi speakers beat
simple issue means your alternator is not able to supply enough amps to keep the system running properly, recommendation get a capacitor to handle the extra load, it acts like a second battery, when the alternator charges the cap it takes the load off the cap rather then the battery, so the lights and system all run with sufficient power i recommend a 1 to 2 farad capacitor for your system if it is about 800+ watts, you will notice the difference immediately
http://www.bestbuy.com/site/olspage.jsp?skuId=8286482&type=product&id=1172880157454&ref=06&loc=01&ci_src=14110944&ci_sku=8286482
very good cap
Aug 20, 2009 | Rockford Fosgate Car Audio & Video
My subs randomly go in and out, for no specific
wow..where to start..
First check your RCA"s by wiggiling them at the connection to the amp, see if this causes the amp to come on..If the amp plays then try swaping your RCA's.
Once you have checked the RCA"s, and other various connections, try simply bang arround on the amplifier, yeah I know, it sound back yardish, but if the sound starts to cut in and out by banging on the amp, then you know you have a bad soldier join somewhere. If this is the case, just have a technitian look at it, and repair it for you.
OK so you have checked your RCA's, and beat the amp up a lil bit, and still nothing.. Now you go beat up the dash board a bit, and see if the radio responds, if so then pull your deck, and find your loose connection.
There are still lots of things to check, but it gets pretty advanced, so try the things listed above, and keep your fingers crossed..
Aug 06, 2009 | Jl Audio 12W3 Car Subwoofer
Amp power protector comes on
Dis connect the sub then turn it on, don't let the wires touch or it will have a problem. If your lucky, it's just your sub that needs replaced. If not, your amp needs serviced. Rockford use to have a three year warranty... I'm not sure what they have now since mass merchants beat up the line. Hope this helps
Jun 02, 2009 | Car Audio & Video
Subs not hitting
remote wire turning on amplifier?
Ground for amplifier?
Gain improperly set?
Radio output crossed over above tuning freq. of enclosure?
Just suggestions. Not much info to go by.
Dec 15, 2008 | Jensen BP212 Car Subwoofer
Mono amp
well first check ur wireing next the amp is turned down or just bad amp let me no if that helps
Sep 26, 2008 | Kicker CVR12 Car Subwoofer
My subwoofers have a heart beat to them
Ok.... FIRST COMMON PROBLEM: recheck your ground connection. Make sure that your amps ground wire is securely bolted to the metal body of your car. Not only that- yo uhave to scrape or use sandpapar to make sure that the terminal is touching bare metal.. this is a very common problem. Nobody realizes that the ground connection is just as impoarant as the power connection... Next unplug youir rca cables from the amp. If the heartbeating goes away then mabye you have a rca cable or deck issue. If you can wiggle the rcas at the amp and make it heartbeat more or less.. then perhaps the rca terminals have come unsoldered form the circuit board... in any case without me looking at it personally this is about all i can tell you. CHeck your connections and GOOD LUCK!!!!!
Aug 26, 2007 | Directed 5108 Car Subwoofer
Audiobahn Sub: AW1206T & Amp: A8002T subwoofer extra noise/pop
The RCA inputs to the sub may be unplugged or damaged. Check them both for the sub and for the amp
Sep 05, 2006 | AudioBahn AW1206T Car Subwoofer
Car Audio & Video Logo
110 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
