Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Bobbin Thread When I embroider, sometimes the bobbin thread will show through and overtakes the color that is supposed to be embroidered. I am using the correct bobbin thread.
  • Anonymous Dec 09, 2007
    THE BOBBIN THREAD IS TAKING OVER MY STICHES. I HAVE TRIED ALL THE STANDARD SOLUTIONS: RETHREADING THE MACHINE, USING A THREAD NET, CHANGING THE NEEDLE, REWINDING THE BOBBIN,
    FLUFFY
I have had the same problem. I always just used the same color of bobbin thread as on the top. It is a pain to change inbetween each block, but the designs usually look perfect. I will have to try playing with the tension.
Posted on Dec 13, 2008
Bobbin thread shows on embroidery pattern
The bobbin thread is being pulled too hard by the top thread. The idea is to get an even pull similar to a tug of war. When it is even the thread will form a knot in the middle of the fabric.
To fix this so the top thread isn't pulling too hard lower the tension of the top thread. This should fix it.
May 08, 2015 | Janome Memory Craft 10000
Why is my bobbin thread is showing while embroidering
Your tension on top can be loosened. If this causes your stitch to be too loose then tighten your bobbin tension. Just think of the top and bottom tensions as a tug of war. They must be even to get the stitch in the middle of the material.
Jul 31, 2014 | Baby Lock Sewing Machines
Having problems with metallic thread breaking constantly. I have adjusted tension up and down. I am using the net over the thread as directed in them manual. The bobbin thread continues to show on
I'm not exactly familiar with your machine but... a few things you should know. 1. You need a metallic thread Needle. or at least one with a larger hole. 2. Check your bobbin carrier, if anything catches or jams between between the spring and the case it can loosen the bobbin tension and make the top show too much bobbin color. 3. If your bobbin spring becomes grooved from the wear of the thread... same thing. 4. If your spring and everything is ok and clean... tighten the tiny screws to tighten the bobbin tension some.
Dec 23, 2012 | Sewing Machines
I have a singer Futura CE-250. I am having problems with the tension I think. While embroidering the top thread is showing completely on the underside of the material. In other words the bobbin thread...
One of the things they don't really tell you about embroidering with the singer machines is that you really do need to use the same color in both the bobbin and the top. No matter how much you adjust the tension, you will still end up with some of the thread from both showing through on the other side, unlike with most other machines.
I found this out from a Singer technician about 3 years ago when I had the same problem with my CE 150 and was going nuts! He worked with both Singers, Vikings and Huskvarna's. and saved my sanity after demonstrating a lot of technical stuff that basically showed me why Singers did this.
Save your sanity-just bite the bullet and use the same thread in the bobbin as you do in the top.
May 27, 2011 | Singer CE-100 Futura Computerized Sewing...
My bobbin thread keeps coming to the top of my fabric during embroidering on my Singer Futura CE350, I've tried bobbin embroidery thread, regular embroidery thread and clear nylon thread, I've tried...
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Oct 23, 2010 | Singer CE350
The bobbin thread is sewing loose - after sewing you can just pull the thread out. Stitches are uneven in length some short some long.
Tighten the bobbin thread a little and loosen the top thread tension a little. A correctly tensioned embroidery machine will show a little less than 1/3 of the top thread color and 2/3 of the bobbin thread on the bottom side of the embroidered piece. You may have to play with it some so use scrap material and dark top thread until you get your adjustment made.
Oct 11, 2009 | Janome Memory Craft 9000 Computerized...
Embroidery Problem with my disney
Check your bobbin case. Thread the bobbin through your bobbin case while holding it in your left hand. Pull the thread with your right hand and feel if there is any resistance. If not, you need to adjust the tension on the bobbincase. Also check if a piece of thread or fluff did not get stuck between the tension blades on the bobbin case. If you are not sure how to adjust the tension on the bobbin case, ask your dealer to do it.
Dec 18, 2007 | Brother SE-270D Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
202 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
