Question about Refrigerators
Freezer is ice cold, fridge won't cool lower than 42*
Ge tfx24rh frost free fridge that is set on mid settings most of the time. noticed that the beer was slightly warmer than normal, so turned it colder and it's still warm. the freezer is a cool 28-29 degrees. Fridge won't cool lower than 42-43 on highest setting. Any ideas? I haven't been able to find any diagrams or other troubleshooting info. If you can offer any tips, it's greatly appreciated. chris_coulter2000@yahoo.com
  • 1 more comment
  • chris_coulte Apr 23, 2009
    about 1/2 hr into defrosting now, will post what I find shortly. Thanks
    all defrosted, the coils were covered in ice and frost. the entire compartment behind the panel was near solid. I think the heaters are shot. I think due to the age of this unit and it being used when I got it, I'm going to see if it will cool the fridge down now and then buy a new one asap.
    measure continuity across the thermostat and now open when thawed and warm. Appreciate the help and any other tips that may come in handy.
  • Refrigerators Master
  • 4,654 Answers
Sounds like it's not defrosting, so unplug open freezer back panel and use a hair dryer to melt ice from evaporator coil. Your refrigerator has a defrost timer on bottom near floor, but if freezer is frozen we need to defrost it so we can make sure there is not some other problem. Let me know when you are ready, Sea Breeze
Posted on Apr 23, 2009
  • John Tripp
    John Tripp Apr 23, 2009
    OK so the defrost heater/element is bad? You're going to purchase another refrigerator? You need to remove one wire from the element and check through the element only. The defrost thermostat will be open at 50 degree all the time so testing it will need to be done while cold. I think its possible if element is good then defrost timer or thermostat is bad.
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
Kelvinator fridge freezer, fridge too cold frosting at back
Fridges that are less then 10 years old have a lot of POWER. To get rid of the frost, wait until you have eaten most of the food up (maybe a few days), then unplug the fridge and leave the doors open. This will take care of the frost after several hours.
From then on, make sure that when your fridge is full, use a higher setting, and when it is near empty or half way full, use a lower setting. Keeping the freezer at a mid to low setting all the time should be fine, because its usually the fridge part that gives people trouble.You will have to judge on your own which setting is best (i.e you can tell when its good based on how cold the juice is in there, etc).
By adjusting the setting based on the amount of food in your fridge, it should prevent frosting.
Hope that helps!
Mar 28, 2011 | Kelvinator KBM5100MB
Fridge not getting cold, ice maker not making ice
It sounds like it is doing some cooling. Check to see if your evaporator fan is running and there is not ice buildup on your evaporator (indicating a defrost issue, common on ge refrigerators, usually heater goes bad), you would either see ice on the back wall of freezer or if you take off the back wall you will see lots of frost. Also check if your condensor fan is running and clean the condensor. The compressor is running since it is getting down to 27 but if it is not being cooled it will shut down. Another common problem on the ge refrigerator is the main board contacts going bad and not running the compressor. If your compressor is running the whole time and none of the other conditions exist it sounds like you have a leak or restriction in the refrigerant or sealed system.
Dec 13, 2009 | GE Profile PSC25PSWSS Stainless Steel...
My GE Adora side by side refrig. has stopped making ice and I am having a hard time regulating the settings on it. The freezer is too cold and the refrig. section isn't cold enough. I also have noticed...
Defroster circuit/timer has failed.
The water line to the icemaker has probably frozen,so no ice. The cooling coils are in the freezer, and the cold air moves to the fridge via vents and circulation fan.
When it all ices up, no air gets to fridge, fridge gets warm.
Many models have a mechanical defroster timer located under the lower front kick panel. Manually rotate the timer until you hear the compressor stop.
Defroster heater then should come on and you hear scorch/hiss/gurgle of defrost sounds. If the timer is working, the fridge should come back on after about a half hour or so.
Sometimes timer fails, sometimes heater element fails. There is also a defrost thermostat that's part of the heater assembly.
http://www.appliance411.com/faq/howdefrostworks.shtml
Oct 23, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
On top freezer works fine, fridge compartment below is not cold.
turn the dual temperature switch to warmer for the fridge to cool down.
Apr 04, 2009 | Refrigerators
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
GE Fridge/Freezer Having to turn temp up just to keep it cold
From your comment. It's not that you have to defrost the parts, that's what they're called. "defrost timer", "defrost t-stat" and "heat element". Defrosting the whole fridge for a few days actually will clear the ice blockage if that's it but it will return in a couple weeks if the "defrost cycle" isn't doing its thing. A fridge typically goes into some form of "defrost cycle" to keep it "frost free". As an example, every 12 hours the compressor turns off and the evap. fan turns off then a heat element turns on to melt the light coating of ice on the "cooling coils". Once about 1/2 hour goes by the heating turns off and the cooling turns back on again. This repeats over and over to keep the ice from building up too much. If that cycle is broken, the ice will build and build till the whole coil is a block of ice. Then the air can't flow around it to provide cold air for the whole unit. It acts basically like putting a large block of ice in the freezer and keeping the doors closed... without a fan to move the cold air only the very lower portion of the freezer is cold, the rest is warm.
Dec 30, 2006 | GE GTH18KBR Top Freezer Refrigerator
Refrigerators Logo
433 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
