Question about Refrigerators
My refrigerator sounds like it is sending Morse Code. It has stopped making ice. The freezer is cold, but the top half or refrigerator part is only partially cold.
    Guru:
  • 1,524 Answers
You have a defrost problem. Evaporator is hitting built up frost, which is restricting air flow to the refrigerator (how it gets cold).
Posted on Apr 22, 2009
Top half of my refrigerator and freezer not as cold as it should be
Make sure there isn't anything blocking the cooling coils GE Side by Side Refrigerator GSS25JFMC Service Manual in PDF format... You can purchase a service manual from here.
Jun 26, 2017 | GE Refrigerators
I'm getting water in the ice dispenser. The
First, check to see if the evaporator fan is blowing in the freezer. A common cause for this problem is an air baffle that is stuck open, or closed due to frost buildup or a component failure. The air baffle is at the top of the wall between the freezer and the refrigerator. If you check for cold air coming through this vent, you will probably find that it is constantly open. A temperature sensor (thermistor) in the refrigerator normally detects temperature and a control board sends voltage to a motor to open and close this baffle properly to control refrigerator temperature. You could have a failed thermistor, failed baffle motor or a failed control board that is causing your problem as well.
Jul 27, 2011 | Maytag MCD2257HE Side by Side Refrigerator
Bottom half of fridge and freezer are cold top half warm?
This sounds like an air flow issue, If your freezer fan is running still you may have a defrost problem starting in the freezer cooling coils. This will cause the cold from the freezer to back flow into the bottom of the fridge and only the lower half of the freezer to keep very cold.
Most likely culprit for defrost issues would be the terminating thermostat (inside freezer behind back wall and clips to top of coils).
Good luck and let me know if you need more help!
Jun 14, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We had a power outage and top half will not work
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 08, 2009 | Refrigerators
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Aug 10, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
