Question about HP DesignJet 1055cm InkJet Printer
Power outage caused printhead error on HP 1055 CM design jet
After a power outage my HP 1055 CM gave a ''reset print head'' error message. I turned off the printer to reboot, and now I am in a endless loop of ''Self Test, please wait'' and Initializing, please wait.. back to ''self test, please wait.
I called my local technician, but he isn't available and told me to see if I could figure out how to do a hard reset - but I don't have a manual, and don't know how to do this..
Any thoughts?
  • terren Apr 23, 2009
    Tried the HP site - no easy way to find the manual... I kept getting older threads relating to cold resets back to factory settings.
  • inkypete May 11, 2010
    Try the HP site?
    Scholar:
  • 96 Answers
Turn off the printer, remove your jetdirect card(nic) sounds like your local tech doesn't know his **** from a hole in the wall. this should resolve your loop problem, if not then your main pca have been popped by the power outage. good luck.
Posted on Oct 01, 2009
How fix error code 0xc19a0003 on HP B110a ?
0xc19a0013 or no code Check the cartridges
The ink system can fail if the cartridges in the product are installed incorrectly, if the ink in the cartridge is low or out, or if the cartridges are damaged or not correctly vented. Follow these steps to check the cartridges thoroughly and resolve any issues you find.
Step 1: Replace empty or low cartridges
Step 2: Make sure the cartridges are installed correctly
Step 3: Use the automatic printhead cleaning utility
The automatic printhead cleaning utility is available only if you installed the HP software that came with the product.
If the print quality is acceptable on the test page, you are done, and there is no need to continue to troubleshoot. If the print quality is not acceptable, repeat the automatic printhead cleaning procedure again. If the print quality is still not acceptable, 'Remove, clean, and reinstall the printhead' .
Reset the HP Photosmart B8550 Printer
The error message might disappear after you turn off the product and turn it on again. After you make any adjustments to the cartridges or the printhead, reset the product in order for the error message to clear completely. Follow these steps to reset the product.
1.Press the Power button to turn off the product.
2.Disconnect the power cord from the back of the product.
3.Wait 30 seconds.
4.Reconnect the power cord to the back of the product.
5.Turn on the product by pressing the power button.
Check the product control panel display. If the error message disappears, you are done, and you do not need to troubleshoot further. If the error message persists, continue with the next section, 'Remove, clean, and reinstall the printhead.
Read More Help.....HP Printer Support
Thanks,
Aug 08, 2014 | HP PhotoSmart Office Equipment & Supplies
Blue screen: error code 0081.After i get a white screen saying shut down and fire back up printer. tried that and a full reset, still not working.What is the problem
Got the same error. It usually is from the printheads. It first gave me the message that the YB printhead has failed and needs to be replaced. I think this printer has some built-in software that says the print-head needs to die a horrible death after a definite period of time, since my printheads were perfect, printed like new. And when the printer gets to the date it just makes the head die. Suggestions is to replace the printhead. I don't think there is any other way. Or buy a new printer. Preferably not HP, maybe a Brother.
Oct 27, 2013 | HP Officejet Pro 8500A Plus Wireless...
Printhead has a problem HP Office Jet Pro L7590
I suggest you go to the HP support website and see what assistance you can get for this model.
Start by downloading HP Assistant
Oct 06, 2017 | HP Office Equipment & Supplies
I have an HP c7180 all in one inkjet printer and recently we had a power outage. Ever since that time the colors are all mixed up. After the power outage, I was getting this error message: ""Ink System has...
If your product is in warranty then I recommend you to contact HP support to service or replace the unit. Otherwise perform the steps given below and verify the results.
  1. Turn on the unit.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 7 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Oct 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
IDS failure, call HP message comes up
Hope this helps you. This error is caused by either a correct or incorrect detection of air in the manifold. The steps below will clear the error condition, which should solve the problem if it is caused by an incorrect detection of air. If there really is air in the manifold, however, this procedure will not solve the problem and the printer will have to be serviced. Step 1 - Remove all printheads CAUTION: Do not touch the printhead tower. Do not remove the printhead handle. Keep printheads out of the reach of children. Figure 1: HP 14 printhead c00042423.jpg 1 - Handle 2 - Tower
  1. Make sure the unit is plugged in and the power is turned on.
  2. Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
  3. Wait two or three seconds, then unplug the power cord.
  4. Open the printhead latch. See the illustration below. Figure 2: Open the printhead latch c00042424.jpg
  5. Remove each problem printhead by lifting the printhead handle and pulling up. See the illustration below. Figure 3: Remove the printhead c00042425.jpg
Step 2 - Reset the internal error state NOTE: This step must be performed before the printheads are re-installed.
  1. Close the printhead chute.
  2. Close the access door.
  3. Plug the power cord back in.
  4. Turn on the power. The front panel should read No Printhead. Will damage Product. Insert [color name] [icon] printhead now . NOTE: The carriage may make a grinding noise when you turn the power on. This noise is normal.
  5. Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
  6. Wait two or three seconds, then unplug the power cord.
  7. Open the printhead latch.
Before re-inserting the printheads, make sure all the electrical contacts have had at least five minutes to dry. Step 3 - Insert the printheads
  1. Place each printhead in its slot in the printhead carriage. The colored shape on the top of the printhead should match the colored shape on the proper slot on the printhead carriage.
  2. Press down firmly and evenly on both the front and back of the printhead, as shown in the illustration below. Proper seating is essential to making good electrical contact.
Figure 4: Seat the printhead c00042431.jpg Step 4 - Close and check the printer
  1. Close the printhead carriage latch and make sure the loops catch the hooks. See the illustration below. Figure 5: Loops catch hooks c00042432.jpg
  2. Snap the latch into place.
  3. Plug in the power cord.
  4. Close the print carriage access door.
  5. Turn on the power.
  6. If the error clears, a message to align the printheads may appear on the HP Officejet D and HP Officejet 7100. Press Enter to align. If the error persists contact HP. Printhead replacement will not resolve this problem - the printer will have to be serviced.
Jan 08, 2009 | HP OfficeJet D135 All-In-One InkJet...
The following printhead(s) has a problem Black/Yellow[K/Y].
Simple solution is:
Replace the Black and Yellow Print Catridges. The print heads are mounted to the bottom of the catridges and these, depending on whther they're from HP or not. can have a hard time conducting electricity properly, and in turn.. spitting ink out properly.
Also happens often with aftermarket Catridges because HP puts chips on the catridge. be sure to put an HP catridge. Sometimes you get what you pay for :)
Oct 31, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7680 print head problem
When installing the print heads out of the box you MUST shake them for 30-60 seconds, same goes for ink tanks. If you do not then the lubricant that is added to them will seperate and it will draw thinned out ink causing damage to the print heads. Also, if your system sits for more than a couple weeks (and this goes for ALL printers) then run a test page ence every 2 weeks to keep the system from drying out.
I used to work at a couple office supply stores and this was almost always the issue with bad printheads on HP, Brother and Cannon printers.
Aug 19, 2008 | HP Officejet Pro L7680 All-In-One Printer
Open Questions:
See all HP DesignJet 1055cm InkJet Printer Questions
HP DesignJet 1055cm InkJet Printer Logo
947 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
