Question about Bosch Appliances 27 in. Wall Oven Electric Single
Bosch wall oven clock flashing on 0:00. I can't set the time
5 Suggested Answers
dutchman05
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
SOURCE: De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
Posted on Sep 26, 2008
SOURCE: Neff series 1 oven
press the two arrow buttons in at the same time as turning the pop out knob
Posted on Feb 12, 2009
SOURCE: Re-set Clock due to power black out
Lucky for you(?) I had to reset our clock for daylight savings and checked here before i found my manual. If you're still looking for an answer, press the + & - buttons at the same time, let go and you have 4 seconds to press the + key again to set the time
Posted on Oct 03, 2011
Bosch single oven has clock function but when I reset it goes to military time
Never heard of Military Time unless you mean 24hour clock in which when the power is interrupted or the clock is reset, that is the default setting.
Jun 18, 2017 | Bosch Ovens
How do adjust the clock to daylight saving?
Touch TIME then the display will begin flashing timer
Use rotary knob to change this to CLOCK
Touch TIME again and it will say ENTER TIME with the time flashing
Use the rotary knob to change the time as required
Touch START and the time is now changed
Page 12 if you need it
Bosch HBL745AUC Use and Care Manual
Oct 07, 2014 | Bosch HBL 745 Stainless Steel Electric...
I have a Bosch built in oven and don't know how to set the time on it
turn the oven off at mains for a few secs. When you turn it on the display should flash 0.00 or 12.00. Press the clock button once ( don't hold it in) use the + or - to set time. Once time selected don't press anything else after a few secs the oven will register and hold you selection.
Apr 03, 2013 | Bosch "27"" Single Wall Oven 500 Series -...
My bosch oven - HBA 13B250B is not displaying the clock real time any more. The oven still works. I can't find my instruction manual. Any ideas how to reset the clock
To change time on your Bosch oven, please do the following:
1. Press the clock icon (above the MINUS (-) button repeatedly until the clock icon on the display illuminates.
Please note: There are 4 illuminated icons on the display above the time. There are 3 which have clocks on them. You need to make sure the 4th icon (on the far right) is illuminated on the display.
2. Use the "+" and "-" buttons to set the clock to the correct time.
Once you have set the correct time, the oven will return the displaying the time and the illuminated clock icon will disappear. You do not need to press anything to confirm the time is set.
If you are still having difficulty, please post back for further assistance.
Regards,
BElectric
Dec 31, 2010 | Bosch Ovens
My wall oven will not work. The clock is flashing '0:00 auto', I don't have a manual but the grill works???? Also tried pushing the buttons to set the clock and they don't do anything either???? Is this...
The clock will generally only be linked to the main oven. Can you comment on this post with the make and model and I may be able to assist with setting the clock, If the make is a siemens (as this is the section that you have posted the question in), follow the link below and download the manual to assist with the setting of the clock. All the best.
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html open link and then click where indicated to open manual search, then input model number (Enr number).
Sep 04, 2010 | Ovens
How do I set the clock
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
Chef regency oven with "HELP" flashing on panel. Have no manual
Usually means that the time needs to be set. Press Clock Set then use the up and down button to set correct time, Then press Manual button.
Apr 16, 2009 | Ovens
Wall oven on automatic with 0.00 flashing and will not go
You need to set the clock to the correct time and this should take it out of automatic mode, it should then work o.k
Nov 30, 2008 | Ovens
Bosch oven HBT346 - how do I reset the clock?
Hi after a power cut my Bosch cooker clock is flashing but I cannot reset it as have no instructions - any ideas? Thx
Apr 15, 2008 | Bosch HBN 442 / HBN446 Electric Single...
Bosch Appliances 27 in. Wall Oven Electric Single Logo
150 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
