Question about V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series
I have a Honda GX610 18 hp small engine. There is no spark to either spark plug. If the engine stop diode is bad would this occur? Any help on this would be much appreciated. Thanks
  • 2 more comments
  • braran Apr 23, 2009
    Problem Solved
    Problem Solved
  • Lieu Apr 25, 2009
    There is no spark to either plug or plug wire. I cleaned the coils. Does this have a relay that both coil wires go to that would cause this?
  • ray012965 Jan 17, 2017
    yes disconnect black wire with blue stripe from diode assembly usually fastened by two nuts on side of head reminder one behind shroud is another diode assembly best way isolate grounding wires from coils and if starts then you back track by re connecting each device
I have the same problem...did you find a solution? If so please email me at
Posted on Jun 09, 2009
  • Honda Expert
  • 406 Answers
Yes first isolate the grounding wires from the coils if she starts you should replace the diode assembly.if it does not start or have spark on either coil,they will need to be replaced.feel free to ask me further ??? i am a honda tech for over 30 years.
Posted on Dec 23, 2014
    New Friend:
Hello I'm from Honduras, I need to locate the motor gears HONDA DYNA
GX 610 / V TWIN 18 hp
series GCAC-1005320
13.4 kw
614 cm # 3
need help to build it today and if I struggled and I get
Posted on Apr 23, 2013
I need to find out the rpm when idle with this engine.. any one who can be of any help email
Posted on Jan 12, 2010
Necesito adquirir el motor de arranque y el filtro de aire para el motor HONDA GX 610 / V TWIN 18 hp serie GCAC 1003623
estoy en colombia y no conosco el distribuidor de repuestos
Posted on Sep 04, 2009
Honda gx200The water blaster just stopped and I change the spark plug but still only a very small spark that is when it sparks?Coil buggered?
very small spark okay as long as its blue and not bright yellow.try using starting fluid if runs might want to see if carburetor is getting fuel.
Jun 18, 2013 | Honda Engines GX200 Series General Purpose...
2007 focus 2.0 engine stumbles sometimes when driving. when this occurs with car idling, the engine dies but cranks ok and restarts normally and drives fine until this happens again. Car is at deale
i had a similar problem with 2007 focus,car stumbled couple times,stopped at store for milk, car wouldn't start back up,alternator light blinking erratically.wound up replacing alternator,actually had the old one repaired,shorted diode.bad job was removing it from car.came out from underneath.
Jan 27, 2013 | 2003 Ford Focus
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
Jul 06, 2010 | Karcher 2500 PSI Pressure Washer
Engine 8 Hp: gx240 8 hp no spark...
i have one that did the same and found out it was the interanl coil...
May 18, 2010 | Honda 8 HP Engine
Lose power
Could be fuel filter, spark plugs, plug wires, bad coil, bad timing. Would need more information to give you more help.
Apr 16, 2010 | 1996 Honda Civic
2005 honda crf100f motorcycle will not start
If the spark at the plug is goog then its a fuel or choke / air problem .Check to see if the plugs are wet after turning over the engine a few times .you may have a sticky choke that not letting enough air in with the fuel mixture .
Mar 13, 2010 | 2005 Honda CRF 100 F
11 HP Honda engine won't start.
Ypu could try a canned spray called AERO START which is a chloriform based accelerant. Spray into air intake and start engine. If it doesnt start with this solution then there is a serious problem.
Ensure the spark plug is actually sparking .
Remove it from the socket and place near an earthpoint while still connected and turn motor over. If it sparks then tick that box.
Ensure the spark is strong rub sand paper over the element of the plug to make it bright and shiny
check the lead is in good condition replace if nescessary. A bad lead especially carbon fibre crack inside and become leaky causing poor spark or no spark. If this appears OK then tick that box!
Place a spray of Aerostart inside cylinder and replace plug start engine again. if it fails to respond it will need to be seen by a mechanic
Jul 22, 2009 | Garden
V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series Logo
5,011 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
