Question about Xerox WorkCenter 4150 Black and White Copier
Print jam when there isn't one; says open side door to remove
Xerox Workcentre 4150
    Problem Solver:
  • 6 Answers
This model has a chronic problem with the fuser exit sensor flag sticking..check and replace.
Posted on May 02, 2013
  • 30 Answers
Hi,cleared misfeed sheet & clean sensors.send me result.
Posted on May 26, 2009
Xerox workcentre 4150 not printing test page on windows 7
Hi Cnorini ,
Check this video and solve your problem.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Xerox Printer Support
Mar 04, 2014 | Xerox WorkCentre 4150 Black and White...
Xerox Workcentre 4150. Paper keeps jamming in print engine area. We clear the jam and it jams again.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. ItemInc.com has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Jun 23, 2011 | Xerox WorkCentre 4150 Black and White...
We had a paper jam in the print engine area. Once the paper path has been cleared we are still receiving clear misfed paper in print engine. I have fed paper through the path and cannot find any paper jam.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Area" you should check and possibly replace the fuser exit actuator (part# 120N00534). Iteminc.com has this part in stock and ships same day. Here is a video the shows you how to check and replace the fuser exit actuator. Good luck, and thanks for using FixYa!
Jun 17, 2011 | Xerox WorkCentre 4150 Black and White...
Do you have any instructions on how to clean a Xerox Workcentre 4150. It is leaving a dark streak down the right hand side of the page on everything it prints, not just copies.
First the to do is a "stop test." You will induce a jam before the paper reaches the fuser (which the the hot thing near the exit). The PN for the fuser is 002N02557.
If the defect exists already then the drum or transfer roller or laser may be causing it.
There are very few things that you could clean except the glass on top or the pick rollers.
Whit
Item, Inc.
Aug 23, 2010 | Xerox WorkCentre 4150 Black and White...
I need to change my Xerox workcentre 4150 toner cartridge. The old cartridge is stuck and I cannot get it out. Any ideas? Thank you. Russ thornock
You have to twist them clockwise and then counter clockwise. There is a locating pin they stick on in back, All I can say is twist and pull.
You can try opening the right side door and sliding a thin bladed screwdriver in there to assist in lostening it .
That is not uncommon and is frustraiting.
Jul 03, 2010 | Xerox WorkCentre 4150 Black and White...
My workcentre 4150 is on my network and sometimes
Check and see if your using the PS driver for that machine, If so switch to the PCL driver. The PS one has been known to run slow.
Mar 22, 2010 | Xerox WorkCentre 4150/C All-In-One Laser...
Xerox 4150 continues to jam on first print - "print engine jam"
Chances are you have a buildup of toner on the charge corotron. This is a part of the copier that charges the drum to accept toner. If there's buildup of toner inside or on the grid of the corotron then the charge will be erratic or excessive and cause the paper to jam as it passes by the drum.
Check your user manual on how to properly remove and clean/replace the corotron.
Aug 21, 2009 | Xerox 4150V_P Printer
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Our XEROX Worcentre 4150 often jams and displays a
In the main door at the top in the middle there is a little black leaver that moves up and down if it gets stuck in the up position it thinks that there is a papper jam just check the little black lever and make sure its down
Jul 09, 2009 | Xerox WorkCentre 4150 All-In-One Laser...
Xerox WorkCenter 4150 Black and White Copier Logo
366 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
