Question about Culligan Sales #SY-750S Under Sink Water Filter
Air tank (underneath house) does not push water out of spigot in sinke or refridgerator.
There is 70 psi of air pressure in the culligan (underneath the house) air tank, but no air pressure comes out of the bottom to push the water through the spigot in the kitchen sink. What should I do if I'm positive that this has nothing to do with the under sink filters? I'm positive that the issue is with the air tank. Thanks for your help, DH
  • jdthefixer May 11, 2010
    See if the pressure gauge on the tank is stuck. They can sometimes fail and appear to have pressure when they do not.
    However, if you have pressure elsewhere in plumbing fixtures, this probably isn't the case. If you have no pressure anywhere, then look for plugging of the discharge air piping from the tank.
    Othewise, look for any blockages in other parts of the system. Can you test for pressure before the sink filter(s)?
I had the same problem on two different systems. Finally a Culligan lady gave me the answer. The tank should have no more than 7-10 PSI when empty, and when the tank fills up with water, it should register no more than 35 PSI. The bladder inside the tank will expand with high PSI to fill the whole tank thus restricting water to fill the tank. Simply bleed off the air at the valve and set the pressure at 7-10 PSI and you will hear water start filling the tank and within minutes water pure water at your spigot:-)
Posted on Aug 20, 2009
  • 13 Answers
You need to test the air pressure with the tank totally empty, remove the tube that is going into the tank and open the tank valve to release all water, if water is in tank and does not come out your bladder is finished and you will need a new tank, if you are able to get all the water out then you need to test PSI again and it needs to be between 7-10 psi, this way when the bladder fills up again with water that pressure will be the ideal 40-50 psi.
Fresh Water Systems | http://www.freshwatersystems.com | 1.877.335.3339
Posted on May 25, 2009
Culligan water machine water is flowing very slowly
The storage tank is probably bad. Shut all the water off to the RO, drain all the water from the RO tank, check the air pressure with a low pressure tire gauge. PSI should be 7psi with a 3 gallon tank. 12psi with a 10 gallon tank.
Add air to tank with a bicycle pump.
RJ
Oct 08, 2011 | Culligan Under Sink Water Filter
I have a Culligan AC 30 aqua-cleer drinking water system;after changing the particle filter and the carbonfilter , the storage tank does not fill.I have pumped air in it to pressure 0,7 bar.
When you put air in the tank did you make sure all the water was out of tank? In a three gallon tank there should be 7 lbs of air, 10 gallon 10 lbs of air.
There can be many reasons for no water in tank.
1. Bad bladder in holding tank. No back pressure on membrane (all water going to drain)
2. Faulty membrane (all the water going to drain)
3. Bad capillary tube (all the water going to drain)
4. Plugged check valve at top of membrane (no water)
5. Faulty water feed valve (piercing valve)
6. Fines from post carbon filter have plugged up the manifold (head) of RO unit.
7. Bad valve on RO tank
8. Plugged drain line
RJ
Jul 30, 2011 | Culligan Under Sink Water Filter
I own an old Culligan RO system with a particulate filter, carbon filter, RO filter and post carbon filter all connected by tubes in an open environment. Replaced filters and tank is only 3-4 years old...
It is quite common to loose air pressure in the RO over time. At times the tank will be full of water but will not have enough air pressure to push water out. Take the tank of drain as much water as possible, for 3 gallon tank bring pressure in tank to 7psi, for 10 gallon tank pressure should be 10psi.
RJ
Mar 05, 2011 | Culligan Under Sink Water Filter
Holding tank doesn't seem to be accepting water.
Either there is too much air in tank or not enough. If the tank feels heavy then air needs to be added. Empty all the water in tank (force it out by feeding air into schrader valve) then set tank pressure to 7psi for 3 gallon tank.
RJ
Feb 27, 2011 | Culligan Under Sink Water Filter
How do i unhook the spigot from my undersink reverse osmosis system i cant get the hose connections to release so that i can take the spigot off the sink. i am putting in a new sink
If they are quick connect fittings make sure all the water pressure is off the lines. Turn off the RO tank and valve feeding system, open the faucet and try taking lines off again. If no luck, mark the lines with masking tape and cut them a couple inches below faucet to remove.
RJ
Oct 24, 2010 | Culligan Under Sink Water Filter
Changed r/o 3 filters and now water produces 2cups
The pressure on an EMPTY tank should be 8-10 psi. Be sure the tank is empty before checking the pressure. A good way to empty the tank is to connect a small air compressor to the air valve on the tank, open the systems faucet, and turn on the compressor. A bicycle pump works too....Just more of a workout:)
Jul 08, 2010 | Culligan Sales #SY-750S Under Sink Water...
What psi should the storage bottle for an Culligan AC-15 water system???
If it is a 3 gallon tank the pre-charge pressure (without any water in the tank) should be 7psi, 10psi for 10 gallon tank.
RJ
Jan 02, 2010 | Culligan Under Sink Water Filter
No flow from EcoWater undersink filtration unit. Flow stopped so we changed two carbon filters and one sediment filter. Still almost no flow.
The water storage has probably lost its charge. A 3 gallon tank should have 7 psi pre-charge pressure. Tank has to be totally empty to set pre-charge. Turn water off to RO, pump air into tank to force all the water out at faucet, turn tank valve off and relieve pressure until 7psi charge.
RJ
Nov 28, 2009 | Culligan Under Sink Water Filter
I HAVE A RO WATER FILTRATION MY PROBLEM IS I CANNOT GET WATER FLOW TO THE WATER STORAGE TANK ALSO I JUST CHANGED THE MEMBRANE FILTER
There may be several causes for this. Here is a list of things to look for.
1. If an activated carbon filter was installed many times carbon fines will plug up the head of the RO housing. Pull the filters out and flush the whole assembly with NO filters in it.
2. The capillary tube (which puts back pressure on the membrane to create water) may be worn out and all the water will run to the drain. Replace capillary tube
3. The automatic shutoff may not be opening to allow for water flow.
4. Shut the water off at RO tank and take the line off from RO filters to see if any water is flowing from housings.
5. The RO tank may also need air. If the air charge is low in tank (7 psi for 3 gal tank) no water can be forced from the tank.
6. If the RO is fed by a piercing valve make sure their is water coming from it.
7. Depending on what type of RO it is their may be a flow restrictor in head of membrane housing that can get plugged also.
I hope these tips may help you,
RJ
Oct 11, 2009 | Culligan Under Sink Water Filter
No water from Culligan Aquaclear AC30 after replacing filters
Try reducing the pressure to 7-10 PSI empty then no more than 35 PSI when the tank is full. This should solve the problem.
Aug 09, 2009 | Culligan Under Sink Water Filter
Culligan Sales #SY-750S Under Sink Water Filter Logo
386 people viewed this question
Top Culligan Home Experts
Donni Steen
Mike
Tim Hunt
Tim Hunt
Level 1 Expert
Are you a Culligan Home Expert? Answer questions, earn points and help others
