Question about RCA F31672ET TV
RCA Model F31665 will not stay on
When I press power on the tv it just turn on turns off turns on turns off and will continue to do this until I press the power button again, then it will shut off.
  • jimpolo Mar 09, 2008
    TELEVISION SCREEN HAS A HOURGLASS SHAPE TO IT. CAN THIS BE EASILY REPAIRED OR SHOULD i GO SHOPPING FOR A NEW TV.
As allthings you need to pay money or there is no help.do you think kindness is for free.
Posted on Jan 12, 2008
How do you program RCA Systemlink 3 RC303-C for Television Model F27255BC
Without codes:
  1. Turn on TV.
  2. Press and hold CODE SEARCH until all device buttons light, release button.
  3. Press TV button. TV button will stay on.
  4. Press POWER repeatedly until TV turns off.
  5. Press ENTER.
With codes:
  1. Turn on TV.
  4. Using number keypad enter code for TV.
  5. Press ENTER.
Nov 17, 2016 | RCA Televison & Video
Do not know how to program the systemlink3 universal t,v. remote control to my t.v.
Option 1:
To clear things up and make it simple, here is how to program the RCA Systemlink 3 remote:
****WITH DEVICE TURNED ON****
  1. Press and hold the "Code Search" button until the LED lights, then release. LED will stay light.
  2. Press and release the device key to be programmed. LED will go off when button is pressed and back on when released. LED remains on.
  3. Press and release the remote On/Off (power) button as many times as required to turn your device OFF.
  4. When device turns OFF, press and release the ENTER button.
Test remote on device, if ALL functions do not work, repeat above procedure.
***IMPORTANT NOTE***Count how many times you press the On/Off button. If ALL funtions do not work and you need to repeat, you don't want to stop at the same non-working code. For instance, if it takes 23 times to turn your device off and after testing, the remote does not control all functions, repeat steps 1-3 BUT when the device turns off at the 23rd time, turn it back on using the power button ON THE ACTUAL DEVICE then continue with step 3 and 4 from above.
Option 2:
Thanks for the hints on your web site. For the RCA SystemLink 3 with the key pad, I could not get the sequences described to work. But they did point me in a direction which worked for my remote:
  • With the TV on (for TV)
  • Press and hold code search until the light stays on
  • Press TV (for TV) button once
  • Press the on/off button once
  • Thereafter, the light will stay lit and every couple to three seconds it will blink twice indicating it is trying another code.
  • When the TV turned off, I pressed enter. Thereafter the unit worked.
May 04, 2011 | RCA Televison & Video
I need code for coby tv-1360, to work with rca systemlink 4
Hello
There is no code for your Coby with RCA systemlink-4 specified. But you can find the stored coed in Coby with RCA remote. Here is the proceedings. Do it and check.
Press and Hold CODE SEARCH button until ALL FOUR device choice buttons light up.
These FOUR buttons DO light up, they are on the SECOND ROW from the top; and from LEFT to RIGHT are named:
SAT-AUX CABLE VCR TV
After ALL FOUR are lit, RELEASE the CODE SEARCH button. All four lights will stay lit!
Select the device you want to control. Press that button ONCE!
The light will stay on for the selected device, the other lights will turn off. Press the OFF-ON button repeatedly until device powers up or down. If device is off and this turns it ON, try channel up or down. If device is turned ON and this turns it OFF, press ENTER and try to turn it on.
If this does NOT work, you don't have the correct code. Go through all the previous steps from the beginning. I actually counted the number of times I depressed the OFF-ON switch, and this helped immenssely! For example, the TV turned Off or On after 19, 45, 76, 94, 115 and 164 depressions of the OFF-ON button.
Of course it wasn't until I hit the 164 mark that it controlled all functions, and is now going great! But I knew NOT to **** around with a number I had all ready tried, and which didn't do the trick the first time!
Remember, when you start from the beginning, it's just that, from the beginning! You'll notice the device turns on or off after the same amount of depressions of the OFF-ON button, but that may not be the code you need.
Again, this is for an RCA SystemLink 4 Remote Control only, NOT for any other model!!
[2]
Without codes:
  1. Turn on TV.
  5. Press ENTER.
[3]
With codes:
  1. Turn on TV.
  5. Press ENTER.
Mar 02, 2011 | Coby Televison & Video
I need help to reprogram this remote. The
Hello, I am sorry i did not get back to you sooner!
I found the manual on the internet, you can just copy and paste into your browser to download a copy for yourself if you like.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&md=rcr4258rcr4358&kw=RCR-4258&st=&ar=&dt=&so=&pg=1&file=others/rca/rcr4358-manual.zip
Here is the simple way of doing it:
0) Turn on TV.
1) Press and hold the TV button, light lights up, continue to hold.
2) Press and hold the power button, light turns off, keep holding both buttons down until light comes back on, release both buttons, light stays on.
3) Point remote towards TV the entire time you are programming.
4) Press and release play button, wait 5 seconds, if TV did not turn off press and release play button again wait 5 seconds. Repeat until TV turns off. (When your TV turns off, it was in the last 10 codes sent).
5) Press and release Reverse button, wait 2 seconds, repeat until TV turns back on.
6) Once the TV turns back on press and release Stop button.
7) Your Remote is now programed! Test it by pressing the power button, volume, mute etc..
Cheers!
Apr 27, 2010 | RCA RCR-4258 Remote Control
How reprogram my universal rca remote control
hold the tv button down and keep it down and then press and hold the power button down and hold them both until the power button stays red then let go of both buttons then keep pressing the power button until the tv turns off and as soon as it turns off press the stop button and it should work.
Aug 31, 2009 | RCA RCR815 Remote Control
I have a RCA remote control (replacement).
I think the easiest way to program a remote is to turn on the tv, press code search and hold down until light stays on. Then press tv button. Continually press power on/off button until the tv shuts off. Hit enter to lock code (on RCA universal) and you should be good to go. The codes can be helpful but are almost always separated from the remote and this random code search allows you to re-progam without having to look for specific codes again.
Jul 17, 2009 | Televison & Video
RCA Universal Remote Model #rcr311w
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Jan 11, 2009 | RCA Universal Remote Control
RCA 31" TV pakes high pitched chirping noise
Did you check the Horizontal Output transistor to see if it were shorted, and also check the MOSFET of the switching power supply.
Jul 25, 2008 | Televison & Video
Looking for programing codes
Turn TV on. Press and hold [Code Search] until LED stays lit. Repeatedly press [CH +] until the channel changes. Press [Enter] to save code.
Dec 13, 2007 | Universal Remote Control Remote Control
Televison & Video Logo
81 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
