Question about Vehicle Parts & Accessories
Black widows 293 just chirps makes noise and hasnt stopped even when i reset alarm
  • 22 Answers
Check two things firstly reposition the earth for the siren or /and the alarm, also is there any chance the siren got wet?
Posted on Apr 23, 2009
My hard wired smoke alarm has had a new 9 volt battery installed and even a second new one installed and is still chirping 4 times every 30 seconds.
On many of the newer smoke alarm installations, all of the units are wired together so that if one goes off, it triggers all of the others so that no matter where you are you will definitely hear the maddening noise of the alarms! And if one of the other units has a bad or weak battery not only will it chirp but so will the others.
Only way around this is to cut any and all wires going to each smoke detector. They will still work because each has its own battery but there will be no more triggering of other units.
Oct 27, 2016 | Cars & Trucks
How do I make my car stop honking when I lock and unlock the car and turn off the ignition?
Hi Joelle
Easy Really!
Find the Honking device thats making the Noise underneath the vehicle and disconnect it!
Put a piece of black tape over the flashing led.
Actually, you probably need to see a company that installs alarms or the supplier of the alarm you are using. Assuming that this was a custom installed alarm and not the one that came from the manufacturer. If it is a standard Toyota Corolla type alarm, then a Toyota Dealership may be able to help.
Alarms often have small dip switches inside the alarm box that allows it to be customised to suit your needs.
Cheers
Jul 16, 2014 | Toyota Corolla Cars & Trucks
My kidde AC smoke alarm I12020 chirps at night then come daylight it makes no noise
Most "chirping" is indicative of low batteries. Perhaps your smokes are improperly wired through a light switch? As to locating, try using a piece of tape over the sound port to change the sound; with these problems there are often more than one causing it. Check also to see if you have any CO alarms that were plugged into a switched outlet. Most of these also have battery backup. Good luck!
Mar 08, 2013 | Kidde Kiddie Ac Wire-in Smoke Alarm I12020
I have a 1996 3.8 liter camaro. I was driving my car down the road when the gages started jumping and i found out that problem it was the battery and aldernater well after i changed them problems i have...
Hmmm, a puzzle.
The only way to disarm these alarms is with
the factory remote or turning on the ignition.
To turn off the factory alarm.
Ok, do you have the remotes?
If so, let's ID the system.
Go to www.KEYLESSRIDE.com & use th fcc #s
on the back of it.
If not try this:
Programming Factory Security on GM Cars and Trucks
Instructions for programming the GM factory security systems that do NOT
disarm from the driver's door key cylinder. This programming is for the
cars and trucks listed below.
96+ Camaro
96+ Firebird
99+ GM Trucks
99+ GM Sport Utility Vehicles
Step #1 Turn the ignition on then off.
Step #2 Remove the radio fuse only (not the fuse that says acc/radio).
Step #3 Turn the key to the accessory position. When you do this you
will get two chirps from the door buzzer. Should you hear only
one chirp, your vehicle does not have factory security and these
instructions do not apply. You need to hear two chirps.
Step #4 Press the unlock switch on the door. This will give 1-4 chirps
depending on the program step. Continue pressing the unlock
switch until you get to the desired chirp setting.
1 Chirp - Security off
2 Chirps - Remote Only
3 Chirps - Factory Setting
4 Chirps - Passive Arming
Step #5 Turn the ignition off.
Step #6 Put radio fuse back in.
Jul 03, 2011 | 1996 Chevrolet Camaro
Abs brakes chirping noise, when pedal depressed,
worn out brake pads and slightly warped rotors. Most brake pads have small steel tabs that touch the rotor at a 90 degree angle when it is time for replacement. if you keep driving on the worn pads, it will stop chirping but that just means the tabs (also called wear indicators) have broken off and repair is about to get very pricey.
Feb 28, 2010 | 2001 Mitsubishi Montero
Replaced 9 v batteries, units still chirping
This is the troubleshooting information from the kddie site. The problem is usually related to an older battery or improperly installed battery. You might also have to do a reset as described below. If battery and cleaning don't work, it might be time for a replacement - short money to keep you and your home safe.
  1. The battery may be loose, or improperly installed.
    Verify that a battery of the recommended type is securely installed. Make sure to use a battery with a use-by date no later than four to five years in the future. Check that the battery is snapped in completely so it cannot be shaken loose. It’s possible that battery connections may not be making good contact with the battery. Disconnecting and re-connecting the battery once or twice will likely fix this condition. On units with a front-load battery, be sure that the battery compartment door is closed completely as well. Loose white neutral wire can cause an echoing chirp. (From one unit to the next)
  2. The smoke alarm sensing chamber may be dirty.
    Dust and insects can collect in the sensing chamber of the alarm. An accumulation of dust in the sensing chamber can cause the unit to chirp. It is good practice to clean the smoke alarm when you change the battery. Static electricity from the ac quick connector attracts dust and can cause false alarms.
    Cleaning smoke alarms:
    To clean your alarm, remove it from the mounting bracket as outlined here. You can clean the interior of your alarm (sensing chamber) by using compressed air or a vacuum cleaner hose and blowing or vacuuming through the openings around the perimeter of the alarm. The outside of the alarm can be wiped with a damp cloth. After cleaning, reinstall your alarm, verify the green LED is on and test your alarm by using the Test Button. If cleaning does not restore the alarm to normal operation, the alarm should be replaced.
  3. Check environmental conditions:
    • Humidity, steam and condensation can cause false alarms. Causes of condensation are:
      • Extreme temperatures changes.
      • High ambient humidity.
      • Unit being installed in an uninsulated electrical box mounted on a ceiling beneath an attic. If this condition exists you’ll want to move the alarm. Click here to see the correct alarm placement in your user’s manual found in our Download Center.
    • Check to see if there is a cooling/heating register, a ceiling fan or an open window within 3 feet of the alarm. If there is, move the alarm away from the source of the increased airflow. Click here to see the correct alarm placement in your user’s manual found in our Download Center.
    • Check the temperature of the room. Smoke alarms operate at 40 degrees to 95 degrees Fahrenheit. Carbon monoxide alarms operate at 40 degrees to 100 degrees Fahrenheit.
  4. Reset the alarm.
    Some current model smoke alarms have a processor that retains certain error conditions, such as a weak battery. The error condition should reset when the battery is replaced but sometimes it does not and must be manually reset to clear the error.
    To reset an AC unit with a battery backup:
    Turn off the power to the smoke alarm at the circuit breaker.Remove the smoke alarm from the mounting bracket and disconnect the power. Remove the battery. Press and hold the test button for at least 15 seconds. The unit may chirp or alarm for a few seconds before going silent.Reconnect the power and reinstall the battery. The unit will chirp once when the power is restored and should not chirp afterwards.
    To reset a DC only unit:
    Remove the battery. Press and hold the test button for at least 15 seconds. The unit may chirp or alarm for a few seconds before going silent.Reinstall the battery. The unit will chirp when the battery is first connected but should not chirp afterwards.
  5. An electrical condition may be causing the power to the unit to be interrupted.
    If the AC power to the unit is interrupted, the unit will chirp when the power is restored. This could be caused by power surges.
    If the chirping seems to occur at about the same time in the evening or morning, it could be due to a surge created when the power company switches electrical grids to meet demand. Check to see if the chirp (or chirping) occurs when something else in the house is turned on such as an exhaust or attic fan, a heater, etc. If the smoke alarm is connected to a circuit with such a device, the alarm may chirp when the other device is switched on. If this is the case and the device is plugged into a wall outlet, move it to another outlet on a different circuit. If it is a hardwired device, have an electrician investigate it. These conditions can be minimized by installing your alarms on a dedicated circuit in compliance with NFPA requirements.
  6. Replace the alarm.
    If none of these conditions exist and the suggestions don't alleviate the symptom, the alarm should be replaced. Age may be a factor. Smoke and heat alarms should be replaced every 10 years, and carbon monoxide and combination alarms should be replaced every 7 years. Most of our alarms have a 5 year warranty from date of purchase (check your user manual for details). A date code is stamped on the label attached to the back of the unit.
Feb 02, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Smoke alarm keeps chirping.
I am having problems seeing if you have any more data besides "smoke alarm keeps chirping." so I will ask; have you tried changing the battery?
Sep 06, 2009 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Car alarm installed. Car wont start.
im sure you cut the starter wire in the ignition switch. usually white. put it back and check. if it starts check the programming configuration of the black widow
Jun 03, 2009 | 1995 Jeep Grand Cherokee
Does not cherp
Is your perhaps alarm in "valet mode"? I've got a Checkmate on my Honda, and I can turn valet mode on/off by putting the key to Accessory, then pushing the black button under the left of the steering wheel. The alarm chirps when you switch the mode.
May 23, 2009 | 2000 Buick LeSabre
Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Sep 13, 2007 | Samsung PCL5415RB 54" Rear Projection...
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
