Question about Canon S520 InkJet Photo Printer
Canon s520 printing is skipping
I just replaced my black cartridge and when I go to print, the text comes out "doubled vision". Somes lines are ok and then others only print out the top of the character or the bottom, making it appear like double vision.
    President:
  • Canon Master
  • 2,022 Answers
Try to clean with tissue paper and see the nozzel of catridge is dust free bye
Posted on Sep 24, 2007
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
I have a Canon pixma mp990 Recently it has stopped printing with the larger black ink cartridge that is meant for printing text (PGI-220BK) All the other cartridges print fine I was using a non-canon...
It looks to me that your non Canon cartridge has blocked the print head. I see this all the time. Remember the compatables are not pigment based but just watered down ink so you can get it to flow through a syringe into the cartridge. This however is the classic outcome of trying to save a few pennies on an expensive bit of kit!
Jul 30, 2011 | Canon Office Equipment & Supplies
My x3350 double prints text. It will overlay each sentence on itself. When I print worksheets on excel every other vertical line will be double-printed. I've tried to uninstall and reinstall the...
This may be a cartridge misalignment issue. First try printing with the settings changed to black and white print only. If this does not work then print in fast or draft mode (this should print in a single pass with less ink. Normal or best quality is usually done by passing the cartridges over the line twice.
Run the cartridge alignment test and see if it can be correctly aligned.
It could also be that the belt that moves the cartridge holder is loose and so two passes of the print head are misaligned. This may not be repairable (at least not economically).
Feb 20, 2011 | Lexmark X3350 All-In-One InkJet Printer
Is there away to fix my printer? It skips every third line of print.
I would first try deep cleaning the nozzles throught the printer maintenance software. If this doesn't work, remove the cartridges from the printhead, remove the printhead and carefully soak it in warm distilled water. you may have to soak the printhead a number of times until the water is clear. Dry the printead carefully. Let the printhead dry overnight. Reinsert the printhead, cartridge and try printing. If it was a clogged head, printing should be normal. If you still have the problem, you will have to replace the printhead. Check with Canon support or try dBay for a new printhead.
Dec 07, 2010 | Canon S520 InkJet Photo Printer
I have replaced the black ink in my canon s520 but printer will not print out black
Please check the seating of black ink cartridge. It may not have been placed correctly. Please replace it and then carry out the print head alignment.
Aug 04, 2010 | Canon S520 InkJet Printer
Canon S520 Printer won't print black!
Hi.
Remove Black cartridge,
make sure its not dry, if that's ok make sure that the small air vent is not blocked (hard to find sometimes)
Dec 30, 2017 | Canon S520 InkJet Printer
Printer creating white lines that distort output
Hello loyasq,
You should do :
1st; Try to fix that by the device's Appliaction
smthing like that
2nd; Uninstall every application for this device and re-install it again.
3rd; If your printer have 1 Cartridge for all colors, Cleanse the part of ink output (the nozzle of ink cartridge) with wet tissue.
Thx for using FixYa.
Apr 15, 2009 | Dell Photo 964 All-In-One InkJet Printer
While printing photos my printer has white vertical lines
Sounds like you need to re-align the print cartridge . The reason the text comes out ok is probably because it is only using the black cartridge for text. The color cartridge is the one that's out of alignment. You may have some sort of Cannon utility running in the task bar that will allow you to easily allign the print cartridges. If not, go to the main "Printers and Faxes" window, RIGHT-click on the printer and select "Properties". You should be able to find a button in the properties that's labeled something like re-align print cartridges. It will print out a series of test pages and ask you to select the set of lines that looks the straightest and type it in. It's a good idea to do this every time you replace a cartrige. Hope this helps, If I was able to FixYa, please remember to rate me. Thanks.
Feb 22, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Canon S520 InkJet Photo Printer Logo
249 people viewed this question
Clive
Clive
old marine
old marine
