Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
Standby light blinking
Television was turned off, three hours later when tv was turned back on light was blinking and no sound or picture.i bought the tv on 02/05 and have never had a problem with it before
  • Carl007 Nov 30, 2007
    hey I am having this same problem and my Technician told me I need a new computer board for my Tv.
    Is this true?
  • Sony Master
  • 8,617 Answers
How many blinks is the light blinking in between pauses?
Posted on Jan 27, 2008
BLINKING STANDBY LIGHT AND NO POWER
there is a possibility that the power switch capacitor has bubbled or leaked a remedy is to unplug the unit from the outlet for at least an hour then try to power it back on.
i will try to look for more information about other work-around's or which of the other parts are defective or almost defective, that is causing the problem.
Jul 30, 2008 | Sony KP-46WT520 46" Rear Projection...
Red standby light came on and no picture sound is ok .Next. time tv came on it played approx one hour everthing ok. then the picture gradually faded away . Red standby light came on again. Still no...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 08, 2011 | Sony Televison & Video
Was watching TV, heard a pop and the screeen went black. Now when I turn it on, the pwoer light blinks green but their is no picture or audio. The light then starts blinking red
Is is standby light blinking red or any other light? Let me know how many times red standby light blinking after three seconds long pause to provide you helpful info.
It seems pop sound was due to broken lamp, please check lamp inside tv and if it is broken, replace it to solve tv problem.
Hope this will help.
Thanks.
Mar 09, 2011 | Sony KDS-50A2020 Television
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Samsung HDTV 52" Flat Screen
Sound like the power supply with a bad capacitor.
Dec 13, 2007 | Samsung SP42P2S Television
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
101 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
