Question about HP OfficeJet 6210 All-In-One InkJet Printer
Where the hell do I plug my computer into an officejet 6210
I am trying to print from an officejet all in one 6210, it is not connected to a computer and I have no idea where to plug it in at and where the plug goes. Or actually how to print from a computer to this printer
  • HP Master
  • 3,866 Answers
Ok check to see if its USB if it is you need to buy a USB cable and plug it into the USB port on the computer. some are wireless witch you need a wireless ethernet card to access them. Check the back for any plugs for USB.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 22, 2009
    Problem Solver:
  • 4 Answers
Usb cd radio shack
My HP Officejet 6210 has a message reading "Remove
Check that the HP all-in-one print queue is not paused (Windows) or stopped (Macintosh). If it is, choose the appropriate setting to resume printing. For more information about accessing the print queue, see the documentation that came with the operating system installed on your computer.
Check the USB cable. If you are using an older cable, it might not be working properly. Try connecting it to another product to see if the USB cable works. If you experience problems, the USB cable might need to be replaced. Also verify that the cable does not exceed 3 meters (9.8 feet) in length.
Mar 05, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Lost printer icon when trying to print....no connection
Disconnect your printer off your computer then try restarting your OS. The printer should be detected if the printer software was installed properly prior to the issue, if the printer will not be detected, try checking the physical connections.
Jan 07, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I have the HP Officejet 6210, it prints but will not scan
If you are flat bed scanning then try this....Try scanning through the top feeder instead. Mine has had this problem before and it has solved it.
Dec 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 6210 will not copy, scan or fax. It will print documents from the computer. Any attempt to do the other 3 functions results in it being "busy" and cannot cancel, have to power it off.
Well if it is printing,the drivers are working fine.The copying,faxing and scanning mechanism use the same scanner to copy the image.It seems to be a problem with the scanner mechanism on the printer.Try a reset using the # and 6 buttons while plugging in the power cord.If it works well and good.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 6210 and Vista
Download the Vista drivers from www.hp.com
Jul 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Scanner doe not work,fax and print are ok
first re-install product driver properly then try.
Jun 03, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Hp officejet 6210 won't print
Perform the following steps:
a) Turn the printer on.
b) Open the printer’s top cover.
c) After the print cartridges have moved to the center/home position of the printer, unplug the printer’s power cord from the electrical outlet.
d) Remove the print cartridges.
e) Using a dry, lint-free, clean cloth, wipe the print cartridge contacts, from the top to the bottom
f) The contacts inside the printer may also require cleaning. Using a dry, lint-free, clean cloth, gently wipe the contacts, from the top to the bottom
g) Plug the printer's power cord into the electrical outlet.
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Now, perform the following:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Mar 30, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Owners manual for HP OfficeJet 6210 All-in-One
If I give you the link to download a HP OfficeJet 6210 All-in-One manual then I'd say thats FixYa
Nov 20, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
111 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
