Question about HP Pavilion dv1000 Notebook
HP Pavilion dv1000 laptop turn off suddenly and cpu fan is working ok. after goes off is hard turn on again, not is battery neither ac adapter but i have seen that many people has the same kind of problem, some time turn on and keep working ok many days but any day could turn off again without apparent reazon. have some one found the cause of failure. thanks
  • 371 Answers
If this happens while you are using it, then that's one thing.
We will get to that later.
If it happens while the unit is just sitting there, then that's another thing.
You probably have an energy savings setting problem that you can easily resolve simply by going into the My Computer equivalent and reconfiguring your length of time prior to shutdown of either the display and/or the hard drive.
Find the "DISPLAY" Icon and click on it and you will find a variety of energy saving routines which you can set to the amount of time that the unit will stay on, even though not in use, after which it will shut down to save energy and wear and tear on your components.
Now, as promised, if this occurs while your unit is in use and just shuts down while you are typing, then your unit requires service by a professional as there apparently is some kind of shortage which with further use could damage your unit.
I hope this helps, but if you have further questions, feel free to ask.
Posted on Apr 22, 2009
Pavilion dv 1000 battery adaptor
You may take it to a tech center to fix it or buy a new charger. As for the cost, it is almost the same. So it is better to get a new adapter.
Replacement HP Pavilion DV1000 AC Adapter 65Watt 18.5V 3.5A
Nov 22, 2012 | HP Pavilion dv1000 Notebook
HP DV1000 won't run normal after a forced shutdown
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Oct 28, 2012 | HP Pavilion dv1000 Notebook
It wont come on. it wont turn on
Try a hard reset. Sometimes it works and is always the first step to take.
Remove the battery and the ac adapter plug from the laptop.
Press and hold the power button for fifteen seconds.
Install either the battery and A/C adapter .Now just press the power button to attempt a boot into the OS.
Contract for further instructions.
Hope this helps.
Oct 07, 2011 | HP Pavilion dv1000 Notebook
Hp pavilion dv1000 fan not working
Try to clean your fan with anti rust oil, maybe due to old age the mechanism inside your fan is already clogged.
http://podnutz-hdlaptoprepairvideos.blogspot.com/
May 26, 2010 | HP Pavilion dv1000 Notebook
My hp pavillion was no power without ac adapter
if the pc is not getting power without the ac adapter then most likely the battery is dead if it does not take a charge via the ac adapter then then the battery is no good or the ac adapter is busted
Apr 28, 2010 | HP Pavilion dv1000 Notebook
Laptop wont boot and the battery and power lights flash
a simple power cycle might work. Take out the battery but keep the ac power connected. hold the poewr button down for 1 minute. then hit the power button again and it should poewr back up. If this doesn' t work. iyou said hte battery light flashes so the problem isnt the battery..the problem might be hte ac power adapter..if you have a warranty this would be a good time to call them. Try the power cycle first though this fixes the problems lots of the time
Apr 15, 2009 | HP Pavilion dv1000 Notebook
Charging problems
Hopefully the battery is just confused and needs to be reset. Drain the battery down until the system shuts off automatically, then take the battery out of the laptop for two minutes and plug it back in, and connect the AC adapter, let it charge without turning the laptop on, then turn it on and hopefully it should work fine again. If not then you may need to buy another battery. Try again with another AC adapter just in case because you don't want to replace your battery (expensive!)
Please rate, thanks!
Mar 31, 2009 | HP Pavilion dv6000z Notebook
How to change the fan
Yesterday, I had my DV1000 open to upgrade my CPU, (same area as your fan). From this link
http://www.fixya.com/support/p381326-hp_pavilion_dv1000_pt111av_pc_notebook/manual-3305/page-136
I printed .pdf pages 127-130; 133-136, 140-142; 145-147; 155-156 for my work plan.
Something to consider: my hsf has two different thermal pad materials, your's might also
Jan 28, 2009 | HP Pavilion dv1000 Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
Blue-screen crashes
i suspect the cpu and or fan is defective
Jan 09, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
651 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
