Mitsubishi vs-4541 won't turn on
I have a Mitsubishi vs-4541. While i was watching it, the set turned off. When I try to turn it back on, it clicks but will not turn on. I've not had any luck finding a service manual and it's hard to find advice on what to do, any recommendations would be appreciated.
    New Friend:
  • 58 Answers
If you are a technical person, this is for you
check for IC9A1 and look for any shorts,
that's located in the main board
Posted on Apr 24, 2009
I have a mitsubishi vs-50605 and when i turn it on the light comes on and clicks and the instantly clicks and shuts back off, I pushed the menu input buttons for five seconds and got one blink then two...
1,2 is no error detected---if during or before this you unplugged the set that clears the errors and you will get 1,2.
To confirm with set plugged in turn it on--when power light goes out repeat the self check.
May 15, 2012 | Mitsubishi VS-50605 50" Rear Projection...
My mitsubishi vs-4541 clicks like it is turning on but the power light doesnt come on and neither does the tv
a old set-----power supply problem or bad solder connections in one of several areas of power or deflection boards--very common on this set---unless something easy it is not worth a shop repair as many of the parts used are no longer available.
May 15, 2012 | Televison & Video
Completely black screen but has sound.
you probabily need to change the input, find the input button, when you hit it you should get a box on the screen, with inputs, highlight diferent ones and hit select- untill you get pick back, thats what my sugestion would be
Jan 11, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-4541
clean it out it is over heating, use a air hose to blow all the dust out
Sep 01, 2008 | Mitsubishi VS-45607 45" Rear Projection...
TV keeps shutting off
Push the menu and inputs buttons on the set in both together and hold for 8 seconds this should make the led flash a two digit code. Let me know what happens after doing this test.
Apr 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-4541 too much red
The set is old and the picture tubes are probably weak. you can pop off the front grill, remove the protective panel to expose the picture tube sockets. On the sockets are controls to increase or decrease the intensity of the colors. The red is on the left ,green center and blue right. Go to a B&W picture or turn the color off, then adjust for the best grey screen.
Jan 03, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source
Jul 28, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Trouble with my Mitsubishi VS 50609
Make sure you have no colent leking on the bord these set many I worked on had colent leaks that cused it to shut down. does the set come back on when it's cool? could be a bad soder joint. allso there could be bad caps. deos it come back on if you unpluge the set for 5 sec and plug back in that resets the set.
May 21, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Open Questions:
Televison & Video Logo
133 people viewed this question
Top Televison & Video Experts
Electro Med Services...
