Question about Microsoft Wireless Laser Mouse 6000 v2.0
Mouse won't track anymore
The cursor on my mouse won't move, but all the other buttons on the mouse still work and the keyboard works fine.  I've only had it for a week and I've tried reconnecting and changing batteries, but the cursor still won't budge.
  • 1 more comment
  • Anonymous Apr 23, 2009
    No, I have the mouse with an invisible laser
  • haydenivy May 10, 2009
    I have the same exact problem. I have changed the batteries 20 times. Sometimes if I reset it, like push the button on the USB port.. let it blink for a few seconds, then push the white button underneath the mouse it would start to move again.
    BUT recently it won't work when I try that. I paid 50 bucks for this mouse with the determintaion of "you get what you pay for" and I have gotten crapped on with it. =(
  • Lee May 11, 2010
    is the red light underneath still illuminating?
SOURCE: Microsoft Standard Wireless Optical Mouse does not move cursor
Your batteries are likely dead.....replace them and try it. Should work.
Posted on Apr 02, 2008
IrishDruid
  • 2712 Answers
SOURCE: No mouse cursor visible on monitor
Could be spyware, virus or a failing hard drive.
Download Ad-Aware® SE Personal Edition, a free program that you can download at:
http://www.lavasoftusa.com/support/download/
Check for updates before running program. Then follow the directions here to do a full scan:
The following explains how to set Ad-aware's settings to perform a "Full Scan."
In Ad-aware click the Gear to go to the Settings area.
The following items should be on a green check, not on a red X.
Under the Scanning button:
Scan within archives
Under Memory & Registry, Check EVERYTHING
In Check Drives & Folders, make sure all of your hard drives are selected
Under the Advanced button, check ALL under Log detail level (this makes it easier for visitors to the Lavasoft Support Forums to see what options you have selected should you require assistance.)
Under the Tweak button...
Some of these may not be an available option, depending on your version of Ad-aware and your version of Windows. Do not be concerned if you cannot select a certain item.
In Scanning Engine:
Unload recognized processes during scanning
Include info about ignored objects in logfile, if detected in scan
Include basic Ad-aware settings in logfile
Include additional Ad-aware settings in logfile
Include used command line parameters in logfile
In Cleaning Engine:
XP/2000: Allow unloading explorer to unload shell extensions prior to deletion
Let Windows remove files in use at next reboot
UNCHECK: Automatically try to unregister objects prior to deletion
Click Proceed to save these settings. When you would like to perform a "Full Scan," switch the scan mode from SmartScan to Custom.
After running Ad-aware, you must reboot your computer. It may be necessary to run Ad-aware two or three times if you have a lot of spyware, rebooting each time in between.
Where it says,"In Ad-aware click the Gear to go to the Settings area", on the top of the Ad-aware window, there are 5 symbols, click on the one that looks like a gear.
Go to: http://sarc.com/ Scroll down and click on,"Free Online Virus and Security Check" Write down exactly anything it finds, then return to: http://sarc.com/ and do a search for what was found. Symantec usually has a removal tool and/or directions for removing. manually.
Regarding the Hard drive, check out what PCWorld offers at:
http://www.pcworld.com/howto/article/0,aid,105869,00.asp
Hope this helps!
Posted on Apr 17, 2008
IrishDruid
  • 2712 Answers
SOURCE: keyboard
Hello ARRG,
It looks like the problem is with the keyboard, and not the mouse. To verify, try the k/b on a different computer. If the issue occurs there as well, it means the k/b is defective and you may have to replace it.
If however, it functions well on the other PC, then it could be a problem with either the port or the driver, or the keyboard itself.
First try the k/b on another free port, if available. If it works OK, then the original port is damaged and you will need to take the PC to a competent technician to get it fixed.
Next, try to download the latest drive for your keyboard and install that after uninstalling the older version. If this does not work as well, consider buying a new keyboard....I always recommend the corded variety, as they are more reliable.
Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
"Discover How to Achieve Your WILDEST DREAMS"...Free Download
FREE SOFTWARE GIVEAWAY
Windows Utilities - Software Street
Posted on Apr 23, 2008
SOURCE: MS wireless notebook mouse 3000 not working?
A friend of mine brought me this problem with exactly the same problem. here is what I found. The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
Posted on Aug 22, 2008
yooperbud
  • 8637 Answers
SOURCE: Microsoft Wireless Notebook Optical Mouse Not Connecting
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Feb 17, 2009
Mouse does not move cursor, button works though
It could be the light, but have you tried using a different less reflective surface?
Feb 17, 2014 | Quill AirObic Mouse - Right / Left Hand
Tip
Mouse pointer with keyboard keys
<span><b>You can control your mouse pointer with keyboard keys in all windows versions. When your mouse stops working, you can enable this keyboard feature to complete your important work. This keyboard mouse can performs all tasks same like a normal mouse.</b><br /><b>Follow the given steps to activate the keyboard mouse:</b><br /><b><br />To edit this feature, first you should log onto your computer with administrative rights.<br />To activate this feature, press Alt+Shift+NumLock keys at once and you will receive a small MouseKey box.<br />To keep MouseKeys on, click on Ok button or click on cancel button to cancel MouseKeys box.<br />Click on Settings button, if you want to adjust the mouse cursor detail settings.<br />Here a new dialog box will appear with the title Settings for MouseKeys", now you can manage all mouse settings for example mouse cursor speed, acceleration and some other features.<br />Now using Numeric keypad, you can move your mouse pointer. The controls are:<br />*<br />1,2,3,4,6,7,8 and 9 keys are used to move the mouse cursor into different directions.<br />*<br />Key 5 is used as mouse click button.<br />*<br />Insert key used to hold down mouse button.<br />*<br />+ Sign used to double click on any object.<br />*<br />Delete button used to release the mouse.<br />*<br />Click on NumLock button to disable this keyboard mouse feature</b></span>
on Apr 04, 2011 | Computers & Internet
I have a uniden wireless mouse and it won't
here ur pc is recognizing ur external hardware that is mouse but cursor is not moving this indicates that bluetooth connection is good and problem comes with the mouse. i advise to meet a good technician and there is nothing to do with it further.
Jun 28, 2013 | Computers & Internet
My trackball mouse will only move the cursor one direction
remove the ball ring take the ball out and visually check to see it alot of link has accumulated on the rubber wheel surface, if it has gently use a pair of tweezers or a q-tip w/alcohol to clean the surface of the directional wheels.
Dec 05, 2009 | Fellowes Micro Trac 99928EA Mouse
Lost function on wireless mouse model kb990w
try to clean your mouse. Open and get the mouse track ball and try to remove the dust that may have accumulated on the bars holding the track ball.
Regards!
Jul 10, 2009 | Micro Innovations KB990W Keyboard and...
Mouse cursor moves, but mouse clicks do not register
1st mite have a virus or you need to redownload the driver for it try rebooting it .
Apr 14, 2017 | Logitech Wireless Access Duo Optical...
Logitech v220 cordless mouse - worked fine for 6 mths - recently changed battery. worked fine. today, would not move cursor when on a white / light surface (although it has previously just fine). It...
Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
Jun 17, 2009 | Logitech Cordless Mouse
Mouse stopped working, but appears ok, batteries ok, can't determine problem
Is the batteries good. If so try,
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jun 08, 2008 | Logitech Wheel Mouse Optical
Pairing my Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Oct 03, 2007 | Macally BTMicro Mouse
Trouble pairing my bluetooth Macally BT micro mouse
Microsoft Wireless Laser Mouse 6000 v2.0  Logo
208 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
