Question about Whirlpool Dryers
I have a whirlpool LER6620PQ electric dryer. when
I have a whirlpool LER6620PQ electric dryer. when I push the start button the drum will not turn, but the heating element gets very hot is seconds. Too hot to touch the proective screen
textonor
  • 130 Answers
SOURCE: whirlpool Cabrio electric dryer
ctwoods, this sounds like the heating element has shorted to the heater can. What that is doing is leaving the element at 1/2 power on all the time. If this happened, then the heat kept going up until it blew the thermal fuse which caused the motor not to run. So check the heater and any fuses in the dryer. You can go to Service Matters for Whirlpool Service Manuals on this model.
Posted on Feb 03, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Dryer Motor Removal
stand that baby up!!! acess is from front, try removeig 2 screws from under lint filter and then pop top with screw driver lean top back.. youll see the tub and belt(if not broken right there),no belt??? order a 341241 whirlpool dryer belt. 2 5/16screws on either side of iside facade remoivefront caver, disconnect door switch and remove front panel. belt slips over drum , you need to reset tension pulley and wrap around motor shaft. .
Posted on Feb 26, 2008
  • 156 Answers
SOURCE: Newer Whirlpool Dryer Heat Element keeps breaking
  • clean out the dryer vent make sure hose behind dryer not pinched close ck the temp comeing out bac k dryer should be around 160
Posted on Mar 06, 2008
  • 659 Answers
SOURCE: whirlpool dryer not blowing hot air
The element is at the bottom of the unit. Usually they are located on the right bottom but when you take the housing off, you will be able to see it.
Posted on Apr 11, 2009
hiltonjug
  • 612 Answers
SOURCE: LER4634EQ2 whirlpool electric dryer. heating
I know this might sound stupid but try this. Find your fuse box, locate the breaker that runs your dryer. Flip it off and then back on. If i'm correct, it will work. Everything on your dryer works off of one leg of the 220v. The other leg goes to the other side of the element. If you have a meter. check for 220v at the plug. Everything you listed is what makes the dryer heat other than the thermostats. Check the cycling thermostats like you did the other pieces. They look like the thermal cut off. They have two wires and they are round.
Posted on Oct 10, 2009
Push start button but drum does not turn. All the display controls look as if they are working. I can hear a click when I press the start button.
if the contro panel lights up but the drum will not turn ,unplug unit remove toe panel and check thermal fuse for the motor right in front has two blue wires going to it
Jul 18, 2010 | Whirlpool GEW9250 Electric Dryer
Push the start button, timer is working but the drum is not turning. I can turn the drum by hand.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 01, 2010 | Whirlpool LER5636P Electric Dryer
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
Whirlpool Electric dryer won't start
Your problem sounds like it could be a broken belt, faulty motor, or maybe the belt has slipped off of the motor or idler arm pulley.
You can try this first:
Uplug the dryer, reach inside and try to turn the drum 1/4 to 1/2 turn, the plug the dryer back in, and push the start button. Sometimes motors will get dead zones in them and this will move it from that zone.
If you attempt the repair, and if you have a front loading machine, you would remove the front of the machine, this will expose the drum and belt, you can now check the belt to see if it is ok. If it is ok, then you can remove the drum and belt and this will expose the motor, idler arm with pulley and drum rollers.
While you have the drum out of there it is a good time to check the condition of the drum rollers to see if they have flat spots on them, if they do have flat spots on them, then need to be replaced. If not then I recommend that you lubricate them at the shaft with a good grade of Machine Oil such as 3 in One oil. This will save problems later.
Good luck,
I hope this helps you
Oct 04, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
105 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
