Question about Crosley CE35111AA Electric Kitchen Range
What does "F1" mean? The oven is out!
I was cooking on the stovetop this morning when the thing starts beeping like the timer is going off... but the display says "F1". Even when the beeping stops, the only way to get the clock to show back up again is to lock then unlock the oven. But the oven won't even come on! I can't set the timer, or the clock either. Seems the whole control panel is out of whack. If I leave the F1 warning on the screen,it won't beep anymore, but as soon as I get the clock to show back up, it starts beeping F1 again! Help!!
  • superman123 Sep 24, 2007
    I did try to reset the main fuse, but that didn't work either.
  • Anonymous May 05, 2008
    SOLUTION :
    One must unplug the range unit for several hours to allow the memory chip to clear itself ...
    The F1 event is caused by a power shift either up or down
    Good luck ...
  • 473 Answers
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
Posted on Oct 06, 2007
Hii i have kenmore kitchen range and itz givin a F1 error and keep beeping please help me out with this beeping sound is so anyoing
Hello there:
Here is the code and what it means read the code i have provided and what needs to be donte to repair it ok but first here is a thing you can try first unplugthe oven for 1 hr to let the internal memory module reset itself then try it again if you get the same code than here is what is wrong
F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERCplease keep me posted on how this is going so i can assist you more if you need to get parts or some thing else ok
Best regards Mike
Jan 01, 2011 | Kenmore 72002 / 72004 Kitchen Range
Display panel on stove not working properly, cannot use the oven
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
&^%$tr
Jan 11, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven showing F1
kenmore digital stove is clicking when cooking in oven
Apr 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I get an "F1" code on my Maytag range.
you need a new temperature probe. its usually located in the upper left hand corner in the rear of the oven.
Mar 19, 2009 | Maytag MES5570 Electric Kitchen Range
Range GLP 85800 toop cook ok, flashing E1 -F1- and a few segments
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Jan 26, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Error code F1 and beeping
Means replace the $300 control board. And if your like me.....do it twice within 12 months.
Jan 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
Oven timer goes off when not being used
I have the same problem with the beeping and screen flashing F1 does anyone have a solution yet?!
Aug 22, 2006 | Magic Chef 9512 Electric Single Oven
Crosley CE35111AA Electric Kitchen Range Logo
1,159 people viewed this question
Top Crosley Kitchen Ranges Experts
freddyfox
Lawrence Oravetz
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
