Question about Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
OUT OF RANGE MESSAGE ON PHONE
I picked up the extension and had the message "out of range" - no dial tone. I reported the problem to AT&T and have not heard anything yet
  • rvitali469 Apr 22, 2009
    It is a Uniden 5.8 GHz digital. I cannot find a model number. There is an 800 number for Uniden, but customer service is closed.
  • 3,866 Answers
Ok check the battery and see if its weak! Check the unit where the cordless sits the master unit and change the channel to a diffrent one. some channels are weaker then the other and somtimes batteries are the problem.
1. Check batteries
2. change the channel on the master the ext will sence the change.
You did not tell us any more info about these phones like model number or how many GHZ it is and that is important if you want a good solution.
Thanks
Posted on Apr 22, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Apr 22, 2009
    Try th above things? Did they work? if my information was any helpful to you please accept and vote thanks.
    Without the model number it would be hard to locate the proper instructions to switch the channels.
Have out of range of base message
does the base unit have a dial tone . if no then you need to contact your land line phone company of course assuming you have it plugged into a phone line coming into the home
Dec 22, 2015 | Vtech Lands Phones
HP LaserJet 3055 .fax not working
Direct Line:
1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
Dial the number and observe weather extension phone is ringing?
A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
B. *Extension phone is ringing no message displayed on device replace "LIU" card..
If extension telephone is not ringing check telephone line..
No out going faxess:
*Check line is connected though EPABX , if connected Check..prefix setting..
*Check out going..
Best of luck...
Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
Unable to make calls no dialing tone and message on phone range out!!
unplugged phone from mains then switched back on
Oct 01, 2009 | Lands Phones
The New Voice Mail message appears and the light blinks and there are no voice mails.
What system? A Panasonic KEY SYSTEM (76xx/77xx/74xx/72xx phones) can have messages from other sources than the VM system.
If it's a display phone, try pressing the MESSAGE button without picking up the handset and read the display. It will tell you where it came from and you can press INTERCOM and ring that extension.
It works the same way if you call an extension and press the MESSAGE button...that leaves a message. Panasonic systems have a MW cancel code that usually begins with 700. In a TA system it's 700#, in the TDA/TAW's it's *700 plus your extension.
If it's a Panasonic cordless, it's probably hearing stutter dial tone from custom calling features.
Carl
Sep 27, 2009 | Panasonic Lands Phones
Uniden powermax 24 out of range
Check the line comming into the main handset base. Make sure it is not cracked or your cat hasn't chewed through it.LOL This sounds like the most likley solution. Try hooking the main phone line to an ordinary old fashioned touch tone phone with a wired handset and if that is working then the problem lies in the main base of your new phone. It could be as simple as reprogramming the base.
Jul 24, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
CHANGE RECORDED MESSAGE
To change the greeting you need to either pick up the phone or press speaker phone then dial *38 then 1 then you will hear a beep/call tone. When you hear that tone record your message/greeting. Once you are finished press the auto dial/store button. If your are satisfied with that message hang up or press speaker phone again to end the call. If you would like to clear the message, then right after you hit auto dial/store you will hear a beep/call tone press 0 to clear or 1 to rerecord.
Dec 08, 2008 | Panasonic KX-T7630 Corded Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
