Question about JVC AV-48WP30 48" Rear Projection Television
JVC AV-48WP30 has vertical lines every inch or so...
Recently, my JVC AV-48WP30 started displaying vertical lines every inch or so from the top to the bottom of the screen. They're very, very narrow (about a "pixel" wide, if you will) and affect every input on the unit, including the DVI, component, TV (RF), and S-video inputs. They "modulate", in that they change color, slightly, and intensity, almost like an amplifier or transistor is "clipping". Mostly, they appear white on dark backgrounds and vice versa, and the lines are not solid top-to bottom, but rather like some pixels are on and off in each line. They do not shift side to side at all, and always run full top to bottom. They do _not_ appear on the onscreen menus, however, only on the tv signals. I have _no_ idea what could be wrong, however, and no idea as to where to start looking. Any help would be most appreciated.
  • 2 more comments
  • CameronE Sep 27, 2007
    The problem lies in the I/P module, which is, unfortunately, a black box according to the service manual (and way, way overpriced to replace).
    Opening it up reveals a very densly populated smd board, and the case is soldered through, making repairs very difficult.
    Seems like something in the filtering circuitry on that board has gone south.
  • Anonymous Nov 26, 2007
    CameronE,
    I have the exact same problem as you mentioned except the lines are only on the left 12in or so of the screen. Its not that noticeable with standard input but is pronounced although tolerable with hd signals. You must have taken your set in to have it checked and it sounds like its not worth fixing.
    I already spent about $800 having the set repaired after a lightning strike.
    Anyway, good luck... I'm thinking about dlp next
  • Anonymous Jan 14, 2008
    I have the same problem. Which is the I/P black box? And where can I purchase a new/used/refurb. at? Thanks for the help.
  • shaefferj Jan 02, 2009
    I have the same problem and using the DVD player makes it worse! I wouldn't think this would happen to such an expensive device.
    joseph.shaeffer@yahoo.com
  • 579 Answers
This may not be the problem but its worth a try:
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Posted on Dec 31, 2007
Lines on top of screen jvc 36 inch model AV-36f802
Check and replace all the electrolytic capacitors at the vertical output section circuit. Replace the supply smoothing electrolytic capacitor to video output supply voltage.
Mar 06, 2013 | JVC AV-36F802 36" TV
Picture bowed
This is called vertical pincushion IMHO.
With a bit of luck you should be able to adjust this from the service menu.
Access the service mode: set SLEEP TIMER to 0 MIN.
While this is still displayed, simultaneously push DISPLAY and
VIDEO STATUS.
Oct 19, 2007 | JVC AV-48WP30 48" Rear Projection...
I CANT ADJUST THE RED VERTICAL LINES ON MY JVC REAR PROJECTION TV. i HAVE DONE CONVERGENCE AND MANUALLY ADJUSTED THE RED LINES HORIZONTALLY, BUT NO LUCK WHAT CONTROLS TO USE VERTICALLY
If it will not adjust up or down or left and right the convergence chips need to be replaced.
See attached photos of board that is in your set:
This can be a do it yourself repair and the parts do not cost a fortune.
Can I help?
SD TECH
Oct 16, 2011 | JVC AV-48WP30 48" Rear Projection...
I have colored vertical lines on my JVC AV-48WP30 projector television what is the problem? Audio is fine, this started with large vertical lines and ghosting but now the lines are about 1/4" wide and not...
Let me say something and also post a few photos.
If you go into the customer menu and select convergence is it skewed and will not adjust. If so you have a convergence circuit problem--not real expensive or hard to do on this model
Look at the photos I will post and tell me if they look anything like your problem.
If they do I can give you directions to fix it yourself.
Most convergence problems shops will get 300 or more to fix but the actual parts cost is under 30.
Look at these photos and let me know if they look anything like your problem.
If this has helped you rate this solution as I do this here for free.
I speak from first hand knowledge as I have repaired hundreds of sets with convergence problems.
sd tech
OR?
Dec 18, 2009 | JVC AV-48WP30 48" Rear Projection...
Red and green vertical lines through television. tried to line up crosses in convergence option under menu with no luck.
Ur convergence is dead,buy the convergence kit,use what in that kit.U know how to solder right?Tries these Websites Tv Repair World.com or Ebay.com.
Sep 30, 2009 | JVC AV-48WP30 48" Rear Projection...
Repairing JVC AV-27D202 27" TV
This is caused by a bad capacitor in the vertical circuit. If you can solder, you may be able to resolve this yourself. If you wish to attempt this repair, please update this and I will provide additional details and instructions.
Dan
Mar 21, 2009 | JVC AV-27D202 27" TV
Purple and Green Streaks
If lcd set the issue may be with the T con board which is responsible for video and any aberrations that you see on screen.
Mar 24, 2017 | JVC AV-48WP30 48" Rear Projection...
it looks like theres a wave in the top of my screen on my jvc av-48wp30 not sure but i think it has something to do with the bulbs because the projection mirror wasfine and all wires seemed to be hooked up properly.. can you help? tell me where i can find the bulbs to replace them?
May 13, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
306 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
